My fisher and paykel machine wont do the spin cycle it is only 3 yr old
  • 1 more comment
  • maskdesigns Jun 29, 2008
    I have the same problem. Mine is only two-three years old and just decided not to go into spin mode anymore. I have checked that there isnt anything clogged and the machine is aligned ok. Its been in the same spot since it was installed and I have never had any problem with it. It goes through the whole wash thing but when it comes to the spin cycle just makes a noise like "its trying" and nothing more. I have turned it off at the switch and re-set it all. took agitator out and made sure there was nothing stuck anywhere. All looks good. If it is a malfunction I'm NOT happy!!
  • tdcoach Aug 25, 2008
    won't empty or spin
  • Ljubomir Vucinic
    Ljubomir Vucinic May 11, 2010
    Does it goes properly trough all the cycles before the spin cycle?
    Problem Solver:
  • 12 Answers
Probably a plugged pump, if not maybe the ccu.
Posted on Sep 14, 2009
Model gw 712. Why are lights 3, 5, 7, and 8 flashing?
Hotpoint, GE, RCA Washer Repair - Does not spin or drain ...
? 6:13
https://www.youtube.com/watch?v=69az-ZA3eSQ
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Hotpoint, GE, RCA Washer Repair - Does not spin or drain - VWSR4150DAWW ... Fisher & Paykel ... my washer won't drainnor spin. what is the problem? .... But in the end, this video helped me fix our washing machine.
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesHow do I remove the lid on a F&P intuitive eco washing machine to get to the motor panel?? IMadeIt ... It runs until the spin cycle and it drains but won't spin.
Dec 18, 2015 | Fisher and Paykel Washing Machines
Fisher Paykel washer spin issue
lift the front of the machine and set on blocks about 3"
reach under to back to the blak flexable pipe and squeeze several times to loosen hair soap gunk eccetera.
start mahine on rinse cyle
it should start to drain on its own
Jul 18, 2010 | Fisher Paykel EcoSmart GWL15
My Fisher and Paykel Smart Drive 501 toploading machine won't finish its cycle...it always gets stuck on the spin cycle and starts beeping. This happens every time not just occasionally. How can i fix...
need to have a look at the machine, how old is the machine 15 years roughly, Yes this is when the machine plays up, hard to find spare parts. If you are getting rid of the machine let me know. 0412676652 Since I want to learn fixing the machine, I did fix one of this model long time ago
Jul 01, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel Ecosmart (about 6-7 years old. Spin
better get e a new one, it is most likely the bearing , can u see small amounts of water under the machine, if u want to take the top off all there r is 2 screws under 2 D shaped covers under the lid towards the front of the machine ,,,,wont help , but it also cud be a wire in the drain pump
Jan 28, 2010 | Fisher Paykel EcoSmart GWL15
The rinse and spin cycles never end
I have seen this often on another brand. Once it starts malfunctioning on the rince/spin cycle, the boars needs replacement.
Nov 13, 2009 | Fisher Paykel EcoSmart GWL15
Our Fisher & Paykel Washing Machine is not spinning. It gets to the spin cycle and sits there counting down. The fault code eventually said Service fault 37. What does that mean?
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
Sep 29, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
I have a 1.5 yr old Fisher Paykel ecosmart washing machine. During the past 2 loads there has been a notable water leak (significant puddling on the floor). I haven't witnessed the problem, but there is...
the play in the tub in normal, it sounds like you have an over sudsing issue, run an empty load with 3 cups of vinager in the tub, set the water temp to hot, cut way down on soap, if you use liquid dont even fill the cup 1/3 of the way, I know this sounds dumb but try it, I have one and this happened to me
Jul 10, 2009 | Fisher and Paykel Washing Machines
On our Fisher and Paykel, the spin cycle does not
ok guest you can set a fisher and paykel machine to skip one rince cycle so as to save water,
Feb 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
At spin cycle pump only runs for 3 seconds then stops
Sounds like the pump motor is overheating. Probably need a new one.
Feb 18, 2008 | Fisher and Paykel Fisher & Paykel Washer
My fisher paykel eco smart is GWL11 not GWL15
Press "end of cycle" for 5 seconds or more to clear the screen. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
117 people viewed this question
Top Washing Machines Experts
