Question about Sony KP-51WS500 51" Rear Projection Television
When i turn my tv on the picture is fine but within 10 seconds it starts fading to blue and after 20 seconds it goes almost completely blue then shuts off and flashes a red light
  • Sony Master
  • 8,617 Answers
The blue crt has failed most likely. very common with that model.
Posted on Jul 15, 2010
Save $. Try to adjust the blue CRT clams under the lamp similar to other color setting. Make sure to turn off power before adjusting.
Posted on Jul 31, 2010
Tv comes on for 10 seconds then fades to a green tint then turns completely green for a few seconds than turns off
Symptom shows tv got problem with green picture tube that need to be replaced.
Rear projection tv has 3 picture tubes, red-green-blue to make color picture.
Since its an old model so spare parts would hardly be available and local tv repair shop will help you to arrange required part, if they can.
Thanks.
Apr 16, 2010 | Sony KP-57HW40 57" Rear Projection...
I have a KP-57WS500 when I turn it on goes blue...
Type in Sony Blinking Codes, you will find alist that tells you want each one means.
Aug 06, 2009 | Sony Televison & Video
Normal pictures fades to blue screen within 30 seconds
The fix for this is here somewhere, as I had the same problem last January and the solution was posted here in March last year. I'll try to find it and post the link to it for you, later.
Nov 06, 2008 | Sony KP-51HW40 51" Rear Projection...
TV goes out
pyrosp4,
it maybe you blue crt (picture tube). mine turn blue and then shuts off. i got it repaired for 460. 300 for the part 160 to install. you can try to adjust the voltage settings behind the speaker screen and see if that clears the problem. if not its you blue crt.
pridah
Dec 18, 2007 | Sony KP-65XBR10W 65" Rear Projection...
Sony KP-51HW40 51 in. Rear Projection turns blue
Hello......
First reduse the G2 voltage for the blue c.r.t,and watch if the unit works for longer period (offcource blue colour will be not present).After reducing G2 voltage to blue c.r.t still behaves the same than c.r.t is faulty and you have to replace.
Pls count the red led blinking when it goes off,incase it goes to std by mode.
Gopali
Dec 14, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Portable Grundig TV/vcr combo - screen goes blue and then set switches off.
Hi mcloud Your problem is your video circuit.the component could be faulty or it has lose solder.have a tech look on your set for repairs.good luck.
Apr 25, 2007 | Grundig GF70-600 TV
Picture Fades
It isn't clear if the picture just loses color or the screen goes blank. If you are just losing color (picture goes to B/W) there is a problem in the color circuit and from your description it could easily be a bad solder connection on the board which decodes the color portion of the picture. If you are capable with a soldering iron and know TV HV safety, unplug the set, and remove the circuit boards and inspect (with a high powered magnifier)and resolder all suspect looking connections on the boards. You could also resolder all the connections which is more work but assures that solder joints are not the problem. If your problem is not solved at this point you are probably going to need a technician to look at it as it could be just about anything and probably would be beyond your expertise. Good luck and be safe.
Jul 12, 2006 | Sony KP-57WS500 57" Rear Projection...
Loose Picture (Goes completely Black)
Nothing special about that board as I cant seem to find that # but If my memory serves me correctly it sounds like a crt board and its a simple soldering job on the crt socket?? Altough Im not there to see the set still 550.00 seems like an awfull lot to repair a set even if they have to replace the entire chassis. I think you should cal rca and take it to an authorized RCA repair center and if the shop you took it to was an rca authorized center I would also report that to them(RCA). Good Luck
May 16, 2006 | RCA MM32110 TV
Sony KP-51WS500 51" Rear Projection Television Logo
180 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
