Question about Sharp AQUOS LC-52LE700 LCD TV
Sharp Aquos incompatiable audio signal, check output device set
Hello, I have a Sharp Aquos TV which is hooked to a cable box via a HDMI cable. I can see the picture but hear no sound. And a Error box said: incompatiable audio signal received, check output device setting. I have no idea what to do. Any help is appreciated!
  • Sharp Master
  • 12,061 Answers
Often you must also use the RED & WHITE Audio Cables. With the HDMI. cable.
It goes from the Cable Box, to the TV, Via the appropriate cables, using HDMI, also use the OUTPUT RED & WHITE Audio connectors and cables, wire color to color. Select EXTERNAL HDMI INPUT on the TV, to be able to see and hear TV. Also there are two controls now for the volume, both the remote for the Cable Box, also the TV's volume as well. set on the TV to a High setting, and control the actual Volume.
http://www.retrevo.com/support/Sharp-LC-52E77UN-TVs-manual/id/23457ag122/t/2/
Above is a guide that will show you how to connect up.
Posted on Jul 13, 2010
  • stephanieche Jul 13, 2010
    Well it was orginally working with only the HDMI cable, then my boyfriend unplugged the cable box, and plugged it back in and now we dont have sound.
No video from AV1 channel connected to a Toshiba DVD player via Component to Sharp Aquos TV via HDMI. Audio is fine via Optical cable.
Usually you cannot mix and match sources and outputs. In other words, if you're using component to connect from DVD player to a receiver, you have to also use component to connect from receiver to TV. Input and output MUST be the same - both HDMI or both Component.
Apr 19, 2015 | Sharp Audio Players & Recorders
My Sharp LC-32SB24U says An incompatiable video signal has been recieved. Check the output device settings?
It sounds like an HDMI lead has standard video on it or the output from a digital unit is not the correct specification for your TV.
Check the instruction booklet for recomended signal sources and then check your DVD, Video, Computer for the right type of signals to be outputed to your TV.
Hope this helps.
Oct 29, 2010 | Sharp LC-32SB24U 32 in. LCD TV
No audio, no video but program guide displays
1. You should check you cabling connections at the satellite receiver to the TV.
2. Check the mode you are in on the HDMI cable
3. Your HDMI should have 3 modes in the set up screen (HDMI 1,2,3)
Apr 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Incompatible video signal has been recieved
I just had the same problem and it turned out to be the HDMI cable.
Apr 08, 2009 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Sound problem with Sharp LC-32D4U
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Mar 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Digital Audio Output on TV
When using HDMI as the source, the Dolby Digital data will NOT be passed through. If you switch your cable box or satelitte receiver to PCM audio it will pass that through.
Jan 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Connection problem
The best hook up for this unit is to use the hdmi if your samsung box offers hdmi output. The panasonic vcr should be hooked to any one of the composit video inputs with the yellow video cable and the red and white audio cables. If the vcr does not have composite output then use a rf (coax cable) to antenna a input and put the tv on channel 3 or 4 as vcr is set for.
Jan 13, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Analog RCA input to HDMI output?
You have said the correct thing HDMI is digital therefore Analog will not pass.
You might have RCA audio outputs on your cable box so either send them into the TV from cable or into the AMP then use AMP volume to listen to TV audio (select unused input and remember it is for TV) the key is to remember that cable box will drive the initial vol so raise or lower cable vol then use AMP vol to obtain desired volume.
Nov 29, 2007 | Onkyo TX-SR605 Receiver
Receiver won't put out sound to LCD Sharp aquos
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
Nov 12, 2007 | Onkyo TX-SR803 Receiver
Sharp AQUOS LC-52LE700 LCD TV Logo
560 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
