WHIRLPOOL MODEL LSR6132BW1 WILL NOT PUMP OUT WATER
Whirlpool model LSR6132BW1 clothes washer sounds like the pump is pumping but water will not drai ... I am pretty sure it is just clogged... Have children that like to help but leave all manner of things in their pockets... How do you get the clog out from between the two tubs?
  • 1,998 Answers
This is quite the messy job so be prepared for some water to leak out if this is your first time remove the cover of the machine look down the bottom of the front of the machine there willbe a motor infront of the motor there is a white, or grey plastic piece with two hoses on it. this is the washer pump remove the two clips onthe top and the bottom o the pump then ull notice the two hoses when u remove the clamps that are on each of these water will come out of the hoses it might be better to empty the inside of the machine with a shop vac first try using a small bowl under each of the hoses while having the shop vac trned on as u remove the hose clamp after you remove each hose check to see if there is any debirs in the line finally inspect the inside of the pump to make sure no debirs is taped inside if the inside f th pump is not moving you willhae to buy a new one you can order one of these and have it directly mailed to you from marcone hope this helps
Posted on Jul 13, 2010
I have a whirlpool washer model WTW4800XQ1. It spins but doesn't drain. I taken apart all hoses...no clog. The water will drain through the pump when the unit is unplugged. Is there a way
it sounds like the pump does the water run out when the outlet pipe is laid flat on the floor or below the machine's height level? if so then the pump will need to be checked out
Nov 10, 2014 | Washing Machines
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Clothes still soaked after spin
sounds like the pump is clogged up, Take pump off and clean.
Nov 29, 2011 | Whirlpool LSR8433K Top Load Washer
I have a frontload whirlpool washer and the water will not drai n out. I have clean the filter but it wil still not drain
hello, Chances are there is something in the pump and usually it will break off the impeller. You might have to install a new pump. Try unhooking the pump hoses and put the unit in drain and see if the impeller is turning or damaged before buying a new pump. please dont forget to rate me..Thank You..
Jun 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washer agitates but will not pump out the water. I thought the timer switch assembly was bad so I replaced it. Still no water pump. I can not find the Model Number tag on the washer...
Drain Pump Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
Aug 03, 2017 | Whirlpool LSQ9520L Top Load Washer
My dishwasher doesn't clean my dishes anymore and sometimes it doesnt dry them. it is a quiet partner 1 and it is about 2 years old.
It sounds like the water pump on the dish washer has gone out. A dish washer works (much like a clothes washer) by filling up the washer with a set amount of water, then through circulation, pumps the water up through the various spray nozzels. If the water pump is worn and not making enough pressure, the spray won't get the job done. Depending upon make/model, it may be cheaper to replace the water pump.
Run an empty dishwasher load with a bowl of white vinegar on the bottom shelf. As the dishwasher runs the cycle, the vinegar is slowly disbursed and cleans the dishwasher.
Mar 02, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool model SM 8525079 fills with water but will not agitate or spin
If you have motor sounds after water fill,but no agitation or spin it could be a broken direct drive coupling. If it will not pump out water,there could be something stuck in the drain pump.
Jan 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Clothes are dripping wet when I take them out of the washer?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Irt sounds as if your pump is somewhat blocked.
See the following for how to remove the cabinet and check the pump for blockage and/or a problem between the pump and motor.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=2edbaee16223b0927cee89fcc394964e
Dec 22, 2009 | Kenmore 22422 Top Load Washer
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
My whirlpool washer goes to the last spin cycle but does not drain the water
Jul 10, 2008 | Whirlpool Washing Machines
Washing Machines Logo
Top Washing Machines Experts
