Question about Intel Motherboard
Cmos battery replaced already but still system
I've replaced my desktop computer cmos battery but still I need to press F1 whenever I opend my computer.
    Guru:
  • 480 Answers
Hi
You can disable the halt errors
In the bios
Posted on Jul 13, 2010
I've changed the CMOS battery of my GX260 series desktop as it was prompting an alert as "System battery voltage low" & after that Systems IDE configuration failed performing an automatic...
Press f2 to enter the BIOS while you see the Dell start up screen. Once in there you shoudl see an option to load BIOS defaults. Load defaults. This should take care of the issue. Are you sure that you replaced it with an approved CMOS batter, You cannot use a watch battery, even though they are the same size it won't work.
Aug 01, 2011 | Dell OptiPlex GX260 PC Desktop
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
My girlfriends Hp Pavilion A305W powers on then automatically powers off after it show a brief error message but also says F1 for startup. Should i press F1 and continue diagnosis?
Most probably your system is not getting your BIOS settings from your mainboard due to CMOS battery failure.
Check your CMOS 3.0v battery & replace it. Then reconfigure your BIOS settings from the CMOS setup.
Hope it helps
May 28, 2011 | HP Pavilion a305w (DM181AR) PC Desktop
CMOS checksum bad Press f1 to run setup Press f2 to load default values and settinss Keeps comming up on star up
Your CMOS battery may be dead. That is the watch style battery on your motherboard. Choose f2. If the problem persists, change the battery
Feb 28, 2011 | E-Machines eMachines Desktop PC
Computer that keeps saying F1 to reboot F2 for setup utility
what is the message you getting?
if it is to press F1 key to contiune then u need to replace ur cmos battery. you will find the battery on ur mother board, if there is no battery then you need to buy a new battery .
good day
Jun 05, 2010 | Dell Dimension 4600 PC Desktop
I get the message "Bad check sum (CMOS)" Model toshiba tecra 730XCDT
hi friend,
Probably a dead Motherboard battery. Need to enter the BIOS screens and reset values. Especially the time and date. Maybe the boot order and if using USB KBoard enable legusy USB devices. This will occur each time your friend shuts down and reboots until the battery is changed.
Issue
When you turn your Toshiba computer on, you see an error message like: **** Bad RTC battery ****
**** Bad Checksum (CMOS) ****
Check system, then press [F1] key The Real Time Clock (RTC) battery provides power for the internal clock/calendar and for maintaining system configuration settings.
This error can occur when a machine has been left turned-off for an extended period of time (around a month), and is the result of a depleted RTC battery. Other symptoms include not being able to execute Windows Update properly, errors/problems executing application software (like Norton Antivirus), and the appearance of the Windows XP "Desktop Clean Wizard".
Resolution This condition is easy to fix in 3 basic steps: Reset the BIOS defaults
Set the correct date and time in Windows.
Charge the RTC battery Please follow the detailed instructions in the next section.
Procedure Set BIOS defaults Press the [F1] key as instructed in the error message:
Check system, then press [F1] key In the BIOS setup screen press the [Home] key to restore the default values, then press the [End] key to save and exit, then the [Y] key to confirm and restart the system. Set the correct date and time in Windows As Windows starts-up, you may see an error message about an "Invalid System Time". Go ahead and click "OK" to clear the error dialog. Open the Windows Control Panel and open the "Date and Time" control by double-clicking its icon. Set the correct date and time, then click OK to save. Charge the Real Time Clock (RTC) battery To charge the RTC battery, connect the AC adapter and turn the computer on (both the DC IN and Power LEDs must be green). Leave the machine on for approximately 24 hours to ensure a full charge in the RTC battery. Please note that the RTC battery does not charge while the PC is turned off, regardless of whether the AC adapter is connected or not. Other Information: If, on subsequent reboots, the "Bad RTC Battery" error persists, it's quite likely that you actually do have a bad RTC battery. If that's the case, you should contact a Toshiba Authorized Service Provider to have the system serviced. Windows XP Desktop Cleanup Wizard The first time you reboot Windows XP after resetting the system clock, Windows XP may try to run the "Desktop Cleanup Wizard". Simply Cancel the "Desktop Cleanup Wizard" at the first dialog. If you do manage to clean your shortcuts from the desktop and want to recover them, you will find them in a folder called "Unused Desktop Shortcuts". You can recover them as follows: Double-click to open the "Unused Desktop Shortcuts" folder
Drag the selected items back to your desktop
Close the "Unused Desktop Shortcuts" folder. You can delete this folder if it is empty.
thank u for using fixya
regards,
sivaranjini
Aug 10, 2009 | Toshiba Tecra 730CDT Notebook
Toshiba satellite a60 wont start.
replace your cmos battery inside... look for a technician for assistance to remove the cmos battery and change a new one... your battery is weak already
Jun 18, 2009 | Toshiba Satellite A60-S1561 Notebook
Turn on computer and message reads ****bad check sum (CMOS) ****
That means that after computer had been off for a long time the CMOS battery has drained, and CMOS (BIOS) settings had been reset to default.
Usually the computer will work fine after pressing F1, but you may get wrong date and time.
Try charging battery completely, often the problem disappears, if it does not , then the choice is between pressing F1 each time you start the laptop, or disassembling the laptop and replacing CMOS internal coin battery, located on the lower side of the motherboard.
May 17, 2009 | Toshiba Satellite 1805-S204 Notebook
Computer starts up with bios screen
I guess there is error saying wrong RTC Time Press F1 ... or something along those lines. You need to get replacement battery for your MB. This is a battery that provides power to the CMOS chip with all BIOS settings.
Mar 14, 2009 | Dell Dimension 4600 PC Desktop
How do i reset CMOS on kv8 pro? getting POST code 25 comp not booting up, tried replacing ribbon cable, also unplgged keyboard. HELP!!!
unplug your computer, then you will find a small battery on the motherboard, this is a small silver disk shape. you need to remove this by pressing the clip to its side, this lets it spring free. you then need to locate the cmos jumper. this is a 3 pin stand off with 2 pins already covered by a plastic sleeve. remove the sleeve and place it over the other two pins, wait a few seccons then put everythinbg back to the way it was. put the jumper back in its origional position and re-attach the battery making sure it is the right way up. plug in your system and give it a try.
Dec 28, 2008 | Computers & Internet
Intel Motherboard Logo
61 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
