Question about HP Officejet 5610 All-In-One InkJet Printer
Printer is showing "error: 0xf0af0001 Reset Power". I have unplugged and then plugged in printer multiple times and printer comes ok for about 30 seconds and then the same error message appears will all led lights flashing.
Last month i had same problem and i contacted customer care and i got this solution. And this works.
Step 1:
Perform a partial reset.
A partial reset returns the user settings to the factory defaults. The language and country/region settings may also be deleted.
Please perform the partial reset using the following steps:
a. Unplug the power cord from the all-in-one.
b. Press and hold the "#" and 3 button on the front panel keypad.
c. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one begins to initialize.
If the issue persists, follow Step 2.
Step 2:
Perform a semi-full reset.
b. Press and hold the "#" and 6 button on the front panel keypad.
Posted on Aug 02, 2010
  • cgakareem Sep 03, 2011
    i have followed the two steps u sujested. but the prblem existing as it was.
Display reports: Problems in inksystem. Error no: 0xc18a0306 What do i do?
error detecting ink volume and will need to be cleared by resetting your printer. here are the two ways to reset it.
Reset to default setting
1. While your printer is on, unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys."Enter Special Key Combo" will be displayed.
3. Press "1", "2" and "3" to display Support.
4 Press ">" right arrow button and release when System Config Menu appear, then click OK
5. Press arrow key to display Hardware Failure Status, click OK.
6. When Hardware Failure Status:Clear appeared, press "OK" to clear.
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".
9. The last part is to turn off the printer and unplug at the back, wait for 30 sec, then plug and turn on the printer, if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print
Don't forget to rate this answer.
Thank you for using Fixya.
May 26, 2011 | HP Photosmart 3210 Printer
HP1610 Allin one model. Serial no. MY52ED41WI Scanner only shows half, the other half is black. Can you help please?
Try hard reset .
Unplug the power cord of printer for 30 minutes . This will reset the printer .
Plug back the power cord to printer .
If your problem is not solved check the cartridge .
Oct 26, 2008 | HP Office Equipment & Supplies
Error:oxc18a0401??
Hi There,
These are reset instructions designed to clear most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to proceed..After this try to print...
If you find the reset solutions helpful...Please rate this solution and vote YES ..thanks..
Nov 04, 2010 | HP Photosmart 3210 Printer
I turn the HP C7280 printer on, the buttons in the front panel start flashing and the LCD goes blank, then this is one of several error codes that comes up on a blue colour LCD. The other error codes...
Hi
Please on the following link to troubleshoot the issue
Follow the steps upto step number 6
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01369982&cc=us&lc=en&dlc=en&product=3204785&tmp_track_link=ot_search
If the issue is still the same then follow the following step to resolve it
1. Press * # together followed by 1,2,3 in sequence..
2.The printer will show the support menu
3.Press the right arrow key to go to the reset menu
4.Press ok on reset menu and go to semiful reset and press ok
If the screen doesn't respond to do this step then you can also perform this step with the following method
1. Take all the ink cartridges and printheads out and keep them out
2. Unplug the power cord from the back of the printer
3. While the printer is unplugged, press and hold # & 6 together on the printer
4. Hold them for 30 seconds and then plug the power cord in the printer while holding the buttons
5. Release the buttons after 6 secs of plugging the power cord
6. Then the printer would as you to select the language and location
7. It would ask you to insert the cartridges and printheads, please insert it..
8. Then printer would do it normal procedure like it does when you use the printer for the first time
9. This particular step would reset the printer back to the factory settings
Hope it would resolve the issue
All the best!!
Oct 29, 2010 | Office Equipment & Supplies
What does error oxc18a0106 mean?? I have replaced all the ink cartridges this afternoon and still won't print
Full reset
Sep 11, 2010 | HP Photosmart 3210 Printer
How do I fix Error:Oxc18s0301 Ink system failed.
Try using these two reset instruction...these clears most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
Full reset
If you find the reset solutions helpful to you...Please rate this solution and vote on this on the YES below..thanks..
Aug 20, 2010 | HP Photosmart C6280 Printer
Error: Oxc18a0401
here.. check this out. a solution to your problem.
Semi reset
Full reset
Aug 16, 2010 | HP Photosmart 3210 All-In-One InkJet...
0xc18a0001
Semi reset
Full reset
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to procede..After this try to print...
Jun 02, 2010 | HP Photosmart 3210 Printer
Error Code 83C00029 with Clock display
Try to reset the printer by unplugging the power cord without turning off the product and wait for 30 seconds. After that try to press and hold the power button for 5 seconds. Then press and hold the pound "#" key and the number 6 key on the number pad for faxing at the same time while plugging in the power cord. Release both buttons when you are prompted on the display like "Semi-full NVRAM reset". It would reset the printer to its factory settings
Aug 21, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
346 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
