Question about Tangent Quattro WiFi Internet Radio Wireless Adapter
Tangent Quattro :port 80 connect failed
Hello !
When I try to use my radio I get nework error: port 80 connect failed, unable to load station list.
Connection from my pc to A-link router and to internet works.
I can also see radio connection in A-link's active client list.
I have switched off and then on my radio, but that didn't help.
What might be the problem ?
Best regards
Pekka Lahtinen
How can I get my Tangent Quattro MKII Internet Radio repaired?
I remember answering this question but in case you missed it - Yes it is possible to do so by getting the Digital Encoder connected to the Selection Dial
Jun 23, 2015 | Audio Players & Recorders
Is there any way I can use my tangent quattro with a wireless modem
You will need the ip address of your tangent quattro for that.
then, connect it with your your wireless modem, which is also connected to your pc or laptop.
then enter the ip address of the quattro in your web browser in the laptop.
you will get some settings there.
feed in the dns, gateway and other details for the modem and this should get your quattro working with the wifi.
Mar 10, 2011 | Tangent Quattro WiFi Internet Radio...
[CS Raw] Connecting to connection server port '5050'... [FAILED] *** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0203' ***
Solve this problem
Checking connection servers...
*** 'COMPONENT_TYPE_YCP_EX' YCP EX Error: ('FND.0210', 0, 0) ***
[CS Raw] Connecting to connection server port '80'... [PASSED]
[CS Raw] Sending port check command... [FAILED]
*** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0000' ***
[CS Raw] Connecting to connection server port '23'... [FAILED]
[CS Raw] FAILED
*** 'COMPONENT_TYPE_YCP' YCPError: 'PortSelector::AllPortsFailed' ***
Dec 08, 2010 | Yahoo Messenger
My xbox won't connect to my wireless router
Before connecting the X-box or play station or nintendo WII to the network, Make sure that you have all the wireless settings of the router.
if you don't know the wireless settings , then you will need to open the router set up to find the wireless settings.
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
Trouble connecting to the internet on X-box ,Play station or WII ?
You can try to reduce the MTU settings on the router. if the MTU on the router is set to 1500 then change the MTU to 1365.
Also you will need to open the ports on the router.
For WII port numbers are ==> 28910, 29900, 29901, 29920, 80, 443.
For XBOX port numbers are ==> 53, 80-88, 3074
For Play station port numbers are ==> 80, 443-447 ,5223, 3478-3479, 3658, 10070-10080.
X-BOX
On the x-box you will need to connect to the wireless network now.
Open the main Interface of the X-Box.
1. In the Xbox Dashboard, go to My Xbox and open System Settings.
2. Select Network Settings, Configure Network.
3. On the Basic Settings tab, select your wireless settings.
4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
5. If your network has wireless security, enter your WEP or WPA key.
6. Try to connect to Xbox LIVE again.
Click Here for more info
Jan 02, 2010 | Microsoft Wireless Network Adapter Xbox...
Don't have user manual for Tangent Quattro MkII
This product is quite easy to use and set up, so within a few minutes of switching on, I had successfully connected it to my wireless router and I was able to select internet radio stations and store favourites.
Sound quality from the built in speaker is very good indeed, and the set offers very clear reception on analogue FM as well.
I probably will never use all the facilities this set has to offer, but I have worked out the stuff I need to receive internet radio.
Thank you for following up my query.
Tony
Sep 17, 2009 | Tangent Audio Players & Recorders
Failed to register! error-code: 408, msg: 'Request Timeout'
Errors / Solutions (Error 408, 401, 503 / Not Connecting / Failed to Register / Audio Problems):
You can try using port 8891 or 80 setting if 5060 port is blocked
Simply change the sip.tpad.com settings in Xlite to
sip.tpad.com:8891
or
sip.tpad.com:80
Use our STUN Settings, simply use the info on this link (stun.fwdnet.net:3478)
http://forum.tpad.com/viewtopic.php?t=617
http://www.youtube.com/watch?v=ugHwkl--zhQ
Use these other Free Softphones with Tpad:
http://forum.tpad.com/viewtopic.php?t=623
http://forum.tpad.com/viewtopic.php?t=864
http://forum.tpad.com/viewtopic.php?t=657
http://forum.tpad.com/viewtopic.php?t=456
May 02, 2009 | Computers & Internet
When downloading a system update it fails about 8% and gives the following error: 80710723
This might help
This is what I found.
"80710723
Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ"
you can do this buy
You will have to open ports on your router. You can check the manual or the router manufacturer's web site for help doing this.
Go to the "Settings" icon on your XMB then go to the very bottom "Network Settings". Once there go to "Settings and Connection Status List". It should be the first thing.
any probs let me know
Jan 23, 2009 | Sony Playstation Home
Unable to connect PS3 to my Secured WIreless Router
http://www.askdavetaylor.com/connect_to_the_internet_with_my_sony_psp.html
Jan 17, 2008 | Sony Playstation 3 (PS3) Console
Tangent Quattro WiFi Internet Radio Wireless Adapter Logo
357 people viewed this question
Top Tangent Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Tangent Computer and Internet Expert? Answer questions, earn points and help others
