Question about Samsung Cameras
Samsung NV9 camera 'Turn off and on again' status
Samsung NV9 camera 'Turn off and on again' status message. How do I reset this so that the camera can be used?
2 Suggested Answers
  • 109 Answers
SOURCE: message turn power off and on again
your lens may be jamed thats why it tells you to turn off then on its tring to cycle the lens so i would check that first! good luck!
Posted on Sep 02, 2009
Error message "turn power off and on again" I did this and it did not work.
Performing a manual power reset (If your camera does not have reset button and initialize function)
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
Jan 07, 2014 | Sony Dsc-s2000 Cyber-shot Digital Camera...
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for using FixYa.
Feb 25, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
On the screen shows turn off and then turn on again and again-it does not turns on any way
The Turn off and on again error message displays when there is an internal malfunction or a malfunction with the Lens. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Setup 1 Menu of the Camera to OK. (Menu-->Setup-->Setup 1-->Initialize-->OK.)
This should resolve the issue. If the issue persists, service may be required.
Jan 17, 2011 | Sony Cyber-Shot DSC-W7 Digital Camera
DS-W370 lens the lens of the camera are out and i get a message to turn off the camera and try again but never worked
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Main Settings Menu of the Camera to OK. (Menu-->Settings-->Main Settings-->Initialize-->OK.)
Jan 10, 2011 | Sony Cybershot DSCW370 Digital Camera
How is e-studio 230 re set the copy counter
Reset the status counter
(1) The following processes are carried out after completing repair of the cause for the C41 error
message.
(2) Press the [0] and [8] keys simultaneously to turn on the power.
(3) Input 400 using the numeric keys, and press the start key.
(4) Change the displayed status counter from [2] to [0], and press the SET key (Reset C41).
(5) Turn the power on again, and check that it returns to the normal standby mode.
Let me know your result.
Nov 17, 2010 | Toshiba e-Studio120 Copier
Error message when turned on
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the SET UP1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks for contacting FixYa
Apr 27, 2010 | Sony Cyber-shot DSC-S600 Digital Camera
When pressing the camera key or selecting camera from the menu, the camera attemps to load but the screen remains balck with the message "camera failed" There is no problem with memory status as I have yet...
try to back up all your phone files, and do a hard reset.. press *2767*3855# in your phone keypad , if this will not help you load the camera, i would suggest to visit samsung service center it maybe a hardware problem.
Feb 17, 2010 | Samsung Jet S8000 Cell Phone
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Message turn power off and on again
Sep 02, 2009 | Sony Cyber-shot DSC-M2 Digital Camera
Cameras Logo
180 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
