Question about Freezers
We hahe a delfield 384-p this unit will cool down to 0 on the gauge on the unit but actual temp is 13 degrees how can we get this unit to cool down to 0 degrees
mrgreenz
  • 962 Answers
SOURCE: cooling system
maybe the ECM got deprogrammed. did you disconnect the battery / if you did disconnect the battery negative terminal and leave it for a few minutes the re install it. It should reprogram the computer Module.If not check you coolant level or themostat.
Posted on Nov 16, 2008
mosthated357
  • 91 Answers
SOURCE: 4.3 liter won't gain temp, why?
The chevy blazers are known fior heater core issues clogged going bad etc... The reason im saying this is because the only reason i could see you having a problem with the temp not getting hot enough is because then your heat in your car isnt getting hot or its taking super long to get luke warm, is that correct? If so 9 times out of 10 its a bad heater core...
Thanks,
Steve
Posted on Jan 19, 2009
  • 33 Answers
SOURCE: cooling fan will not come on
you need to remove the connector at the fans and then take a jumper wire from batt. positive to one terminal of the connector and then a grounded jumper wire to the other...Do the fans come on? if not your fans are bad...If they do you might try a coolent temp sensor
Posted on Mar 28, 2009
  • 83 Answers
SOURCE: Sta Rite Sr333na Max E Therm Pool & Spa Heater gauge stuck?
Anytime the heater is reading the water temp to be above what it actually is, especially 126, the problem is the Thermistor, or Temp Sensor, for the heater. This is a very easy part to replace. The Thermistor is located on the manifold, on the left side, between the top two bolts.
Sorry this is a late response! Hope that it helps!
Posted on Jul 10, 2009
  • 233 Answers
SOURCE: 13 degree Delta T
I assume r-22 refrigerant by the pressure... you have a saturate temperature of approximately 41 degree and 71 degrees at the service port this equates to a 30 degree superheat. a condenser saturation temperature of 105 degrees and since the liquid line temp at the service valve is not given only the enterin indoor coil on the liquid line a 96 degree temperature this would equate to a subcooling temperatureof about nine degrees. You have too high of a superheat reading. verify that the bulb for the txv is correctly positioned and insulated. if it is then you need to remove the bulb from the suction line, hold it in your hand to warm it up and see if the superheat changes. you could also have issues with your ductwork. If the supply temperture is around 50-55 degrees then the unit is doing all it can.. Check the txv and the ductwork as the subcooling indicates that the condenser side is doing it's job, but the superheat readings indicate that you are starving the evaporator..
Posted on Jul 28, 2009
What is the suction pressure low side and high side charging 404a refigerant cooling temperature
evap temps usuall run 10-15 degrees below the box temp.This a generally accepted rule of thumb.
Sep 15, 2014 | Delfield Freezers
Is it possible for a delfield freezer 6151 XL-S to trip a breaker every 2-3 hours if the TXV valve was faulty letting liquid get to compressor. This unit has had controller and relay start assembly...
I would look to see if it is tripping during the defrost cycle. One of the heater elements my be faulty. Never heard of a bad TXV causing a breaker tripping, but I guess it's possible. I would adjust the superheat so that it is about 6 to 8 degrees just prior to unit reaching temp and shutting off. I'd start there.
Apr 01, 2011 | Delfield Freezer 6151XLSR Stainless steel
Delfield MD # 6151 - S Sr # 206156-T not pulling down to Temp set at -10 and only pulling down to 24 freon is good
Take the top cover off that is next to the compressor,. That cover is about 30 by 30 inches. You will see two fans and an evaporator coil. Several things can happen. First these fans won't come on until the coil is somewhere around 10 degrees or if the door is open. So, once the freezer has been running look under the big cover and be sure both fans are running. If one or both are not running it won't pull down to 0. Also look at the coils and see how much frost has accumulated. If your defrost timer is not working it may be frozen over. When that happens air is blocked from reaching the inside of the freezer. While you are at it, fell of the coils if they are only partially freezing, you may be low on freon. If you have gauges to check the freon charge, check both the high side and the low side pressures. If the high side is less than 200 psi, you have some freon, but maybe not enough. If the high side pressure is 300 psi, you have something blocking the freon from returning to the compressor. Usually a blocked cap tube or a malfuncting expansion valve. Finally check the condenser coils which is the radiator thing out where the compressor is located. If it clogged with dust and grease, it will not dissapate the heat from the freon and will intefere with the operation of the entire unit. Clogged condener coils are probably the number one cause of burned out compressors. Good luck.
Sep 17, 2010 | Delfield 113.28 cu. ft. Commercial Freezer...
CAN'T GET EVAPORATOR FAN TO COME ON & TEMPERTURE TO DROP.
Several possibilities. The fan won't come on until the coil inside the box on top of the freezer gets down to about 0 degrees. It also will not come on if the door is open. It sometimes takes 10 to 15 minutes to come on. If you are low on refrigerant (freon) the coil will not get cold enough to come on at all. Feel the coil on the outside of the freezer on top and see if it is very warm to the touch. If not you are probably low on refrigerant. If you have the electronic control system, it may not be sending the signal to the fans after a defrost cycle. If possible, put gauges on the valves to check your freon charge. If this unit has not been operational in a while, you might try flipping the top cover off the coils and turn the fans by hand a couple of revolutions. I have had them to seize up from not being used. The fans should turn freely.
Aug 31, 2010 | Delfield Freezer 6125XL-S
Not cooling
make sure the compressor and all the fans are running. With the condenser at the top of the unit, you will be able to see the condenser fan and you should be able to hear and feel the compressor running.
Check for the evaporator coil frozen up and not allowing adequate airflow. If it is frozen up, you will need to have it checked out as to why.
Just because the compressor was replaced doesn't mean the freezer was fixed properly. Have it checked out just to be safe. But in the meantime, you can do the checks yourself to hopefully gain more understanding of what is going on.
Jun 07, 2010 | Delfield 113.28 cu. ft. Commercial Freezer...
Temperature display reading 32 degrees on delfield 6000 xl freezer unit. Should be set for 0. door has been opened one time this morning. Where is display box to check troubleshooting codes located on...
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 16, 2010 | Delfield Freezer Series 6000XL Remote Half...
Need run pressures
You have to give more info. What refrigerant, where is the unit located so ambient temps can be considered, is there a cap tube or txv.
http://www.delfield.com/docs/uploaded/del/manuals/DM6000XL.pdf
Try this web site from Delfield. It should be you manual. It says your unit has 404-A. Check it out and let me know if you need more info.
Dec 16, 2009 | Delfield Freezer 6125XL-S
Delfied Freezer6000XL freezing temps are not hold
Sounds like a refrigerant restriction in the system. Recover the refrigerant, replace the filter drier and pull a deep vacuum on the system before recgarging.
Mar 21, 2009 | Delfield Freezer 6151XLSR Stainless steel
The unit begins a defrost cycle without warning
in general, a freezer will go into a defrost cycle about every 6 hours and usually from 25 to 40 minutes. After the defrost, the unit should function normal. Pull down to temp and cycle off. If the product shows signs of thawing, then I would be concerned about the box temp. Defrost may be too long or some other issue may be effecting it. Otherwise, if no signs of thawing, I wouldn't be too concerned. It's the product condition that is the concern.
Nov 12, 2008 | Delfield 37.96 cu. ft. Commercial Freezer...
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Freezers Logo
111 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
