Question about Motorola Computers & Internet
I have a motorola i776w nextel handset and i forgot the unit unlock code to the device the code is a six digit code and is not allowing me to access the main menu or make or receive calls
    Guru:
  • 551 Answers
Have you tried 123456? If this will not work, try calling the Motorola. They will give the code to reset your unit.
Posted on Jul 13, 2010
I have a nextel ic902 and a nextel i335 how come the sims are not interchangeable
First you need to unlock your phone after that you can use this sim .It is so simple to Unlock your Motorola .go this site order your Motorola Imei Unlock Code and get your imei unlock code.
this site is offer best price.and guide you to how to enter your Motorola Imei Unlock Code.
customer support is excellent. i hope this site will help you alot.
Feb 13, 2012 | Motorola Mobility ic902 Cellular Phone
I own an i730 Motorola. Bought it a few years ago when I was with Southern Linc. I have never used it for anything other than the walkie-talkie. My Nextel i710 Motorola transmit button stopped working...
Hi, Welcome to FixYa
This document is also available in PDF format (this PDF has higher qualify images and a password and is not free. It requires purchase, with your purchase, you will receive the HEX file for Raptor Pro that's mentioned in this web page) for easier viewing and printing.
RSS Carrier + iDENPro
Phone Power: On
i-DEN phones are made by Motorola. They use SIM cards and look like GSM phones, but they are not GSM. The most popular iDEN network in the US is Nextel (now with Sprint) and Boost (owned by Nextel)
For most i-Den phones, use the RSS Carrier to put the phone RSS-SIM mode. Then use iDEN Pro.
It is recommended that you use the USB cable for Motorola iDEN phone when using RSS carrier and iDEN pro. Pay attention, the iDEN cable is very similar to the Motorola V600 cable, but a bit wider. So be careful not to confuse them.
RSS Carrier is useful for reading either the six-digit or four-digit phone or user security code. However, the actual unlocking of the Service Provider lock is done with iDEN Pro software.
Once you connected the phone, some times it will prompt you to install the driver, just follow the instruction and install it automatically. If it does not work, try to manually install the driver from the directory, which the Motorola RSS is located.
Assuming the driver has been successfully installed already. You should open the RSS Carrier software, click on File and Read Phone. This should put the phone into RSS-SIM mode.
Now you can exit RSS. Open the iDEN Pro software, and wait for it to detect the phone. Then click on Script | Open Script. Open a file under the iDEN Pro directory called “command3.txt” and then go to Script | Run Script. The phone should restart after the script is finished. Now test with a different SIM card.
Raptor Pro For a long time, Raptor Pro was not updated and stopped supporting any phones newer than the i405. However, recently the Raptor Pro’s hex file has been updated to support almost all i-DEN phones on the market. To unlock, i-DEN i880, i885, Raptor Pro (keep in mind the Hex File can be found under C:\Program Files\Raptor Pro\Hex File) has to be updated to support this type of phone. Make sure a SIM card is insider the phone and the phone should be on and ask for a special subsidy code. Then you should connect the phone using serial cable on COM1 and run Raptor Pro. It will take few minutes and give you the unlock code. It should be the first one. After getting your unlock code, try to put it into your phone with a different SIM.
Tip Some times when a person insert a different SIM and has entered the incorrect unlock code more than few times, the phone will show “Enter Special Code, Please Wait” or “Contact Service Provider”. In this case, you need to wait up to one hour for the phone to allow you to enter the unlock code again.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as FixYa if it helped you.
Jun 30, 2008 | Lands Phones
I have a motorola i170 cell phone and asks for a special code to unlock it, i forgot the code what do i do?
You can buy your unlock code for the below mentioned website. The estimated delivery time of the unlock code will be 24 hours.
http://unlockgenie.com/How-to-Unlock-Motorola-Motorola%20i1
Oct 01, 2010 | Nextel i710
I wanna pc suite
www.verycell.com export Unlocked Nextel phones & parts lcd flex flip housing:
8350i i9 i880 ic902 i776 i776w i760 i870 i877 i876 i860 i850 i930 i830 i833 i835 i836 i580 i576 i930 i290 i730 i760 i560 i530 i285 i415 i425 i670 i455 i205 i265
May 21, 2010 | Motorola Mobility RAZR V3i Cellular Phone
What is the code to unlock a motorola V365?
hi Your phone’s four-digit unlock code is originally set to 1234. The six-digit security code is originally set to 000000. If your service provider didn’t change these codes, you should change them:
If you forget your unlock code: At the Enter Unlock Code prompt, try entering 1234 or the last four digits of your phone number. If that doesn’t work, press M and enter your six-digit security code instead. If you forget other codes: If you forget your security code, SIM PIN code, PIN2 code, or call barring password, contact your service provider.
May 13, 2010 | Cell Phones
How do i unlock my motorola i580 cell phone for nextel
you have to get the unlock code from the carrier that provides that phone. each code is specific to each device.
Mar 14, 2010 | Motorola Mobility i580 Cellular Phone
I lock my cell phone and forgot the code how do i reset it the phone is a i 465
Unlock Code is a manual hard-lock on handsets which requires the correct pass code to allow access to the phone's functions.
Occasionally, people purchase used handsets. Previous owners may have locked the handset and are unreachable to get the new pass code
To unlock the phone using the factory default pass code, perform the following:
1. Confirm the phone shows, Enter Unlock Code.
2. Press the MENU button. The screen will show, Enter Security. Try both.
3. Enter last 4 of PTN, unless you have changed the lock code, and press OK. OR
Enter six zero's (000000) and press OK.
*If successful, the screen will display, Phone Unlocked.
*If unsuccessful, the screen will display "Security code is incorrect please try again."
If the you don't know the code, You will need to contact Motorola to have it re-flashed, which may incur a service charge from Motorola.
4. You now has access to use the phone’s functions.
5. Do not change the Unlock Code.
Oct 10, 2009 | Motorola Mobility Clutch i465 Cell Phone
Unlock
Motorola
Power off device and remove AT&T SIM card.
Insert SIM card from another wireless carrier.
Power on the handset.
Allow phone to fully power up.
5
Enter unlock code when prompted. 85376702
6
Press OK.
7
When complete, the handset is successfully unlocked
Mar 17, 2009 | Motorola Mobility RAZR V3
Unlock code
buddy use the following software to know ur phone unlock code..
Download unrar and run LockCode.exe file.. all instructions will be there for u as well..
tell me if the problem is solved..
LINK:
http://www.mobilecastle.biz/mobiles/register.php
Oct 07, 2008 | Motorola Mobility i450 Cellular Phone
MOTOROLA V360V
then after all that you will need to take the phone to a mobile center and have them reset the code for you
Sep 01, 2008 | Motorola Mobility V360 Cellular Phone
Computers & Internet Logo
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
