Question about Philips GOGEAR SA6045 MP3 Player
I have a Philips SA1356/97 1GB mp3 player .it is not charging by my pc but it is showing carging by other pc
ThaMp3Doctor
  • 8596 Answers
SOURCE: philips GoGear Mp3 player problem
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
Posted on Feb 11, 2008
  • 476 Answers
SOURCE: STMP3500 driver for PhilipsGogear 1 gb
The driver is installed when you install the Firmware Manager software on the product CD.
The player will show as STMP3500 when it is in recovery mode (usually caused by corrupt firmware)
Install the Frimware manager.
Connect the player.
If asked for a driver let Windows search automatically.
If you get a Signed Driver message just click ok to continue.
Run Firmware Manager and follow the on-screen prompts, and all should be well.
Posted on Feb 27, 2008
  • 899 Answers
SOURCE: charging battery
you might have a faulty charger or the battery just won't charge , if you can exchange it back at the store I would do that , but otherwise the charger would have to be tested and the battery , and if those are ok then something is wrong in the mp3 player
Posted on Oct 12, 2008
SOURCE: My Philips Go Gear SA3025/37 MP3 player won't charge/turn on
i had the same problem. my reset button was jammed. the problem: the reset button is so deep in the tiny hole its hard to tell if you even really hit it when you put a pen in there and somethign like a sharpened pencil just doesn't go deep enough. i monkeyed around wiht a peice of straw in the reset hole for about 10 seconds then tried to turn it on and it worked. good luck
Posted on Aug 10, 2009
SOURCE: Philips SA1356/97 1GB mp3 player
hi my mp3 is philips your problam is same me.help me please my id s.hulangaa_77yahoo.com
Posted on Jun 11, 2010
After charging,the screen says philips,and wont do anything else
Hi Cheryl, The link below is a youtube page full of videos showing how to turn on your mp3 player and unfreeze it.........CHEERS..
how to fix mp3 player that won turn on YouTube
Apr 24, 2016 | Philips GOGEAR Audio Players & Recorders
MP3 player won't turn on.
Well its a software problem so try connecting it to your pc and format it....i think sa kinda virus affected your mp3 player
May 30, 2010 | Philips SA3025/37 Flash MP3 Player
I bought a Gogear 2gb philips SA018 mp3 player i dont know how to start it and download anything theres no instructions and its not showing anything. how do i charge it?
I have problems with the Philips SA018 4gb MP3 player. While it is connected to the computer the it shows green once it is disconnected it goes red and nothing works.The battery should be fully charged as it shows green,but as I have said once it is disconnect it turns red and that's it...there is no joy.I wonder is there a problem with the battery...? Has anyone else had this kind of issue?
May 21, 2010 | Philips GoGear SA178 MP3 Player
Willnot carge up
the port went bad is my guess
Sep 29, 2009 | Philips GOGEAR SA6045 MP3 Player
After chaging my mp3 player, it doesn't work, when charging it shows that battery is charged but there is blured images on the rhs and hen when not cg=harging battery shows red
Have you reset the player? Reset the player by holding the off-switch and the volume-+ (plus) switch.
If this doesn't help try this: Connect your player to the pc that has the Philips device manager running, then reset the player by holding the off-switch and the volume-+ (plus) switch. As soon as the player shuts off, press and hold the volume- - (minus) switch. The Philips device manager will recognize the player now, and recommend a repair, let it do so.
Jul 13, 2009 | Philips GoGear HDD1830 MP3 Player
PC not detecting mp3player and also not able chage
First, make sure the hold switch is not engaged. Then:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
-Tha Mp3 Doctor
Dec 04, 2008 | Philips GoGear SA3125/37 MP3 Player
Hello dear
If u can open your mp4 player then open it. and after change the crystal
detecting problem will be slove.
thanks
Sep 08, 2008 | Philips SA5125/37 MP3 Player
Mp3 philips hdd082/17 not charging and not connected when connected to usb
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Mar 24, 2008 | Philips HDD082 MP3 Player
Dead Nano
I am currently having this issue. It happened once before. What worked last time was putting the lock on - then off - then hold the power button for 30 seconds. Unfortunately - it is not working for me this time...
Jan 06, 2008 | Philips GoGear HDD6330 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
173 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
