Question about Toshiba e-Studio 350 Copier
Toshiba estudio35 trouble code
I have a toshiba estudio35 copier appearing a code of "call for service 1571324" and a F11 code.
Please help me fix my problem, could you send service manual of teach me how to cancel it.
Thank you very much...
Try 08-600 sub code of 2. This is a reanitilazation of the HDD it may help you out. If it errors and does't tell you to reboot then your hdd is shot. after this code you will lose all fax presets and templates stored on machine. also just try a reboot.
Posted on Apr 24, 2008
  • Toshiba Master
  • 647 Answers
U need to update firmwares, if failed. then probably need to change board...
Posted on Sep 17, 2009
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } I have a Toshiba Photocopier Model 2030 it have a code 43. Please solve my problem.
thanks
Munir Khan
PK.
Posted on Jun 29, 2008
Error code C440
Toshiba eStudio 355/455 Full Service Manual - Tradebit.com
https://www.tradebit.com/.../155135538-toshiba-estudio-355-455-full-se...
Download Toshiba eStudio 355/455 Full Service Manual ... Configuring DepartmentCodes Configuring ... TSB-1013: C440 Error - Countermeasure .... DIG-ACC-145: MJ-1025 Bracket Change to Enable Installation on e-STUDIO205L/255/305
Aug 08, 2015 | Toshiba E-Studio 305 Digital Copier
Problem with code F11 on Estudio 311c - aspanner
[F11] Communications error between system-CPU and scanner-CPU
This quite often can be cleared up by resetting the machine. If not you will want to check all of the connections between the scanner, the scanner board and the system boards in the back of the machine. If nothing is loose this is likely a very critical error and you will need to have a toshiba authorized technician take a look at your copier.
Sep 08, 2010 | Toshiba COPIERS - E-STUDIO 311C Copier
Service problem giving code F11 on estudio 311
Have a Toshiba E-Studio 350 in the field, and just lost our Toshiba tech. Copier is showing a wrench. Any recommendations?
Wrench appear in the LCD touch screens mean "call for service". It will freeze the copier from operating until the problem is fixed.
There will be an error code appear when you press "CLEAR" and "3" button at the same time. The error code should appear next to the wrench icon you mentioned.
It is recommendable to get an experience tech to solve the problem for you.
Jan 19, 2010 | Toshiba Estudio 200L Copier
I have 2 problems with my toshiba 550. service code CD3 and SPC
The CD3 error is related to the recycled toner unit. the recycled toner is backed up/clogged.
Toshiba made a parts change to the design of the recycle toner unit by replacing a bushing with a roller bearing and a seal. depending on how old your copier is it may or may not have this modification. The copier firmware/software also needs to be updated to the most current version and along with that there are a few internal settings that need to be adjusted.
If you are unable to do any of the above then try this - (it will get rid of the problem short term) clean/vacuum out the toner recycle unit.
If you open the front cover of the copier you will a white plastic pipe sitting at about a 45 degree angle (below the toner cartridge) - this is the pipe that leads to the recycle unit on the right. The whole unit needs to be removed and taken apart and cleaned, inside and out, including the pipe.
The SPC code is related to this issue and should also go away.
Hope this helps.
Mar 31, 2009 | Toshiba E-STUDIO 550 Copier
I have a toshiba estudio35 copier I CANAT INSTALL IP\TCP IN MY MACHIN
Apr 20, 2008 | Toshiba e-Studio 350 Copier
Toshiba E-Studio 160
When the message call for service is displayed
press the C key and the 8 key at the same time
an alpha numeric code will appear eg: C47 etc
Post the error code and I'll tell you what it means
Jan 19, 2008 | Toshiba E-Studio 160 All-In-One Laser...
Toshiba e-Studio 350 Copier Logo
430 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
