I have a candy cm1 166. no matter what i do the stop light is consatntly flashing.i have checked the filter and water supplie in and all is ok.
I HAVE A CANDY CM1 166 HOW DO I RESET THE DELAY BUTTON
Posted on Feb 19, 2011
I have a Candy CM126 washer. It will not go into the spin cycle. I have cleaned the filter and checked if the pump is ok. They are fine. However when the machine stops the Activa rinse and 90' lights flash...
It could be the NTC ? two small wires between the heat main wiring. Or Possible the heater is leaking to earth. You would need a meter to test , NTC should be about 18kohm
Sep 15, 2017 | Candy Washing Machines
It won't reset no matter how many times I push the button. The light flashes, stays lit and as soon as it starts to filter the light goes out and it sllllowwwly filters the water.
Check or replace the water filter going to the unit. if ok the controls may be frozen , switch off and defrost this will often cute the fault.
Mar 14, 2016 | Refrigerators
My candy go w475 washing machines stop working, the stop buton flashing all the time, colse the door but still flashing any help plz
clean the filter empty the machine at the drain filter !!!
check for rubbish in the pump viens {power OFF}
kirby grips clothes wires coins etc
perhaps you dont have the manual how to keep it clean
http://www.manualsdir.com/manuals/242947/candy-go-w475-s.html
Dec 04, 2014 | Candy Washing Machines
Candy Grande o, stain vanish and 90 min light flashing
Try to find error codes on the Candy website.
Dec 20, 2013 | Washing Machines
Wash cycle stops and light on the extra dirty symbol lights up
This is might be the drain filter. When the drain filter is clogged, the machine won't empty itself of water.
Candy has a troubleshooting webpage that lists many possible problems/solutions:
http://service.candy-domestic.co.uk/fault-finder/FaultFinder.aspx?Section=11
If you do try to check the filter, keep in mind that opening the drain filter will yield gallons of water on your floor, especially if your machine does not have the drain hose next to the filter opening. You'll need to have some way of transferring the water ready before opening the filter.
Good luck from Detroit, MI.
Jul 18, 2011 | Candy Washing Machines
My Candy C514 Washing Machine stops half way through the cycle and lights flashing.Yesterday mechanic came and checked everything ok Motor, pump and water goes in fine, any idea? What this can be? Many...
first does the water drain in the machine or stays if so it can be your pump that sucks the water out or cloged check, next if its electronical screen it could be screen problem ,or even door lock somtime s pops half way will need to be change ,check step by step,, if helpful plz rate.
Jan 19, 2011 | Candy Washing Machines
I have a candy go c58f and it is stopping after approx 10 secs of starting it's cycle and all the lights are flashing - I have checked the filters and emptied the water
This is a problem of the dryer being too cold. What you need to do is turn it off when all the lights flash (using the dial) then turn it back on again and start the cycle again. Repeat until it keeps going.
This is a real PITA. I spoke to their customer services about it and told me what to do. It seems the sensors in it are not happy in cold weather!
Mine takes 6 to 10 go's in very cold weather. I find it's best to get it warmed up when empty as the hot air gets to the sensors more quickly.
Dec 19, 2010 | Candy Dryers
I have a Candy Grand 8g vented tumble dryer. No matter which programme I put it on, it starts drying for a few seconds, then ALL the lights flash and it stops. I have cleaned the filter and do not know...
Its a wierd coincedence I have the exact same problem this morning,and my identical unit is 6 months old.Misery loves company,I will read the on line fault finder manual for this unit and hopefully find an answer
Regards Quiggers in Ireland
Nov 28, 2010 | Candy CDC266 Dryer
Stop light flashing
i have a candy activa cm1 146. no matter what i do the stop light is always flashing. Ive emptied the machine, turned it off at the mains, checked the waste pipe and currently trying to empty the filter, whilst the light is flashing it will not work on any programs???
Dec 16, 2007 | Candy CN146 Front Load Washer
Washing Machines Logo
338 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
