Computers & Internet Logo
Anonymous Posted on Jul 13, 2010
Forgot router password. I set up new OS on laptop and can not connect to my wireless router as is asking me for password which I dont remember. I do connect to the router with another laptop automaticly without problem as password is saved there I assum. Can I recover password somhowe? Also I did have a message "USB devise not recognized" even now with new system on it. What is it about and how can I remove it? Thanks
Anonymous
Level 3:
  • Master 6,487 Answers
  • Posted on Jul 13, 2010
Anonymous
Master
Level 3:
Answers
6487
Questions
6
Helped
1557221
Points
18452
You can recover the wireless password from your router using the computer that is working with it. By typing the routers IP address on a web browser address bar.
So in order for us to provide you the complete details provide us the brand and model of your router.
I forgot my WEP key for my ps3
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop,configure the wireless card in your computer/laptop with the router's wirelesssettings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptopscan communicate with your wireless router.http://www.fixya.com/support/r10267861-network_security_key
2helpful
2answers
I can't conncet to my wireless-G broadband router
you are trying to connect to the wireless network on a new wireless computer.
When you try to connect to the wireless network, it is asking you for the password. That means your You wireless network must be secured
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
I can't remember my password to access my wireless connection to connect another laptop?
You can either:
Connect your computer with a network cable and set the new password for the wireless connection
- or -
Reset the router to the default settings and set new passwords.
Hi I just purchased a HP laptop equiped with WLAN wireless. However it will not allow me to add my wireless connection in order to access the internet. I cannot remember my password to the netgear.
I DON'T HAVE NO IDEA HOW MANY PC IS CONNECT TO THIS NETGEAR ROUTER. IF YOU FORGOT YOUR PASSWORD OR SOMEONE CHANGE THE PASSWORD. YOU MAY RESET THE ROUTER TO FACTORY SETTING BY AT THE BACK OF THE ROUTER THIS A LITTLE HOLE A PAPER CLIP IS THE PERPECT TOOLS TO RESET IT. THE DEFAULT ID USER IS ADMIN AND THE PASSWORD IS PASSWORD. HOPE THAT THIS INFO WILL HELP YOU SOLVE THE FORGOT PASSWORD AND TO CONNECT TO WIRELESS PROBLEM.
HH
Wrt310n adding wireless laptop
If you are using windows xp :
Go to Start>control panel> Network and internet> network connections > right click on wireless network > select 'view available wireless networks' and select your home network and click connect. If it asks for a password i guess u have it or if u dont have then go to Internet Explorerand and type 192.168.1.1 in the address bar, it will ask for a username and a password, type admin as username and the same for password. it will take you to the lynksys page....then select wireless and click wireless security, it will show you the wireless password.......
If u have windows vista :
Click Start > go to 'connect to' > select the wireless network you want to connect to and the rest is the same as windows xp....
Hope this works out
Regards,
Anup
2answers
New laptop want to connect but forgot key
what you want exactly?password for what? username and password for internet in subscriber? or just WEP for wireless key password?
if you forgot the password for username and password for subscriber....theres an option,i dont know what kind of subscriber do you have in your country...if you forgot the username and passowrd you can ask in the subscriber.
regarding in the WEP password for wireless,it doesnt matter,try this..
type 192.168.1.1 in the internet toolbar
username:admin
password:admin
and you can see the configuration,check the wireless settings for WEP...
3answers
Linksys wrt160n wireless router
how can i connect my router so that i can use my laptop
My laptop screwed up and I had to reformat and reload os. When I tried to connect to my router I get to thr point where it asks for"security key or passphrase". AT which time I entered admin for...
Yo! if you dont remember the password try connecting the laptop to the router to access the routers page or you could also do it on the main PC that is physically connected to the router.
go to the setup page of the router normally routers ip would be 192.168.1.1 but not always depends on the manufacturer.
once your on the setuppage of the router try to go to wireless section and wireless security.
on that you can get the wireless key that should work.
Peace.
2helpful
Forgot password
connect to your router by an ethernet cable.
OR
try resetting your wireless router. on the back, there's a small button, usually beside the power connection.
unplug the router, push it with a small pin or paper clip and hold it for 30 seconds.
2answers
New Laptop Connection
Try each of these suggestions 1. username admin, password 1234, 2. username leave blank, password admin BPCS
Grand Canyon Tech
Grand Canyon Tech
