Question about Samsung SW62ASP Top Load Washer
Tornado 7 kg WA 90B9 washing machine top loading type, the rubber flap in the filter torn.
  • 1,998 Answers
You can order a new flap froom marcone appliance parts they have front door mail service alson if marcone does not carry this and they should you can go dircetly to samsung I have personally done tons of warrantly work for them ad they are more then happy to help there customers hope this helps
Posted on Jul 13, 2010
Can a clogged filter cause my machine to leak?
Yes. A clogged filter can cause your machine to leak. Always keep filters clean-especially using well water.
Mar 09, 2015 | Gorenje W7543LR Red 600 mm Washer Front...
Hi the large rubber section that joins fom the door t the drum inside on my Aqualtis AQ9L 29 I 9kg washing machine has come off????? Is there any way I can fix this back on myself? Any tips? The rubber...
there is usually a ring type clip with a spring on it that goes around the rubber section to hold it on...I am assuming this is a front load washer...you can remove the top of the washer by removing a couple screws..look inside for the clip..it may have fallen off inside....then you can put the rubber back in place and re-attach the clip
Jun 11, 2011 | Washing Machines
How to clean out the machine a top load 7.5 kg load hoover
Open the lid, locate the centre washing spindle/arm then undo the cap on top of the spindle (this will either unscrew or just slip out, Pull up.) inside there you will see the lint filter, wash this out and put back.
Nov 02, 2010 | Hoover HTC243 Top Load Washer
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
The washing machine makes a high-pitched squeking
No, not if the noise is only when rinsing, if it makes the noise when spinning generally then possibly but if only noisy when rinsing sounds like a filter blockage on the waste pipe. clean out the filter behind the flap on the bottom of the front panel
Aug 21, 2009 | Maytag Bravos MTW6600T Top Load Washer
Rubber Gasket Torn
IT IS EASY :
1- IF YOU SUCCEED TO TAKE OLD gasket YOU CAN DO IT FOR THE NEW ONE
2- IT IS JUST A RUBER PEICE SO YOU CAN
3- LIKE YOU SAID a {spring securing OR CLAMP } USING A SMALL TOOL {SCREWDRIVER OR BLAYER } TO DISCONNECT THIS SECURING PIECE IN FRONT THEN
4- FLAP THE RUBBER TO INSIDE THE DRUM THEN
5- THERE IS ANOTHER SECURING PIECE HOLD THIS RUBBER WITH DRUM INSERT YOUR TOOL AND DISENGAGE THEN
6- NOTICE THE TRIANGLE IN THE RUBBER PIECE
IT IS THE MARK TO CONNECT AGAIN IN RIGHT WAY OR YOU CAN MARK BY A PEN
7- REVERS THE MANAR
YOU WILL REACH
GOOD JOB
Jun 18, 2009 | LG Washing Machines
Whirlpool top loader 9 kg - I can't see any serial no.
There are no lint filters on this machine. The lint is pumped out with the water. There may be a restriction in the drain line starting where it connects to the tub or the small drain holes in the inner tub may be clogged.
Jan 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Samsung SW62ASP Top Load Washer Logo
225 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
