Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
My dyson vac will not stay on. When the on button is pressed it is on but as soon as you take your finger off it turns off. Can this be fixed and how
    Filmmaker:
    Uploaded 5 video answers.
  • 101 Answers
It needs a switch. You can get one for three pounds here: Dyson DC07 Spares
Posted on Nov 30, 2010
I can't the the max mode to turn off. How do I fix this?
Hi Kayla, it's Jack at Dyson.
To switch between Max mode and regular mode, first hold down the red on/off trigger, so the vacuum is running. Then at the same time, press and release the Max button on the rear of the machine. The machine is designed in this way to make Max button can't be activated accidentally. When running in Max mode, the button will light up.
I hope this information helps, If you'd like any additional advice, you're welcome to give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
May 26, 2015 | Dyson V6 Absolute Bagless Cordless Hand...
How do I fix the power button for my Dyson DC14?
  • You will need to remove the switch cover and replace the main power switch.
Jun 29, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
My dyson hose sucks good but, when i put handle down, it won't **** but brush does turn
I just had the same problem....suction from wand, but no suction from soleplate, the brush bar spins. Did all the troubleshooting steps on dyson.com but they didn't work...dyson.com says need to take to repairman, being a diyer I went to search engine. I didn't find a fix, however I found one myself....it appears the vac can get stuck in floor mode or in between modes....the dial on top on dc07 ....selector of floor or carpet..try pushing it back and forth to see if that puts it in carpet mode...check for suction or try vacuuming...if that doesn't work, looking at vac from behind vac on the right hand side is the selector dial..on top of bottom portion of vac.....with vac in upright position, recline it as if about to vacuumn floor...look down at selector area ...you should be able to see a rectangular type button exposed ..push this to reset position...you may have to push it a few times...then try vacuumniing.....I finally had suction from soleplate!! Another tipoff to this problem is my selector dial would not stay in place would pop I to carpet by itself, but only halfway....fro a long time my vac would work but not very well...had to go over same area.4-5 times..What a workout! The first time I contacted dyson via tele the rep had me remove some stuff and I was able to look at area below selector...what I saw was two holes, one hole was only over the other hole half way...hence at that time I had only part suction since holes were not aligning properly....I read somewhere as a further tip to get suction to engage, while vac is reclined step on front edge of vac head it said you'll get more suction that way, I haven't tried that, but thought it may help someone
Feb 16, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum will not stay on
Hi Patriccia,
I'm sorry to hear you're having difficulties with your Dyson's on/off switch. If the switch won't stay down when pressed, please call us free on 1866MYDYSON, or email askdysonUS@dyson.com so we can provide further assistance. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Nov 24, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hi my dyson dc18 has great suction from wand but when you got to use the vac for floors little suction but wand still got suction even while vacuming floors is it suposed to stop suction from wand
My Dyson dc18 had the same symptoms. The wand worked well and the floor bar had no suction. After removing pieces & shoving my fingers into the machine (no blockage) I found the suction pipe rotates between two positions (floor and wand). It looks like a piece of plastic broke on the outside housing, so it no longer rotates positions when the wheels are raised or lowered. My son found we can move the suction by sliding a finger into the mechanism behind the wheel cover, and rotating the plastic piece clock-wise or counter clock-wise until it locks into position. It's a big pain but it works for now. I wish I could find a replacement piece online. Patty
Apr 03, 2010 | Dyson DC18 all floors Bagless Upright...
The on button won't stay pressed
Faulty switch, undu the screw with a torx driver where the handle sits and unclip the switch cover out at both sides, be careful not to break it,
where the switch is situated they may be a spring, also test the button, if no good replace
Sep 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Dyson upright suddenly won't stay in the upright position. It appears that a little rubber piece has fallen out of position.
- Stand behind the vacuum cleaner and look at the right-hand side wheel
- Remove the AI PIPE (it has two purple buttons that you push together to lift it up and out - it looks like a Tuba)
- Lay the handle down and look for a black button that will be exposed in front of the square hole
- Stick your index finger and middle finger into the vacant AI Pipe Hole (the square hole)
- Reach over with your thumb and press the black button in front of the square hole
- Whilst pushing the black button, lift your index finger and your middle finger and move the gray plastic piece up (lift the square
hole basically)
- Remove your fingers from the square hole
- Lift the handle and stand your machine back upright again
- Place the AI Pipe back into the square hole
Apr 06, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
The brush on my Dyson DC17 Animal does not turn
Remove the plate over the brushbar. Gently clean out debris. Put plate back on,plug in and turn on vac and press brush bar button to reset.
Mar 18, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson won't keep running
THAT IS THE PROBLEM U NEED TO FIX OR REPLACE THE SWITCH
Aug 22, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson animal, have to hold ON switch for it to work
Pull the wand out of the Vac. Need to use a small Torx bit to take out 2 screws hidden behind the wand storage. Once screws are out, there are 4 push-clips which need to be un-latched. Pry the power panel off and you will expose the two switches (one for power, one for the brushes). Push the power switch down and it should "release" and go back to clicking when pushed. Re-assemble. Took about 5 minutes to fix.
Aug 06, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
120 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
