Question about GE 24 in. Profile PDW8280JSS Built-in Dishwasher
The Normal wash cycle won't light up. Only china cycle - just bought used dishwasher.. GE Profile 5 wash cycles stainless
  • 1,998 Answers
Does the normal wash cycle work though sometimes a ligt might be gone on the control if the wash cycle doesnt work then your in for some headahces unfortunatley you would have to be able to diagnos which is the problem either the main control or the touch pad it all depends on how old the unit is ive seen both of these go you can find the part online at marcone appliance parts if you have a problem diagnosing which it is please call a technician and they will be able to tell which one is malfunctioning
Posted on Jul 13, 2010
How is the china and crystal wash cycle different from the regular cycle on my GE Triton XL dishwasher? Can I use regular dishwasher soap on my china and crystal?
Most dishwashers that employ this setting use a lower temperature for the water and also they do not use the element to dry the dishes, they are air dried. China and crystal are very sensitive to changes in temperature and can crack easily. They should always be washed by hand however if you have to use the dishwasher make sure you have a mild detergent. No bleach or acid should be contained. If it says citrus anything it has acid in it. Also use half the amount of detergent regardless of its strength. Hope this helps. Good Luck!
Jul 19, 2011 | GE Tritonr XL GSD6260JCC Dishwasher
The clean light will not stop blinking so the normal cycle will not run
From another link, clean light flashes 7 times. Turn off breaker for dishwasher, wait 5 minutes, turn back on. with dishwasher door open, push high temp, energy save dry, high temp, energy save dry, then close door, open door, press cancel and then Normal wash cycle. Dishwasher Starts!!!!!! Save myself several hundred $. Was about to buy new one from Lowes!!!!!! Thanks everyone!
Feb 01, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Only can use the heavy wash cycle
HELLO THERE
The cycle doesn't advance or you are unable to use one of the cycles such as light or the normal wash cycle, your problem normally is caused by a bad timer It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance.and if you set it to the normal cycle or light cycle and nothing happens Then you need to replace the timer. ok? hope this is veery helpful for you
Best regards Michael
Jun 05, 2010 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Nov 15, 2008 | GE Profile PDW8400J Built-in Dishwasher
DIshwasher Cycle TIme INcreases by 20 minutes over two years
Try cutting the breaker off for 5 min, This will reset the control. The issue is in order for a dishwasher to clean the dishes properly the water in the dishwasher needs to be at least 120 deg f. If its not the dishwasher keeps adding more time with the heater on to try to achieve this temp. The dishwasher only uses about 1 gallon of water per fill so if the water heater is a ways away or the temp is not hot enough, the water temp in the dishwasher will not reach 120.
Jun 11, 2008 | GE Profile PDW8400J Built-in Dishwasher
Ge triton xl dishwasher
One answer is NEVER buy another GE product!!! I bought all GE Profile appliances when I redecorated my kitchen. Have had issues with every single piece. Refrigerator has been replaced twice (on 3rd one). Triton XL dishwasher will not reset...good luck getting it back to normal wash if you change a cycle...for example to run just a rinse. It is almost impossible to get it to reset. And don't get me started on the over the stove microwave. Never have been able to use the lights. Every time from day one I turn them on, the bulbs blow and the cover shatters. Absolutely no support from GE!!!
Dec 24, 2007 | GE 24 in. GSD6660GSS Built-in Dishwasher
Control Module?
Sounds like a dishwasher.. You didn't say or give a model number. Dishwasher that do not drain are usually caused by clogged up drain hoses, often right where it connects to the drain or disposer under the sink. In some cases, there's a separate drain pump that is defective, in other cases, there's a drain solenoid, and in others a drain impeller that's broken or clogged. All depends on the model.
Oct 24, 2017 | GE 24 in. PDW9880LSS Stainless Steel...
GE 24 in. Profile PDW8280JSS Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
