Question about Sewing Machines
Model #158 19460 need manual to thread and what is the correct tension settings
bargainbox
  • 1388 Answers
SOURCE: WHITE Jeans Machine model 1475 thread tension problem
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on May 23, 2008
louislevel_2
  • 374 Answers
SOURCE: bobbin thread breaks. sounds like clicking while sewing
hi there,
pls, the see the figure how bobbibs thread directionc21dcd7.jpghave you seen theres a screw on latch body case of bobins,you can adjust this but mostly this is factory
adjusted,bobbin tension can adjust here.but try to follow the thread direction.set up again the dial setup tension to #3 and stitch to #8 to #12.bobbins slip due to accumulation of thread under
bobbins.hopefully this may help you to continue sewing.
have a nice day,
Posted on Apr 19, 2009
bargainbox
  • 1388 Answers
SOURCE: cannot get the tension to work correctly. The
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
TOP LOADER:
FRONT LOADER:
back properly.
OTHER ISSUES:
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
.bargainbox.com.au
Posted on Aug 02, 2009
SOURCE: threading my bobbin and correct tension
If you go to this link, it shows for the 117.591 model, but it is threaded the same exact way as the 117.959, that will thread the machine and bobbin, I have used this to thread my machine which is the 117.959, and it sewed perfectly until I started messing with the tension, I still haven't figured that part out yet, but I will and when I do, I will let you know. You should be able to thread the bobbin correctly with the manual, if you are pulling the bobbin through the hole the needle is going down in, your bobbin is threaded correctly, if the problem is like mine, your not making stitches, the problem is with the tension. I hope I have helped and if not, sorry.
http://sewusa.com/Threading_Diagrams/Threading_Pages/Kenmore_Sewing_Machine_Threading/kenmore_117591_threading_diagram.htm
Posted on Sep 24, 2009
  • 255 Answers
SOURCE: I need a manual for a Necchi Royal Series,
Hi! I found your manual at http://www.sewusa.com/Sewing_Machine_Manuals/Necchi_Manuals/4795_Instruction_Manual.htm
Happy Sewing!
Robbie
Posted on Mar 15, 2010
Necci 752 manual is needed.problem with threading and stitching
Hm, I'm not able to locate a manual but may be able to offer some suggestions.
Remove the top thread from the machine.
AVOID OLD OR BARGAIN BIN THREAD!
Use the same thread in top and bobbin.
Be sure to use a brand new needle--needs to be compatible with the thread and fabric of the project..
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the top tension to the midway point.
Verify the bobbin is loaded and threaded correctly and it turns the correct direction.
Pull the bobbin thread up through the fabric before taking the first stitch. It also helps to hold both thread tails in your left hand when taking the first stitches.
Test your machine and tweak the top tension until the top and bobbin threads meet in the middle of the fabric. (Increased top tension will pull the bobbin thread up. Decreased top tension will allow the bobbin thread to pull the top thread down.)
How to Thread Necchi Sewing Machine
How to Thread Necchi 535FA 535 534FB 534 Sewing Machine and Bobbin Case (not your model, but the threading and basic instructions will be similar or the same as your machine)
How to thread Necchi model 535 FA sewing machine now with captions
Mar 18, 2018 | Sewing Machines
How to thread tension on my L47 singer sewing machine
Threading and tension are two different things.
You can search for a manual:
Make Model manual
or
Make Model threading
(most machines thread similarly so even if you don't find your specific model, the instructions would be helpful)
https://www.manualslib.com/products/Singer-L47-4062252.html
When threading, be sure to ALWAYS RAISE the presser foot so the thread will seat completely in the tension disk.
For tension, generally start with the tension set at the midway point. Tension is correct when the top and bobbin threads meet in the middle of the fabric. If the bobbin thread is showing on the fabric top, loosen the top tension. If the top thread is showing on the underside of the fabric, tighten the top tension. Do not adjust the bobbin tension until it has been determined that the top tension does not make the adjustments needed. (Bobbin tension is sensitive--a little change makes a big affect so you will need to know how to reverse any changes you make.)
Understanding Thread Tension Threads
Jan 15, 2018 | Singer Sewing Machines
Top thread too tight?
make sure tat the thread is between the tension plates and not behind and jamming on the bolt
proper tension is a slight resistance when you pull the thread to thread the needle
Oct 20, 2016 | Necchi Sewing Machines
I have Bernia 180. The bottom thread is puckering. Top thread is perfect. I cannot find help in manual. Please help
Check that the bobbin is inserted turning the proper direction in the bobbin case and that the thread is threaded correctly through the tension control on the bobbin case.
