Question about Fuji FinePix F10 Digital Camera
Port on camera
Where is port to plug in camera to download to computer?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 241 Answers
On the left side of the camera, seen from the back. The socket is for the terminal adaptor. You connect the USB cable to the terminal adaptor.
Posted on Jul 13, 2010
I need a usb port and a download disk
You don't need either.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Feb 22, 2013 | Kodak EasyShare C182 Digital Camera
Memory card is full but when try to download to computer says no pictures
Buy a memory card adapter that plugs into the usb port of your cumputer. turn off the camera (important) before removing the memory card. Place the card into the adapter and plug the adapter into the computer's usb port and download the pictures into the computer. You MUST turn off the camera before removing or replacing the card to avoid ruining the card.
Dec 25, 2012 | Fuji FinePix S700 Digital Camera
Downloading pictures to my computer though a USB port
Try NOT connecting your camera to your computer.
Dec 24, 2011 | Casio EXILIM Card EX-S770 Digital Camera
I plug the camera into the usb port my computer bings but i cannot load picturs ti the computer. I used rthe finpix loading disc but nothing will go to my compuert
You will need to check your manual for download instructions not all cameras are the same however, if you have the camera software installed try following this work flow.
First make sure your camera has enough power to complete the download, turn off the camera plug the USB cable into the USB port on the computer then the mini USB on the camera. If you have been turning the camera on this may be part of the problem a lot of cameras use the playback button to transfer pictures from the camera to the computer.
Diagram of play back button
Mar 04, 2011 | Fuji FinePix A850 Digital Camera
I can take digital photos that are on the sd card but I am not able to get my pc to download or reconise the Canon Powershot. I can not download photos! It used to go into download mode as soon as I...
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jun 21, 2010 | Canon PowerShot S1 IS Digital Camera
Why can't import my pictures into the computer?
Have you downloaded the Kodak Easyshare software? It will be easier to transfer picture from the camera to the computer also easyshare software has feature to enchance picture download not to mention that you can send picture thru email using the esayshare software. To download the software visit www.kodak.com/go/easysharesw.
Transferring pictures/videos with the USB cable
Turn off the camera.
2 Plug the labeled end of the USB cable into the USB port on your computer.
3 Plug the other end of the USB cable into the USB port on the camera.
4 Turn on the camera.
Note: EasyShare software opens on your computer. The software prompts you through the transfer process.
If still having issue importing picture from the camera to the computer call Kodak support line at 1 800 235 6325 (23KODAK)
Nov 20, 2009 | Kodak EasyShare Z730 Digital Camera
USB cables
make sure you plug the small plug on your usb cable into your camera...easy..
the big plug on your usb cable must be plugged into your usb port on your computer. It can only fit in one way and not upside down. It will also fit into your network port, but this not correct port. If your usb plug fits into the port the right way up, and upside down, then it is the wrong port. If your computer is old, then it may not have a usb port.
Oct 08, 2008 | Cameras
Are you saying that you turn your camera on and the lens emerges, and then you plug in a live (5volts DC) USB cable, and the lens retracts? If this is the case, then that sounds fairly normal. Your camera has turned itself off in response to you hot plugging the cable. You only need to turn your camera back on. The lens probably doesn't emerge because the camera is in download mode, not shooting mode. In this case there is nothing wrong with your camera, and therefore nothing to fix. If you have tried all this, and your computer still cannot see the camera, try plugging the camera in to other USB ports on your computer. You should have between 4 and 8 to try. Also make sure the plugs and ports are all clean on bothe the computer and the camera. Another thing you can do Lizzie is to get a USB card reader (SD or multi or whatever card your camera uses) for $2 Reject Shop to $10 most camera shops. You put your camera card into the card reader and then plug in the card reader. MOST IMPORTANT! Make sure your camera is off when removing the card, and use the SAFELY REMOVE HARDWARE icon when removing your card from your computer.
May 05, 2008 | Casio Exilim EX-S500 Digital Camera
Disney Pix Max 3.0 Megapixel Camera by Digital Blue can't download photos
If you're plugging the camera into a port on the front of your computer try one of the ports on the back. The front ports in most cases only provide 100 milli-amps of power whereas the back ports provide the full 500 milli-amps of power. This could be the problem or it could be your USB cable. Try a different cable and see if that makes a difference. Just make sure that you aren't plugging it into a USB hub and you're connecting it directly to a port in your computer.
Mar 05, 2008 | Disney Pix Max Digital Camera
Fuji FinePix F10 Digital Camera Logo
26 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
