Question about Samsung LN32A550 32 in. LCD TV
Tv turns off under 15 mins from being on. then black screen but yet the audio is still there
  • 11,361 Answers
You either lost the 24vdc power supply section that supply the power to the backlight inverter board, or he inverter board had shorted out.
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 13, 2010
Tv goes black and can still hear sound, then it will shut off, then turn back on. will repeat after 5 mins
Hey iterry,
I have the same TV with what seems to be the same problem (screen off, audio remains until turning off->on); posted in several places (including here) but yet to receive a conclusive advice.
Please check the following:
- Does the screen turn off exactly 5 min. later - or when high brightness frames come up (could be 1...2...15 min. into the run;you can check that by pausing on a dark frame for a while)?
- Try altering the set to 4:3, low definition (did mine through my UVerse menus) as well as manually reducing the brightness settings; see if this gives you longer screen activity (I often manage for several hours, until some stupid commercial has a few seconds of a bright-white screen).
If we are indeed both in the same boat, my findings thus far are:
This is not a lamp issue (changed, no difference); not a color wheel issue (changed a couple of months before this ****); probably not a temperature issue - though I'm still checking that.
I'm hoping it's the ballast; will soon check and LYK. Good luck.
Nov 04, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
RCA 32V550T Posessed
This tv is know to have circuits burn out
If you still have the warranty, use it
Otherwise a repair will cost about $150
580-634-0151 support number for rca
If you need anything else, please ask, thank you and I hope you fix your problem
Mar 27, 2008 | RCA 32V550T 32" TV
Plays for 10-15 min.then pic.goes black,sounds stays on.
Resolder FBT pinns flyback transfomer on deflection board also CK capacitors 3 of them cp114,120,150 if anmy of them is puffewd up on top it is bad.cp150 2200uf 16v other 2 are 220uf 35v replace all 3.
Jan 28, 2009 | RCA R52WH73 Projection Television
Picture for 1 second then screen goes blank but still have audio
i have taken the tv to repair shop a circut board has went on it
Dec 30, 2008 | JVC LT-32E479 LCD TV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Still posessed!
These tv does have loose of audio problems im concern about looseing picture . Try unplugging tv for 5 minutes it will reset tv very common fix for audio. Tv that are less then a year old are sometimes covered under new warr call manufacture on that.
There is a microprocessor on these that lockup and when you unplug it. it resets it.
I have a tv shop and have helped customers get exchanges under a year especially if you complain
good luck i hpe i helped Thanks DOCTOR VIDEO
Dec 31, 2007 | RCA 32V550T 32" TV
Flashing light
this unit will have what is called ik protection wich means that the picture tubes are constantly monitor with this system all the way to the video procesor so the picture will desapear to a black screen even if the audio is ok,there may be a solution if contract a tech like me to adjust the bias so that compensates the drives to the pictures tubes since 1 or the 3 pt are week at this point.
Dec 25, 2007 | Sony KP61XBR200 TV
Samsung LN32A550 32 in. LCD TV Logo
87 people viewed this question
Jerry Greenberg
Jerry Greenberg
