Hampton Bay 5200 BTU window AC cycling on and off frequently
Hampton Bay 5200 BTU window air conditioner cycling on and off very frequently. We use it upstairs for our child and it runs great when first turned on and cooling down the room. The problem is trying to maintain the temp. It will run for anywhere from seconds to a few minutes and then turn off for a few seconds or minutes. It has even turned on for seconds, turned off and then turned back on before the fan finished spinning. This is all with the energy saver mode. If set at 73, it is as if the unit is shutting down at 73.9 and turning back on at 74....that is how much it cycles on and off. Thanks for any help/tips
  • 3422 Answers
SOURCE: air conditioner window unit {Hampton Bay}
You can get the parts from the below sites:
www.searspartsdirect.com
www.partstore.com
If you need anymore help let me know.Please don't forget to rate or accept the previous premium solution.
Posted on Jun 22, 2008
  • 15 Answers
SOURCE: Air conditioner is not cooling. The fan is running. When I turn the thermostat past 7, the unit shuts down. Any ideas? Low on Freon?
Sounds like a leak to me - if you have a set of guages available (know anyone working in the refrigeration field???) you could tell this for certain.  Otherwise, try running it when it cools down outside and see what happens.  Take a stick thermometer, and put it in between the fins on the INSIDE condenser coil.  If they get cooler, but not down to about 50 degrees, then you are low on refrigerant.
Good Luck!
Posted on May 26, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Energy Saver setting
Could not find a manual, but that setting is the setting that you choose to leave on and let the air conditioner decide the most effecient way to run during the day. There are too many ways to approach that answer in a small conversation. There are many things to consider and I will leave you with a link to a PDF that explains better of what I am writing. Sea Breeze
http://oee.nrcan.gc.ca/Publications/equipment/pdfs/ac-directory-2006.pdf
http://servicepartstec.blogspot.com/
Posted on Jun 20, 2009
taran_2005
  • 10515 Answers
SOURCE: My Hampton Bay 12,000 btu A/C when used for the
This means that it's a time to change "COMPRESSOR".
Hope i helped you.
Thanks for using "Fixya".
Posted on Jun 23, 2009
  • 534 Answers
SOURCE: I have a model HBT120A Hampton Bay window unit
Usually this type a/c has a 5000 btu rating
Hope this helps
Dave
Posted on Aug 10, 2009
I have a Hampton Bay AC. It is 18,000 BTU. It is 230 volts. The EER is 9.7 and it is 8.3 to 9 amps. When I use energy mode on the AC it blows warm air. What gives? Just cool mode and it blows cool.
Hi Paul,
  • Energy Saver Mode most likely shutdown the compressor and Fan Only will be running to recirculate Ambient air into the room.
  • Make sure there is no Port or Vent that is open on your unit and would let hot air from outside be mixed in with the ambient air especially if it is hot outside.
  • Also refer to the troubleshooting section of your owner's manual.
Good Luck,
JP
Jun 21, 2015 | Hampton Bay Heating & Cooling
I have a hampton bay air conditioner model hblg5200e. how many btus is this air conditioner>
5,200 btu's which is equal to 4.33 tons
Please give me a rating as I need them to get in FixYa's good graces.
Aug 03, 2011 | Hampton Bay Heating & Cooling
What does the "dry mode" mean in a Hampton Bay air
"dry mode" normally means, to dehumidify only. this will not cool the air nor heat it consistently.
Jun 19, 2011 | Heating & Cooling
The "dry mode" dehumidifies the air. This is useful when you do not need to cool the air but the relative humidity is higher than you want to have inside. You get the advantage of bringing in the fresh air without increasing the indoor humidity.
I hope this helps.
(this applies to all air conditioners with a dry mode)
Jun 19, 2011 | Hampton Bay HBLG5004 Air Conditioner
Air conditioner window unit {Hampton Bay}
www.partstore.com
Jun 22, 2008 | Heating & Cooling
Find fan blade exhaust
Do a google search under the company name
Jun 09, 2008 | Hampton Bay HBLG5004 Air Conditioner
BTU
There should be a tag somewhere on it. Take the front grill off and look in the area where the fan blows out the grill face or below the evap coil face where your filter covers the coil
May 14, 2008 | Hampton Bay Heating & Cooling
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
