Question about HP Office Equipment & Supplies
Paper jam problem. the red light blinking. how can you solved the problem
    Problem Solver:
  • 7 Answers
First make sure that there is no paper left in the printer paper path. If there is DO NOT JUST YANK IT OUT. You could damage the printer. Remove it carefully. Some printers have levers that release the pressure on the paper so it can be easily removed.
Check the paper path and make sure there isn't a flag or sensor out of alignment.
Power down, wait 30 seconds, and power back up to see if it clears.
If it does not pick up the paper at all, it will give you a paper jam error. Your pick up roller is probably dirty or worn out. You can clean it with alcohol or depending on the printer, replace it.
Make sure the paper tray is set correctly. If you have a removable tray, the paper size could have slipped back to a longer paper that what is in there and this will cause the paper jam error as the pickup roller will not be able to pick up the paper.
Posted on Jul 14, 2010
Red lights blanking
1st uninstall printer software in your system and reboot your system them after re install software.
Nov 20, 2013 | Epson STYLUS R230 InkJet Photo Printer
Printer hp deskjet 840c blinking green and red light why
Depends which red blinking light. I assume the red light is the resume light. The green light is the power light. If the Power and the Resume light are blinking alternately, then you have a paper jam somewhere in the printer. remove the paper jam and you should be fine.
Mar 18, 2011 | HP DeskJet 840c InkJet Printer
Hello, my Lexmark e120 gives me the sign of paper jam (secondary light sequence: 10 times blinking green light and red light is on). I opened all the doors (rear, top and front) but didn't find any...
This answer may seem elementary, but I would recommend that you change out the paper, and prior to loading the fresh paper, I would recommend that you fan the paper to separate it. I would also recommend that you readjust the paper sizing control as well. Have you tried resetting the machine? You can do so by unplugging it for a few minutes.
Mar 07, 2011 | Lexmark E120n Laser Printer
Polaroid Paper Jam
I had the same promblem and this is how I solved it. If you have an android, screen shot the picture and crop as you desired. Then Press the share button and click bluetooth (Poloroid Zink) and dial in 6-0-0-0 for the password. Only put that in for the password. If it the password entry doesn't come up, that's okay. Hopefully this helped!
Nov 08, 2009 | Polaroid PoGo Digital Photo Printer
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Mar 25, 2009 | Brother HL-2040 Laser Printer
Xante 1200, paper jam front. Red light is blinking without a paper jam.
PROBLEM: Paper Jam. XANTE 1200, Tabloid size, B&W, Printer —Red light blinking fast indicating paper jam upfront. If you checked everything, trays, ink cartridge etc., and see no paper jam anywhere, take the top cover off and look inside the (head) for the jammed paper! This printer is problem free. It has given us the best service for many years.
Michael J. Frangos, Baltimore, Md.
Feb 04, 2009 | Xante AW 1200 Laser Printer
HL 2040 paper jam light is blinking but there is no jam. the printer sounds like it dies out everytime it tries to print.
Often the paper jam light will stay on when the *back* paper jam door is not cleared.
Open up the back of your printer. There is a 2nd door behind this door that you can pull open. If there is a paper in this section, pull it out and it should clear your red light.
When clearing paper jams, clear the front first, and then if the red light is still on, you need to check the back hidden door for another piece of paper.
Dec 08, 2008 | Brother HL 1440 Laser Printer
Printer ML2010 not responding
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 15, 2008 | Samsung ML 2010 Laser Printer
Printing troubles
Paper jam:
Clear the paper jam. If the printer does not start printing, press the control panel button.
No paper:
Put paper in the printer. Then press the control panel button.
Misfeed:
Put the paper back in properly, and then press the control panel button. The printer will start printing again.
Mar 24, 2008 | Brother HL 1440 Laser Printer
mukhtar21 shaikh
mukhtar21 shaikh
