Cd drawer broken and cant eject disc.cover has come off and is lost.
    Champion:
  • 207 Answers
New DVD ROMs costs so little nowadays that any repair or wasting time of finding spare part would cost you more. You can buy new DVD writer for as little as 20$. http://computers.pricegrabber.com/dvd-rom-dvd-writers/p/7/lo_p=24/hi_p=26/x=71/y=11/st=filter/lo_p=20/hi_p=26/x=45/y=15
Posted on Apr 20, 2008
I hit the eject button and the drawer opened, but my disc was not there
It will take the removal of the CD drive and opening the case to dislodce the CD from the spindle.
Oct 20, 2014 | ASUS Computers & Internet
CANT OPEN THE CD DOOR
Take out the complete mech, look for a small pulley wheel under the tray and turn it with your finger until it releases the disc
Apr 19, 2014 | Kenwood Audio Players & Recorders
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
CD-R drawer won't open. CD is in drawer.
there are different reasons for stuck up disk tray
1. load belt is worn out already
2. driving gear for mechanical loading disc tray has broken teeth.
3. cd got stuck up between the loading disc tray and the plate holder.
You will need unplug your device first and then unscrew the cover of your unit and find it yourself to know what causes it not to open.
once the cover is out, the mechanical loading disc tray will be exposed.
1. remove the stuck cd
2. plug the unit and turn on, to get access the belt, wait for the disc tray to move to the pull out position, then unplug your device.
3. plug the unit and turn on, if the disc tray do not move, use your finger to move the tray and see which gear is broken.
belts are available from this site. just have to measure the correct diameter of the belt in your unit
http://electronics.mcmelectronics.com/search.php/ui.php?lastSearch=belt+cdr201&lastDims=4294967285&Ntt=belt&ctl00%24ct1%24RefineButton=Refine
Feb 16, 2011 | Classic Electronics CDR201 CD Recorder
I asked for free help in ejecting my cd from my Kenwood DV-505. I have already reset the microchip to factory setting and have unplugged it for 5 minutes and then simultaneously held down the open/eject...
Normally on the drawer that you use to put in the CD there is a very tiny hole, look closely for it. Take a paperclip and straighten it out, insert it into the hole and push. This should help open the door. You might have to pull the drawer out the rest of the way but you should be able to get it out.
Nov 20, 2009 | Kenwood CD-403 5-Disc CD Changer
Cant play dvd cd or even eject the disc that is already in .
actually it is due to faulty disk or dirty lens sometimes , when the lens is dirty it keeps on trying to read the data from cd or dvd and it just cant stop that infact stuck in it , or the other reason is faulty loading gear , in either case u have to physically dis assemble the player , remove the top cover some 4 or 6 screws are there in place open the top cover see the cd /or dvd and remove it physically do not force anything hard when removing the media and then if u can see the lens of ur player just clean it with a soft cloth with ur fingers in cicular motions very gently and u will see that it will play dvd /cd fine , the other thing if the loading gear is faulty or broken then u can ask me more on this
Pls rate me WELL !
Jul 04, 2009 | Pioneer AVH-P6500DVD Car DVD Player
TEAC-P1260 - Initially Cd would play then eject randomly. Next would play only a few seconds then eject. Now has eaten a disc and will not eject. Any suggestions?
First you do is to unplug the cord of your CD unit for 5 hours in order to drain the stored current,the purpose is to reset the unit. After the 5 hours plug the CD see to it if it open If not,just try to press down on the stop button and pressing eject button at same time and it will unlock the tray .Then the other option is to open the cover of the CD unit and unplug the unit again to avoid electricalshock . When open already look for the disc platter moved it outward while driving the gear or simply push out. The drawer or door of the CD player and you will see a small circular disc which is often called turntable or disc platter.When the disc platter is out push it back and push it out you do this three times so the slider mechanism align it properly.If you do already what i said then plug it again and if works already closed the cover. The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn?t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There?s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also. Hope it may help you; Regards; VOTIT
Jun 08, 2009 | Teac CD-P1260 CD Player
NAD 502 CD player problem
Does it have a failing drawer belt? My 522 was fixed after that.
Jun 18, 2008 | NAD C521 CD Player
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
