Question about Husqvarna 28cc Gas Line Trimmer
Hi my husqvarna 128L will not run unless i have the choke half one
    Problem Solver:
  • 11 Answers
Fuel restriction problem
-dirty carburetor
-kinked fuel line
-most likely - old and stale gas that has corroded the carburetor and needs to be cleaned
www.ButlerPower.com
Posted on Sep 06, 2010
  • jennifer336 Sep 06, 2010
    Hope this is helpful, please call 860.233.5439 x222 and speak to John
    Thank you
My husqvarna chain saw will run only if choke is at least half way out
this is a sure sign of a fuel blockage some place !! id start with fuel filter and air filter and then look closely at fuel lines for signs of collapsing when running (CAREFULLY!!!!!) then move on to cleaning and resetting carb jets
remember choke richens fuel/air mix so if it needs choke to run then it's being restricted in fuel supply
Jun 17, 2014 | Husqvarna Chain Saw 20" Bar
Husvarna power trimmer and blower only runs with choke
If this is the 128L or R machine, they are not made by Husqvarna, they are hobby machines built in the US, they are low quaility machines built for a lowr price, they are not designed for continual heavy use, Husqvarna built higher quaility machines for this type of use, unfortunatly the prices reflect this.
Aug 19, 2013 | Husqvarna Garden
How to change fuel line on Husqvarna Trimmer 128L
They are juat a pull in fitting. Get access to the fuel tank, the broken fuel line should just pull out the tank. The new full line goes back in through the top, just pull through into the tank until the hole in the tank sits between the 2 flanges on the fuel line.
Mar 20, 2013 | Husqvarna 128L Line Trimmer
I own a Husqvarna 128LD. My trimmer works on full choke, half choke, and when in the run position...it runs...but when the trigger is on balls to the wall throttle, it goes dead. What is my next move?
The next step is to richen the fuel mixture on the H screw on the carb, there is a special tool required to turn the adjuster screws because they have a splinr rather than a screw driver slot, the tool is part np. 530035560 unscrew tthe H screw 1/4 turn anti clockwise.
Aug 07, 2012 | Garden
Husqvarna 223l runs wide open on choke, but dies when choke is off
it may be the idle jet is plugged there is a needle and seet on most of them. have you tried half choke sometimes the will clear on their own
May 01, 2012 | Husqvarna Garden
My husqvarna 128ld starts and idles fast but only with the choke half on. Give it gas or take the choke off and it dies.
Possibly a fuel starvation issue, incorrect fuel air mix or an air leak within the fuel system
Nov 25, 2011 | Husqvarna Garden
I have a husqvarna 455 rancher that won't run at full throttle unless the choke is on. It runs at half throttle fine.
Clean or replace the fuel filter. Check the fuel lines for decay or other damage. Check the muffler for plugging of the screen. Be sure to run with fresh fuel mix and to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
Nov 11, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
My husqvarna GTH2448T has to be choked to run
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes.
Oct 06, 2008 | Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna 28cc Gas Line Trimmer Logo
308 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
