Question about Whirlpool LEB6300 Electric Dryer
Dryer suddenly stopped working and won't start again!
  • 1,998 Answers
First check that u have power going into the machine from the cord. Next would require you to be able to use a multimeter so that u can test the run fuse and the hi and low fuse also make sure that the door switch is functioning properly if the door switch is broken the machine will not turn on on most whirlpools the run switch is located behind the back panel it is a small reqtangluar fuse located above the blower u can remove the fuse with a 1/4" socket if u wish to test to see if the fuse is fuctioning simply connect ur multimeter to both sides and measure continuity between the two sides if there is no continuity this is your problem these fuses are notorious for breaking when there is a back up of lint in your vent hose so also make sure u dont have an obsruction inthe dyer vent hose hope this helps
Posted on Jul 13, 2010
    President:
  • 1,382 Answers
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Thank you!
The dryer was drying, and suddenly stopped and control panel says call technician. Then says door open, won`t start after unplugging to reset it. The inside light stopped working at that time.
It may have overheated. Wait a couple of hours and try again. If it still doesn't work you will need an engineer to diagnose the problem. As it went out during a cycle it could be high limit thermostat or high limit cut out. Both are available on eBay and Amazon. Those parts fail if the dryer gets too hot caused by bad airflow, clogged filters, exhaust pipe or stuck vent slats outside.
Mar 16, 2016 | Frigidaire Fasg7073Lw 7.0 Cu Ft Steam Gas...
Whirlpool heavy duty 5cycle 3 temp dryer won't turn on suddenly stopped..no sound whatsoever..changed heating element and still not on
Check your thermal limiter . It should look like a white bar about a inch long . You can find it on the blower housing
Feb 17, 2013 | Whirlpool Dryers
My zanussi dryer has been working for four years and now its suddenly stopped. I tried cleaning the condenser which didn't work.How will i get it in proper condition again?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 19, 2011 | Zanussi ZDC37100W Electric Dryer
Dryer appears to 'overheat'...starts a load but stops before finishing then won't start again for hours...
Test air flow. Remove the exhaust hose at the rear of the dryer, run the dryer and form an opinion on the volume of air flow, hook the hose back up, turn on dryer again and verify that the same volume of air exits the building. Usually a build up is the cause of your complaint.
May 13, 2011 | Kenmore Dryers
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
LG Gas dryer will not keep heating
sounds like the heat sensor on side of heater pan is bad and needs to be replaced ,,, its mounted on side of pan the flame blows into and has 2 wires plugged onto it / larry
Dec 12, 2008 | LG DLG5932W Gas Dryer
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Jan 27, 2008 | Kenmore 659 Electric Dryer
Hoover condenser hdc 6
this could be the thermostat has gone but most likeley its the copasitator that makes the machine start and stop and change directions if the machine runs and cannot change directions this will cause the thermostat to glow red WARNING THIS MAY CAUSE A FIRE
Dec 06, 2007 | Hoover HDC6 Electric Dryer
Dryer only starts sporadically
your headed in the right direction. there are contacts inside the timer that have gone bad. the timer is in the console ofcourse. its not hard to replace and replacing it will solve your problem
Nov 25, 2007 | Whirlpool LEB6300 Electric Dryer
Whirlpool LEB6300 Electric Dryer Logo
347 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
