Question about Brother LS-1217 Mechanical Sewing Machine
Loops of loose thread on bobbin side of fabric Brother PE 700 II machine
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
dizzythevamp
  • 9 Answers
SOURCE: lost my manual for my Brother CS-100-
Here is a site for the manual. Just click get manual, register for free on the site, then download it. It works great!
Posted on Jan 05, 2009
louislevel_2
  • 374 Answers
SOURCE: Thread looping on top and bottom of fabric
hi! there,
on this condition,you can avoid wasting time and material try on this, the problem is your set up of tension thats why.,but you should follow upper theading. see figure,c978815.jpgthis just sample of exact threading,next bobbins set up see fig.the thread should be clockwise rotation on winder5a00a72.jpgfollow this set up,and upon inserting be sure
you have clean feed dogs and shuttle race free from fabrics and threads chips.set dial tension to #3 to #4 and stitch dial to #12.then try this set.and you can watch on you tube sewing. try this stuff on internet address type www.youtube.com then on search box type sewing machine,have enjoy and have a nice day.don't forget to rate me,
Posted on Apr 14, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
sburtenshaw1
  • 5 Answers
SOURCE: Shirring fabric?
When putting your shirring elastic on the bobbin, don't thread the elastic through the bobbin holder,adjust the stitch length longer,and loosen the tension, other wise if you want to put it through the bobbin holder you have to loosen the tension screw on the bobbin holder, and then you have to adjust it back for ordinary sewing,
Posted on Feb 13, 2010
How do I fix the thread tension on the bobbin side. The thread is looping
Adjusting the bobbin tension should be the last thing to try. Usually, if the machine is working properly, the upper tension should be the main form of tension adjustment. If the upper thread is looping under the fabric, the upper thread is too loose.
Oct 21, 2016 | Sewing Machines
Back side of stitches are loose
increase the thread tension of the needle thread
this is an indication that the tension is not enough to pull the bobbin thread up tight
Jun 15, 2016 | Sewing Machines
Upper thread looping around bobbin
make sure your needle is positioned correctly? not too high and not too low.
Jan 10, 2014 | Brother Sewing Machines
Tension is loose underside
Loops appear on the surface (top side) of the fabric?
Reduce the tension by turning the upper tension control dial to a lower number. If the loops still appear on the surface of the fabric after you adjust the upper tension, the bobbin thread may be too loose. In this case, turn the screw clockwise, being careful not to over-tighten the screw, approximately 30-45 degrees to increase bobbin tension. After you adjust the bobbin thread, adjust the upper thread to match the bobbin thread.
Make sure you reset before your next project.
Apr 26, 2013 | Brother LS-2125 Mechanical Sewing Machine
Brother PE 180 D WILL NOT PULL UP BOBBIN THREAD
change the needle--make sure it's the right one for the fabric being
sewed
rethread the top thread make sure to use every thread guide
also make sure the bobbin is inserted correctly into the bobbin
case
also make sure it bobbin is wound correctly, that it's not warp
it's also possible that the machine could be out of time
Jul 22, 2012 | Brother LS-2125 Mechanical Sewing Machine
Feed dog doesn't move material through, huge thread loops on under side of fabric. I put a new needle on machine, no luck there as far as the loops.
Check the tension of the feed foot. Some machines have an adjustable tension for the foot pressure. If this is not the case then re-check your thread tension setting. As well clean the bobbin area of loose threads and dirt. You can adjust the bobbin thread tension on the side of the bobbin holder(small screw). From the sounds of your dilemna the bobbin tension may be the culprit. The housing does come out with either 2 screws, or clips. Try that. Wayne
Mar 24, 2010 | Sewing Machines
I get loops on top and/or bottom of fabric during sewing. I have tried to adjust upper thread tension without any success. On brother website it is said that it might be lower tension or incorrect bobbin...
Top tension back to 4 and leave the bobbin tension as is.
Make sure you have a new needle for the type of fabric being sewn installed with the flat side to the back of the machine. A bent needle can sometimes go unnoticed.
Always thread the machine with the presser foot up and this will give proper tension to the stitch.
Check the manual to be sure you are threading correctly (always with the presser foot up) and that the bobbin thread is feeding in the correct direction from the bobbin spool and through the guides.
Take hold of the thread at the needle as you lower and raise the needle to pull up the bobbin thread. Take both thread ends under the presser foot and to the back of the machine.
Mar 11, 2010 | Brother LS-2125 Mechanical Sewing Machine
Looping thread bottom side of fabric
That means you have not routed the bobbin thread properly, or bobbin has not been filled properly. Could also mean your tension is incorrect.
Feb 14, 2010 | Brother Sewing Machines
I have a brother sewing machine but all the patterns come out with the bobbin thread showing
When you pull gently on the thread from the bobbin area, do you feel slight resistance? There should be resistance but it should not be tight. If the bobbin thread is in the bobbin case tension area properly and there is no resistance then you need to tighten the screw on the bobbin case to increase the tension on the thread. Do not tighten the top thread tension. To get to the bobbin tension screw on the case, some models require that you remove the needle plate and then the bobbin case. Some have a hole in the front housing that allows you to reach the screw without taking off the needle plate. Also make sure you're hooping the fabric tightly. When you snap the fabric when it's hooped, it should make a drum like sound. If the fabric is loose in the hoop, bad stitching will result
Nov 09, 2009 | Brother Disney PE-400D Computerized Sewing...
Brother PE 400 D threading bobbin problems
im going to help you as much as i can,,,,try using a bobbin that is already threaded and make sure bobbin is in bobbin case correctly, make sure machine is threaded to instructions in book,,,if this is all done exactly u should not have a problem unless something is jammed
Jan 20, 2008 | Brother Disney PE-400D Computerized Sewing...
Brother LS-1217 Mechanical Sewing Machine Logo
56 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
