Question about Canon Office Equipment & Supplies
Canon LC-41T hand held calculator. After replacing battery I have managed to set the time but cannot determine how to set the date. Fancy my being the one millionth visitor to your site. It was too good to be true! Why is it necessary to agree to terms of use before posting when that is the default on visiting your website.
drknow
  • 44 Answers
SOURCE: set date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Posted on Dec 19, 2007
SOURCE: Cannot set the date on my Canon P23-DH V calcualtor
ok, have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved. do the same for time.
Posted on Feb 05, 2008
SOURCE: Setting time & Date
I copied this from another post & it worked for me:
To enter the date
1. Be sure to switch to "rate set" from GT
2. Enter the month
3. Press the decimal point
4. Enter the day
5. Press the decimal point
6. Enter the year
Example 3.09.2007
7. Press the button that look like a clock/calendar
To enter the time
2. Enter the hour (please use military time)
4. Enter the minutes
Example: 13.24 or 9.24
5. Press the button that look like a clock/calendar
Then change the "rate set" back to the GT setting.
Posted on Mar 24, 2008
SOURCE: EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Posted on Dec 04, 2008
old marine
  • 2122 Answers
SOURCE: set the time and date on a canon mp25dv/instructions
To set date:
1. Press the calendar/clock button (display should show date)
2. Press and hold the 'time set' button for 3 seconds (first digit of the date should flash)
3. Use the numeric keys to enter date using mmddyyyy format
4. Press 'time set' button
To set time:
1. Press the calendar/clock button twice (display should show time)
2. Press and hold the 'time set' button for 3 seconds (first digit of the time should flash)
3. Use the numeric keys to enter time using hhmm format, press 'AM/PM' button as needed
The '12/24' button changes between 12 hour and 24 hour format for time.
The 'format' button changes the date format from mmddyyyy to ddmmyyyy or yyyymmdd.
Posted on Feb 26, 2009
Setting time and date canon electronic calculater lc-64t
With switch in set position hit date. Hit the date button (X) and then enter the year in (4) digits (ie:2013) then hit the (X) button. This will enter the year. Enter the month and day in (4) digits (ex: 0615) and hit the (X) button again. This should set the date for you..ie:6/15/2013!!!!! For time in set position enter time (ex: 346 and hit PM button if afternoon and then press time. This should give you 3:46pm. Hope this helps.
Dec 08, 2012 | Sharp EL-1750PIII Calculator
How do I set the time and date on a canon p170-dh
Press the Date and Time button on the calculator. It is to the right of the Feed button and has a small calendar and clock on it. To set the date, press the button once to display the factory supplied date and hold down the Equal ( = ) button that is two buttons below Date and Time until the screen flashes. Input the correct date. Ex: August 20, 2010 would be entered on the numerical keyboard of the calculator at 08202010. When finished, hold the Equal button again. Do the same for the time.
To sum it up:
Press Date and Time button
Hold = button until blinks
Enter date or time
Hold = button again until blinking stops
Aug 03, 2010 | Canon P170-DH Calculator
How do you set the date and time?
1) press calendar clock button
2) hold the time and date button for 3 seconds, this button is marked with "Time and Date" one the keypad and not on the button itself
3) The date or time should start blinking
4) make inputs of current date and time
5) press Time and Date button again to save changes
6) All set!
Anytime you want to display the date or time hit the clock and calendar button. The calc will hold the display until u switch to the calculation mode i.e. by pressing the CE/C button.
DUHHHHHHHH!!! All these instructions are in the piddly sheet Canon calls the manual.
Dec 28, 2009 | Canon MP-25DV Calculator
I don't have the manual for my canon p23-dhv calculator. How so you set the date?
Hold down the time set key (M+ key) for 3 seconds. Then hit the date/time key. Enter in the correct date. Hit the time set key again to set. To set the time hit the date/time key twice to bring up the time.
Hope this helps.
Oct 30, 2009 | Canon P23-DHV Calculator
How do I change the time on my Canon LC-3175?
Open all 3 One-touch Speed Dialling panels.
press Data Registration. press Set.
USER SETTINGS press Set
DATE & TIME press Set
use numeric keypad to enter month/date/year and then time press Set
To exit, press Data Registration or Stop
Jun 11, 2009 | Canon LC-3175 Laser Fax
Set the time and date on a canon mp25dv/instructions
To set date:
To set time:
Feb 26, 2009 | Canon MP-25DV Calculator
Canon MP11DX
press the date/time button
press and hold the = button
once blinking set the date
press the = button again
once blinking set the time
the "x" button changes A / P
press the + button again
Feb 29, 2008 | Canon LS-100TS Calculator
Overflow won't clear
Look for the reset button, then remove the batteries - this should fix it.
Oct 22, 2005 | Canon P23-DHV Calculator
93 people viewed this question
old marine
old marine
