Question about Icom Mxa 5000 Ais W Real Time Vessel Traffic Information
I have a mxa-5000 icom receiver and i cannot get any connections. It always say no data received. Is it supposed to show right way on my pc if it's properly connected or otherwise. Does the vhf radio has to be to a specific channel or not. It's connected to my vhf radio my gps and my pc. Please help. Thanks Denis
4 Suggested Answers
bigtor1976
  • 21 Answers
SOURCE: icom vhf radio
i have the same unit. i get interferance from my depth finder wire touching the antena wire off the back of the radio. make sure that no wires are touching the antena wire.
Posted on Dec 01, 2008
  • 64 Answers
SOURCE: The VHF radio receives but will not transmit more than
Check the connector on the back of the radio and make sure it is a solder type connector. The connectors that are twisted together never work well. The shield of the coax needs to be soldered to the outside of the connector and the inner portion needs to be soldered to the center.
There also could be a problem with the radio so if that doesn't work I would recommend taking it to a marine electronics dealer for them to test the radio.
Posted on Jun 14, 2010
SOURCE: I have an ICOM-504 . I can transmit but I can not
I had the same problem and traced it to a bad connection between flex cables and boards.It seems the SQL signal from the Rx board is not reaching the processor on the front panel. Check all connections (reseat all cables) and try again.
servstan
Posted on Aug 19, 2010
Fully charged with car charger. Reset to factory. Wont come on when connected to PC. Just flickers.
try not turning it on just connect to pc and see if the system finds a new device as a removable storage device . if it does find it , download the maps to it . LUCK and CHEERS
Sep 01, 2015 | Garmin nuviĀ® 5000 Car GPS Receiver
Wired network problem
First of all are you sure your Internet card is working? there should be 2 lights at the back of your CPU in the Internet port when you connect the RJ45 or Internet cable they suppose to blink to show they receive and sending data. Are you sure you the RJ45 cables are at their right places? you can always identify them by their colors.If you think every is ok with your connection and your modem is sending Internet signal you can always buy an Internet adapter (USB) to resolve your problem.
You are welcome buy with guarantee and no more fear for your pocket
Apr 12, 2014 | Dell OPTIPLEX 745 PC Desktop
In my nokia 6300 phone , phone memory is running when i receiving data via blue tooth. how to change it to memory card?
Hello 000Krishna,
While receiving the data via blue tooth data will store in phone memory always.
If you want to transfer in memory card.
Then connect the phone in computer using the PC suite.
Please download the Nokia PC suite from
http://www.nokia.co.in/support/download-software/nokia-pc-suites
Then transfer your data from phone memory to memory card.
Mar 18, 2011 | Nokia 6300 Cell Phone
On the ICOM M604 will not receive the weather channels, will receive other close radio's.
Hi!
This is almost ALWAYS caused by a problem (a short OR an open) in the coax cable from the VHF radio to the antenna. An easy way to check is to JUST insert the PL-259 connector into the socket of the radio, making sure that ONLY the center pin is making contact with the socket. If the weather channels come in clearly, then it's usually an easy fix. Simply check the connections at each end of the coax, looking for a poor center pin solder connection or perhaps a bit of the ground braid is shorting out the center lead. A magnifying glass is a great tool to spot problems.
If the coax proves NOT to be the problem, then the fault is likely to be in the radio itself and is probably a bad solder connection where the antenna chassis mount attaches to the PC board.
Hope this is helpful.
Good Luck!
Jan 09, 2011 | ICOM Informatique Icom M604 Vhf Marine...
I have an ICOM-504 . I can transmit but I can not receive any chanels even the WX is not receiving
servstan
Aug 09, 2010 | Icom IC M504 Black Submersible PLUS Marine...
Does this unit have a distress signal that a Nema 0183 data cable can attach to
See below:
GPS RECEIVER LEAD
Connects to a GPS receiver for position indication.
• An NMEA0183 ver. 2.0 or 3.01 (sentence formatters RMC, GGA,
GNS, GLL) compatible GPS receiver is required. Ask your dealer
about suitable GPS receivers.
Color code:
Yellow: NMEA IN (+)
Green: NMEA IN ( )
Feb 19, 2010 | Icom M302 VHF Radio
M402 didnt receive the gps signal transmitted by garmin 72 via nmea 2.0
Check the wiring again. Installing my M422 needed to switch the polarity of the NEMA input from my GPS75. May be similar problem
Oct 23, 2009 | ICOM Informatique Icom IC-M402 VHF Marine...
D:\ directory name invalid message
that error message is for the DATA BUS CABLE, you need to buy another DATA BUS CABLE, and verify the right connection contact in the Back of CD and the Main Board for this DATA BUS CABLE
Nov 26, 2008 | Compaq Presario 5000 PC Desktop
Don't have wiring diagram
This was taken from the manual that I have.
Yellow - Serial data 1 output
Green - Serial data 1 input
Red - Batt (+)
White - Serial port Ground
Black - Batt (-)
Grey - Serial port Data output
Jul 15, 2008 | ICOM Informatique GP-270ML GPS Receiver
ICOM GP-360ML GPS Receiver
I had this problem about a year ago. If all you need is the firmware update they will update it at no charge and they told me if it needs repairs they most likely will not have the parts becaus it is a discontinued model. They also said they did checked it and found no other problems. Sent it in to Icom:
Icom America
2380 116th Ave NE
Bellevue WA 98004
They did the firmware update and sent it back to me free of charge. It works great now and my chart cards work great.
Sep 09, 2007 | ICOM Informatique GP-360ML GPS Receiver
Icom Mxa 5000 Ais W Real Time Vessel Traffic Information Logo
Top Icom Boating Experts
Steve
Steve
Fabrice Wolters
Lawrence Oravetz
Are you an Icom Boating Expert? Answer questions, earn points and help others
