Theres no power to my idesit wixl123 - Washing Machines
    Champion:
  • 207 Answers
From what you wrote I can only hint that a fuse within a machine must have played its part for some reason so you better not mess with it. Call a repairman.
Posted on Apr 20, 2008
  • Ljubomir Vucinic
    Ljubomir Vucinic Apr 20, 2008
    There's also a possibility that some wire inside of machine has fallen off but from your question I can't tell much.
Hi,our Idesit IWB5113 has stopped heating the water,element,or something more tech?
replacing the heating element should take care of the problem. Make sure you unplug the unit before installing the new one. Also you may want to take a photo of the wiring so you will know where they hook to.
Nov 01, 2016 | Dishwashers
Why do all lights flash when machine is turned on and unable to start the washing?
The number of times that the lights flash is the trouble code. Your machine is in need of repair.
Nov 21, 2015 | Washing Machines
Can a drum on an idesit integrated washing machine be replaced
Hello.
The answer to your question is YES .
But you most have a very good instruction to follow with the proper tools.
Thanks
Nov 08, 2011 | Indesit W 123 Front Load Washer
Hi I have no power to my WIXL123 washing machine. I replaced 13A fuse - still no good. checked the power socket - works fine. what part could be faulty?
ds nanra, you need to look first at where the power cord enters the washing machine. It then connects to the terminal block on the inside. There is where you need to check for loose/burnt connections. If you have the means (a voltohm meter or continuity tester) you could check the power cord itself for continuity, which would mean that the cord is fine if it has continuity. This is the first place you need to check. Other than a visual check for obvious defects on the power cords connections inside the washer, you would have to test it with a meter for definitive results.
If you have any other questions, dont hesitate. I would be happy to help you out further.
thanks,
mike
Jul 19, 2011 | Washing Machines
My washing machine will not drain ..it is only 7 myths old ,i cannot seem to remove the filter either ..its an idesit w1b111 model .any help as i know its usually the filter that is blocked but as i cannot...
You will need to remoe the drain hose and get teh link out, the drain pump/valve must be clogged or filled with dirt. use a goo d jet of water to remove clogging, try to power and see if this works . or else replace the unit.
Sep 21, 2010 | Washing Machines
Machine stopped mid cycle with water still inside and the panel is saying FO/5
F05 means you have a pressure switch fault, check the pressure chamber or pipe also the wiring from the switch. For more Hotpoint, Creda or Idesit error code definitions use this link
Mar 18, 2010 | Hotpoint Ultima WF860 Front Load Washer
Boiler broke down
if you have two hoses going into it probably not
Jun 10, 2009 | Indesit W 123 Front Load Washer
Try to replace the door seal on my zanussi fjr 1454w washing mach
its a pain, I am not sure of the zanussi systems, on a Hoover/candy and hotpoint/idesit, these are a clamp band with spring and bolt, you have to secure both sides of the nut and bolt, and unthread the bolt the clamp will open up and can be removed, and do the opposite putting it back on, I find access from the top of the machine is easier to work with on the inner clamp, but remember to turn of the power as some of the components around where you will have access from will be live, always unplug from the wall, shocks are not very nice or good for the heart.
Mar 24, 2009 | Zanussi F1245W Front Load Washer
Washing Machines Logo
322 people viewed this question
Top Washing Machines Experts
