Air conditioning only runs on high and does not work on switchs 1-2-3 but works on switch 4
  • 1,940 Answers
Either the switch for the A/C fan is bad or the blower motor resistor is bad. The most likely of the two is the blower motor resistor, it is typically found behind the glove box near the blower motor:
Air conditioning only runs on high and does not - moz-screenshot-4.png51de5bb.gif
Here is a picture of a Air conditioning only runs on high and does not - b05be71.jpgMotor Resistor:
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on Jul 13, 2010
Where is the air conditioning sensor located ?
1 What are you working on?
2 Which of several sensors do you mean? Low pressure switch? High pressure limit switch?
3 Temperature control sensor?
4 Other?
Jul 06, 2015 | Cars & Trucks
Air condition and heat won't work
Check to see if you are getting voltage to the blower motor if you are the motor is bad if not check the fan speed switch. 1 2 3 or low medium high if you get voltage going to the switch but not from replace the switch if you have voltage from switch check the blower motor resistor the although with the blower resistor you commonly have a high fan speed in the max setting and the lower speed settings don't work wich would make you think 1 2 3 are not working but 4 is. That is why it is best to check all parts to make sure the part you do replace needed to be replaced
Oct 15, 2012 | 2000 Ford Focus
04 Saturn vue compressor turns off when fan is set to 3 or 4
The problem is the blower motor speed control resistor, it is located near the blower motor in the housing. I exchanged mine and it works like a charm now.
May 31, 2012 | 2002 Saturn VUE
Daytime running light
[Information] For a 2002 Toyota Camry, the Daytime Running Lights (DRL) operate utilizing the High Beams (inner Lamps closer to the center of the vehicle front) at a reduced power.
[The troubleshooting process:] Review the Owner's Manual and ensure the test configuration matches the following criteria:
1. According to the 2002 Toyota Camry Owner's Manual (Check your Owners Manual):
"The DRL system will make your headlights come on at a reduced brightness when:
The light switch s in the "DRL" position.
The ignition is on with the engine running.
The headlight switch is off.
The parking brake is released."
2. Set the Test Conditions according to Step 1 above.
3. Check the headlight bulbs to ensure they are not burned out. If one burns out, there is a fair chance that the other would have burned out at the same time. Replace as necessary. In this case, if the high beams operate, the DRLs should also operate.
4. Test the system, ensuring the step 1 conditions are set. (Engine running, Multi-function Switch on Turn Signals in "DRL" position, headlight switch off (repeating what the manual says -- it should be obvious that in the "DRL" position, the headlight switch should be off / do not have the switch positioned to "High Beam"), and the Parking Brake "off").
5. If DRL lights do not work, check the engine compartment Fuse and Relay Box. there is a 5 Amp DRL fuse -- replace it with the spare. Test (step 4).
6. If it does not work, swap around or replace relays -- there are three (3). Any one of them could be bad (stuck or burned out). Test (step 4).
7. Other less likely possible issues could be that the Multi-function Switch is broken or a connection / wire is broken. [Beyond the scope of this process.]
My problem was that the test configuration did not have the engine running and parking brake off - Step 1. Problem solved with much thought, repetitive tests on the vehicle and going back to the basics -- what does the Owner's Manual say and where are the applicable fuses and relays located?
Dec 30, 2011 | 2002 Toyota Camry
Daytime Running Lights Inoperative 2002 Toyota Camry
I have a Coleman/Evcon furnace model #DGU08016UB that has a concern. In my attempt to check my furnace before we need it for the winter; the following condition occurred. Condition: Flashing code of...
jump out pressure switch see if it lights check hose to pressure switch see if they are split or connections are not good ,cut off ends and put back on presure switch.
Sep 21, 2011 | Coleman Heating & Cooling
My rv air wont work on high?
could be the selector switch turn off power switch low and high wire if it blows high replace selector switch if it does not work replace motor. Tom
Jun 13, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner doesn't work
problems yes low high and high low are usually caused by faulty defective clutch coil or defective thermostat...electrical issues can be cycling switch pressure switches ambient air sensor or fin switch ( evap temp sensor)
Mechanically it could be clutch,or compressor the symptoms are not good... srry hit me back if you got some manual gauges and wanna run pressure test diagnostics..
May 08, 2009 | 1997 Infiniti.5 J30
1994 Hyundai Excel Air conditioning RADIATOR´S FAN works always very fast
this not really a problem as the fan speed is controlled by the high preasure switch in the ac system the hotter it is outside the higher the preassure will be in the system as hot as its been the preasure is high already when the compressor cycles it pulls suction on one side and outputs high preasure on the other the fans cool the condenser the higher the ambient temp the faster they go so all is fine...
Jun 08, 2008 | 1994 Hyundai Excel
"high" vs "low" dual control
could be problem with either switch of fan. try continuity across both legs of the switch then try continuity across the fan windings.
May 25, 2007 | Fedders X Chassis A3X05F2B Air Conditioner
Heating & Cooling Logo
109 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
