Question about LG DBRH197H DVD Player/HDD Recorder
LG RH7823W - Timer recorded audio out of sync
When I manually record a program using the internal tuner on the LG RH7823W to the HDD - no problem. When I use the timer to record automatically, the audio is out of sync with the video by about 1.5 seconds behind.
  • gooblian Apr 27, 2008
    I have exactly the same issue only when timer recording
Try this site reportedly the fix is here
http://mybroadband.co.za/vb/showthread.php?t=24182&page=6
Posted on Aug 05, 2008
It will not timer-record some channels such as Channel 5-2 and 9-2. I can manually record on those channels, but when I try to record using timer programming, it won't record those channels.
If Toshiba offered you a refund due to the alleged bug, I doubt that there is a work around to the problem. If it had been a regular tuner I would have suggested that you scan all the channels to commit them to memory.
The problem basically is that those channels re not in the recorder's tuner memory. You can enter them manually but when you try to use the programming the unit will not do it since channels are not in memory. Check your manual to see if there is a provision for getting channels into the memory of the unit. Don't hold your breath.
Sep 10, 2015 | Toshiba DVR670/DVR670KU DVD/VHS Recorder...
TV/VCR Recording of TV Programs Using a Digital Converter Box
Hi Rick
I think you are painting yourself into a corner. So to Speak.
Why buy a SetTop Box to convert to an old VHS Tape when you can buy a Digital Recorder for probably the same price.
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
  1. Main Features:
    DVB-T Twin Digital Turners
    DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
    2.5" Sata Hard disk: 500GB
    Time Shift Function (Pause live TV)
    HDMI Digital Output
    Digital Audio Output
    CVBS/YPbPr/SPDIF connectors
    Supports TV formats 4:3 and 16:9
    Electronic Program Guide (EPG) up to 7 days in advance
    EPG searching and auto download
    Recorded program edit
    Parental Control
    Copy files from internal HDD to external HDD
    Built-in WiFi
    Network Playback
    USB 2.0 Interface
Now
This was my original reply until I saw the light.
So, Hopefully one of these will answer your queerie.
A digital TV picks up the new Digital Transmission and stores it in memory, then supplies the high definition to the input of your TV.
With a STB, once the digital broadcast signal is captured by the Set Top Box tuner, it is stored in memory and then it is converted to Video Format and comes out of the back connectors as a standard video & audio signal on the Red & White (Audio) & Yellow (Video) as a composite signal that can also be attached to an older VCR tape recorder.
If the STB output connectors have a Red White & Yellow RCA plugs then it is all ready to be picked up by an older TV or VCR.
Most set top boxes also have HDMI Output for high definition video & sound in the one cable, which attaches directly to the back of your TV (assuming it doesn't already have a tuner (STB) already built in).
HDMI is the state of the art cabling for modern devices. But probably not on the old VCR.
It will either use Component, Composite or SVideo cables. Match one of these cable standards up with your VCR.
Cheers.... Trevor
Was this Helpful
.......Then give me a tick of approval
Aug 18, 2014 | Panasonic PV-V4022 VHS VCR
Flashing red cassete light mean
So.... Who uses a VCR any more. They are ancient history.
They don't last forever so perhaps it's time to think ahead....
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. I got him a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Main Features:
HDMI Digital Output
Parental Control
Built-in WiFi
Network Playback
USB 2.0 Interface
Cheers
Good Luck
Maybe you can get a little more life out of that VCR still
Aug 15, 2014 | Toshiba W522 4-Head Hi-Fi VCR
Problems recording on LG RHT49H HDD
There may be plenty of space in the HDD but you can only set a certain number of timers. Delete a less important timer setting to make room.
May 05, 2014 | Televison & Video
Can't use timer setting to record Foxtel on LG RH397D
Are you trying to use video plus?try manual setting and in the channel space put av1
Sep 21, 2009 | Televison & Video
Problem dubbing from HDD to DVD+R (LG RH7823W)
Received no proposed solution, Is this the service I can expect from fixya,com?
Jun 16, 2009 | LG DBRH197H DVD Player/HDD Recorder
My LG LRH-880 HDD/DVD recorder sometimes stops recording by itself, before the end of the programming and even if there is enough disk space left.
Somehow, my HDD/DVD recorder recorded correctly 2 times last night, even if I did not do anything specific to fix. I will keep an eye on new occurences of this problem, but it appears at the moment that the issue disappeared by itself.
Sep 13, 2008 | LG Televison & Video
Timer recorder n/w
the recorder must be off, otherwise timed recording doesn't work
Aug 29, 2008 | LG RH177 DVD Recorder/HDD Recorder
I have a lg dvd recorder model RH7823W. I have recorded something onto HDD and i want to burn it onto a DVD.
If you read the instructions, it's under "Dubbing" - Page 51. The one thing the printed manual fails to tell you is that you need to "finalise" the disc if you want to play it on any other player apart from another RH7823W - DOH! See page 23.
Mar 11, 2008 | LG DBRH197H DVD Player/HDD Recorder
DVD er Help
Device Manager information and help Display adapters, Displays each of the video cards installed and/or detected by Windows. DVD/CD-ROM drives, Included in Microsoft Windows 2000 and Windows
Good Luck/Please dont for get to Vote.Thank You.
Dec 15, 2007 | LG DBRH197H DVD Player/HDD Recorder
LG DBRH197H DVD Player/HDD Recorder Logo
350 people viewed this question
Computer Repairing
Computer Repairing
