Question about Ovens
Model # ECS2275BK Dacor double ovens I need to know how to take the glass cover off of the light to clean on the inside of each oven?
  • 883 Answers
SOURCE: Kitchenaid Oven
I believe the entire door must be removed first. then remove every screw that you can find and draw a picture where they came from. then split the door open like opening a clam. then you may find additional screws to remove the glass
Posted on Jun 02, 2007
ranger25
  • 72 Answers
SOURCE: glass window cleaning!
You have to remove the inside skin of door, pull door up and off of hinges and lay on floor to make this easier. Then you remove clips or brackets that hold the glass to door and clean. Very simple, but time consuming, mainly lining skin back up on reassembley.
Posted on Jan 27, 2008
SOURCE: AEG COMPETENCE DOUBLE OVEN - 13 year old model
You can look on eBay to buy a used cooker and use it or spare parts
or if its better replace your own.
Posted on Sep 15, 2008
onthejob5130
  • 640 Answers
SOURCE: cleaning between the double glass doors on smeg integrated oven
thats 4 glasses not 2,,you should get a technician,it preety hard taking door apart,,but this is a commend problem..if you want to give it a try .i will talk you thought
Posted on Dec 27, 2008
  • 17 Answers
SOURCE: cleaning between double glass oven door
Without disassembling the door, you can't. the glass is sandwiched between two rather rugged metalized gaskets to create an air pocket (or vent space) to keep the outside glass cooler than the inside.
Posted on Feb 04, 2009
How do I change the bulb inside the cooker of the B5741 cooker
Oven Lighting
Warning: There is a danger of electric shock! Prior to changing
the oven light bulb:
  • Switch off the oven!
  • Disconnect from the electricity supply.
Place a cloth on the oven floor to protect the oven light and glass cover.
Replacing the oven light bulb/cleaning the glass cover
  1. Remove the glass cover by turning it anticlockwise and then clean it.
  2. If necessary:
Replace bulb with a 40 watt, 230 V, 300 °C heat-resistant
oven light bulb.
3. Refit the glass cover.
Dado
Apr 15, 2015 | AEG Ovens
Location of oven sensor
usually located inside the oven near the top left but varies in other models, at bottom, at top, it looks like a tiny thin pc of tube or metal or glass and held by a couple screws
Mar 01, 2015 | Dacor ECD227 Epicure Electric Double Oven
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
I have a Dacor double oven, Model xxxx. I'm replacing the upper element in the upper oven. We removed the old element easily enough, however, because the connections are way back inside the oven, I can't...
Yes if wires have gone through back or hard to access, then remove oven and take off back panel. Always disconnect the appliance from the mains. David The Famous Forry" Call me for help
Oct 20, 2017 | Dacor ECD227 Epicure Electric Double Oven
Display panel works, but oven will not come on
I take it the oven will not heat. there is a safety thermo inside the grilles. it can be reset.. turn the power off at the breaker... remove the grille..inside of the door. then look inside the thermo is has two wires going to it and a red button in the middle.. push the red button down it will reset the thermo with a click... replace grille and restore power... hope it helps.. replace grille
Sep 19, 2009 | Dacor Epicure 30" Double Wall Oven,...
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | GE JTP86 Electric Double Oven
Melted foil in oven
try this take them out if the oven they just unplug in the back soak them in a de greaser with lemon juice really hot water let me know if this works
Dec 04, 2008 | Dacor MCS130 Millennia Electric Single...
Dacor Oven
Depending on your model it is usually at the top behind the "grill" of the oven that is not working. Take out the screws aournd the oven latch (usually for cleaning) and slide out the grill. The limit switch is either over the latch or to the side. If it popped, just put it back with a screw driver. If that is not the issue, then it it could be a bigger issue.
Aug 12, 2008 | Dacor ECD230 Epicure Electric Double Oven
Ovens Logo
23 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
