Question about Panasonic Lumix DMC-FS5 Digital Camera
LENS WON'T FULLY RETRACT ERROR MESSAGE SAYING TURN OFF AND ON AGAIN
    President:
  • 1,382 Answers
If you've recently dropped the camera you may have lens damage that is causing the camera to shut down. If you haven't dropped it, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try solution before you do anything else:
Step1: Remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper).
Step2: Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced.
Step3: Remove the lens from the camera. Put the body cap on the camera, and put the rear lens cap on the back of the lens. Make sure you are in a clean environment.
Step 4: Take the rear cap off the lens and use the blower to blow large pieces of dust off the lens. Go around the entire rear part of the lens with the blower.
Step 5: Dip the swab in the iso propyl alcohol or cleaning solution. You should use only a light amount; the best way to ensure this is to wear light vinyl gloves, like those used by health care providers, and squeeze the swab with your fingers after dipping it in the solution. Gently clean the contacts on the lens with the swab. After you have done so, use the blower on the lens contacts again.
Step 6: Repeat the procedure on the contacts on the camera body.
Step 7: Reattach the lens to the camera and test it to see if the error or focusing problems still exist. If they do, try cleaning the contacts again.
Thank you!!
Posted on Jul 13, 2010
If i on the camera the lens won't work properly and message that turn off the camera and turn on again
Hi there:
If the camera has recently been dropped it may have lens damage that is preventing it from powering up. There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
Additional details could find in this article link: fixing-lens-error-on-digital-camera.html
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 22, 2012 | Sony Cyber-shot DSC-W170 Digital Camera
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
Lens error message
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
Jul 18, 2009 | Canon PowerShot SD1100 IS Digital Camera
Lens error message on nikon coolpix L18 I purchased my Nikon L18 Cool Pix camera last September ('08). Last week when I turned it on, the lens extended fully, then retracted fully as I got a "lens error"...
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
May 01, 2009 | Nikon COOLPIX L18 Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Coolpix lens opens retracts opens then closes again and lens error appears
Hello
When you turn the camera on the lens comes out and has parameters when extending to focus, if the lens does not open fully it sees a problem and then closes.
there are tiny plastic gears inside and may have chipped or a piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Aug 26, 2008 | Nikon Coolpix L11 Digital Camera
Dsc w7
While turning in off softely press the lense in and out a couple of times. The lense would retract. If not fully, but most of the way, push the lense a little harder in until completely retract. If you turn it on, I should work fine. The reason the lense does not retract is most likely some dust in there somewhere. If it did not help, you would have to open the lense and clean it and close the lense.
I hope it helps,
Jul 13, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
Lens extended can't take pictures
The only thing not functioning was the lens I could turn on off see menus etc but could not take a picture and the lens would not retract - My husband cleaned the battery terminals on battery & in camera -IT WORKED !!!! good as new -
Apr 06, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
"lens error" on casio ex-z3
Sorry to say but a lens error actually is a problem that you cannot fix at home. When a lens error occurs, the motors inside that make the lens retract and protract were some how damaged, usually caused if the lens try coming out when you have it in your pocket or against a surface so it cant fully come out. You will have to send the camera in for service and you can do that by calling 1-800-706-2534, option 1.
Oct 19, 2006 | Casio Exilim EX-Z3 Digital Camera
Panasonic Lumix DMC-FS5 Digital Camera Logo
188 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
