Question about Whirlpool AWM5125/1 Front Load Washer
Whirlpool AWM 5100, When spinning, sounds like a marble is bouncing around between metal and plastic drum. Have taken off drain outlet from bottom of tub and cleaned out lint debris but didn't find large loose debris, nor stop noise when reassembled, although did seem reduced. Any ideas?
  • 1 more comment
  • Handichick Jul 15, 2010
    Thanks for your advice diddydoddy. My model is a 5100 and I am unable to remove the element easily. However, while shining a torch and rotating the barrel I could identify that one of the prongs holding the element down had bent upward and was catching on the barrel seam at each rotation. I could not imagine any way to access this without disassembling the "entire" unit (looks like a bomb has gone off in my laundry)I hope there wasn't a more simple solution as I couldn't find any other access point- advice to others-you will need help with heavy lifting!!! (and used digital camera to ensure everything goes back where it came from..) I am still in the middle of this ..adventure.. but am confident it was the problem. I will post final result when I'm finished!
    Other advice to others- I had a long running prob with stopping, jamming, speeding through etc during cycles and was going to get a new timing switch but nearly every time there was something jammed in the drain/pump outlet. Now I have located the drain at base of tank and discovered how much debris was stuck in there waiting to block the pump outlet I expect my timer problem will disappear. I believe the cycle progress is very dependent on the pump being clear! Always check it first!
    Thanks again diddydoddy, and good luck to all.
  • Handichick Jul 18, 2010
    (somehow this enquiry went elsewhere so I don't know how well my 'cut and paste' will work!)
    hi diddydoddy, further to my prob with banging in drum of whirlpool front loader AWM 5100, I am wondering if the clip which holds the element is absolutely necessary? It is simply a piece of hardened bent wire. one edge had somehow bent out of shape and was hitting the folded seam of the metal inner barrel each time it rotated. I don't understand how this could have happened, and since I had to completely disassemble the machine to reach it, I would hate to find it somehow bends out again. It was very difficult to reshape back into the correct shape, and is still very slightly lopsided. The element appears to be very securely in place, so does the clip actually do anything? What do you think? Many thanks, Handichick
  • Handichick Jul 19, 2010
    I can't thank you enough for your clear concise assistance! You are a gem. If only all the 'experts' were as expert as you. Thanks again. :-)
  • 269 Answers
Try removing the heating element and also the sump hose you removed the first time then see if the object can then be dislodged.You may have to shine a torch in by the element whilst turning the drum slowly and see if anything shows up.
Hope this solves it.
Posted on Jul 13, 2010
  • Christopher Dowling Jul 18, 2010
    Hello Again,
    The clip you mention keeps the heating element in position and to stop it rubbing against the drum which could cause an electrical fault if it wore through to the inside of the element.If you have managed to reshape it back to its near original shape,well done.The normal reason for this to occur in the first place is debris/lint or the like getting through to the inside of the drum and wrapping around the element but it seems as if you are winning.
    Thanks for your payment and positive feedback it all helps.
    Good luck Chris.
My dryer is making a sound as though there is loose change bouncing around in the drum. what could this be?
Zippers and metal buttons, like on jeans, will sound like that when tumbling against ss drum. Experienced the same with mine.
Sep 21, 2014 | Whirlpool Dryers
During spin cycle, washing machine is bouncing around the room
Sounds like the drum, balance weights have come off, to me. This will cause those symptoms.
Feb 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
MY Whirlpool AA1400 5145 I had remove bottom drain and there is some blocking then I don't know whow comes first the ball or the rubber. Regards, OA
Hi
I hope I understood your question properly.
When you take off the drum drain pipe, you have a plastic ball and plastic ring inside the cup shaped hose which fits on the bottom of the drum.
When putting it back on, first put the plastic ring inside the cup-shaped hose. Then put the plastic ball on top of it.
Secure the hose to the bottom of the drum with the metal clamp. Make sure it is on correctly and will not pull off.
Also make sure there are no kinks in the hose leading to your drain filter.
Start a quick cycle and monitor the machine to make sure there are no leaks.
Best Regards
Ash
Nov 15, 2009 | Whirlpool AWM5145/2 Front Load Washer
Awm 5125 front load womt spin
Check the agitator(the big plastic piece in the center)you can remove the cap in the top and there will be a bolt that holds it on,remove the bolt and see if the plastic gears are worn out.
Please rate this solution
Jan 20, 2009 | Whirlpool AWM5125/1 Front Load Washer
Awm 5125 front load
I had the same problem tonight!! I opened the filter at the front and found one of my baby sons socks and 81 cents!
The machine is draining away perfectly now, but the floor got soaked when I opened it, so be prepared.
Hope this helps...
Jan 17, 2009 | Whirlpool AWM5125/1 Front Load Washer
Whirlpool washer AWM 5145/5 water wont drain/stops on B
I had same problem twice, the first time there was a sock in the filter at the front adjoining the pump, the second time a sock had got in the pipe under the drum which is more awkward to get to but is possible if you have the tools to remove the back plate and are ok at diy, there is a spring tension clip on the pipe which comes off quite easily with a pair of pliers.
Jan 14, 2009 | Whirlpool AWM5145/2 Front Load Washer
Whirlpool Washing Machine AWM 029 is not draining
Hi.
I assume you have checked to see if the pump is working,
Select drain and spin, if water does not go away, then you have a pump problem, which will stop the programme completing.
Please leave feedback.
Thanks
Nov 25, 2008 | Whirlpool Washing Machines
Washing machine does not drain out when cycle ended, water left in drum, there is a filter bottom front only opens slightly to release some water, should this be able to be taken out to clean it
Most washing machines are based on the same principles: there is an inner drum with holes around the entire drum walls, this is where you place your clothes. This drum sits inside of another drum that has a drain hole at the bottom of it that connects to a pump motor. When the machine is in spin cycle it uses centrifugal force to remove the water from the clothes and it escapes the interior drum via the holes and is captured by the drum with the drain in it. The pump motor has an impeller which may be made of plastic or metal which often fails resulting in the issue you have described. Depending on your make and model it may be possible to replace the impeller itself or you may have to replace the entire pump.While most are easy fixes they are labor consuming. Cleaning of the filter in front of the machine will be of little consequence to resolve the issue. I hope this assists you and thanks for using Fix Ya. Please let me know if I can be of anymore assistance.
Oct 16, 2008 | Home
Drum outlet hose assembly
Hi trevor it is just a eco ball it is not needed it will cause you more problems when it is in the machine dont worry just leave it out
Aug 01, 2008 | Whirlpool AWM8103/1 Front Load Washer
Sounds like there is a marble or coin in drum
remove the heater which is held by 1 19mm nut in the centre and prize out carefully with a screwdriver. you can then see the gap between the drum and the tub and fish out whatever is in there. a common problem
Jul 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM5125/1 Front Load Washer Logo
356 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