Make sure the upper thread is threaded correctly. The factory standard upper tension setting is midway between high & lower number although this may need to be tweaked for your particular machine.
If the machine is still pulling the bobbin thread too tight, you can try tightening the upper thread tension. If it still isn't resolved, you may need to loosen the bobbin tension.
You might also want to check the presser foot pressure on your machine. That generally needs adjustment when changing from thicker to thinner fabric and vice versa.
Manual: BERNINA artista 180 Support BERNINA
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
How can properly adjust my tension
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Oct 02, 2016 | Bernina Sewing Machines
How to fix a thread correctly on a Toyota sewing machine model 5500
You don't state what is the problem with the thread so we are unable to provide helpful suggestions.
As a starting point, make sure to install a brand new needle that is compatible with the thread & fabric you are sewing.
All About Needles
Second, always raise the presser foot while threading the upper thread.
Make sure the thread path is correct (consult the owner's manual), insure that no thread guides are skipped or the thread is not wrapped around something it shouldn't be.
Set the upper tension at the midway point between low & high numbers to test stitch. Tension is correct when both upper & bobbin threads meet in the middle of the fabric.
Apr 12, 2016 | Toyota Sewing Machines
Upper thread keeps breaking
The most common cause of upper thread breakage is incorrect threading. Remove all the thread, install a brand new needle, RAISE the presser foot, and then rethread from the beginning. (Verify with the owner's manual that the threading process is correct.) The other thing to check is the upper tension setting. The factory standard setting is usually the halfway point between the high and low numbers. Tweak the upper tension to achieve correct tension. Correct tension is when the upper thread and bobbin thread meet in the middle of the fabric. The upper tension is meant to be the most common method of tweaking tension. As such, a sewist should become comfortable with tweaking the upper tension.
Jan 19, 2016 | Sewing Machines
Need diagram for threading and what must the tension be on cotton
Consult the owner's manual or search the internet for:
Make + Model + the word "Manual"
Factory standard upper tension setting is halfway between the high and low tension numbers. Correct tension is when the upper thread and bobbin thread meet in the middle of the fabric.
Upper tension is meant to be the method for tweaking tension. A sewist should become comfortable with adjusting the upper tension, especially when fabric, thread, or needle are changed.
Need manual my tension is out I think the bobbin is also faulty
search the manufacturer's website or Google make,model,manual
Dec 15, 2015 | Sewing Machines
How do I adjust tension?
Probably best to consult your owner's manual. If you don't have one, search the internet for:
Manufacturer + Model + the word "Manual"
HINT--BEFORE threading the upper thread, raise the presser foot so the thread will seat properly in the tension disk. Verify that you are threading everything correctly and not missing any steps.
The upper tension is the dial usually directly above the needle. About the halfway point between the high and low number is the standard factory setting, but that may have changed over time. Start with it set at that point and test, re-adjust, test... For most machines, the higher the number, the tighter the tension.
Correct tension is when the upper and bobbin threads meet in the middle of the fabric. If the bobbin tension is coming to the top of the fabric, the tension is too tight. If the upper thread is showing on the bottom of the fabric or is creating a loopy mess, the upper tension is too loose.
In most cases, the bobbin tension doesn't need adjusting. However, when you get into more adventurous sewing when you load different types of thread, ribbon, elastic, etc. in the bobbin, you might want to adjust the bobbin tension. In any event, be sure to mark the screwdriver slot setting on the bobbin case so you will be able to undue any adjustments you make. And, make only 1/8th turn adjustments at a time and then re-test. Small changes to bobbin tension will make a big impact in stitch quality. Some sewists will buy an extra bobbin case to keep on hand just for special projects.
Also, note that the upper tension will probably need re-adjustment when changing projects with different types or weights of fabric, thread, and needle. Get used to adjusting the upper tension to get the best stitch possible on every project.
Dec 06, 2015 | Sewing Machines
How do I fix the upper tension?
top thread tension is set via a pressure roller on back on most models , some serger's use the actual thimble for this, but most use a simple pressure roller , usually a simple two washers with a spring pushing them together and a screw that adj the spring pressure
the needle foot most times has a thread grabber that grabs the thread and pulls it enough for one stich at a time then releases it then goes thru cycle again
Oct 29, 2015 | Sewing Machines
Sewing Machines Logo
56 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
