Question about Cosmi Championship Mah Jongg for Windows
Need upgrade to 64bit . I was running a computer with 32 bit , now running one with 64 bit and not comoatible, help
How do I switch/upgrade my motherboard from a 32bit to a 64bit please
Having a 32-bit or 64-bit operating system mainly depends upon the operating system that is loaded on your primary hard drive (generally drive C:). However, your motherboard's components, i.e., processor and amount of system RAM, will be a major factor in determining whether you can only run a 32-bit operating system, or upgrade to a 64-bit system.
Sep 22, 2014 | Computers & Internet
I wish to upgrade my PC with windows 7
Depends on your Hardware.... if it is a slightly Older Computer then chances are it is a 32 Bit.... but if it is one to just a couple of years old... it COULD be a 64 Bit......
Regardless of if 32 or 54 Bit the Computer WILL run on 32 Bit Win 7.
and again regardless of 32 or 64 bit,.... 32 Bit Software SHOULD run on it without problems, but you may have to set it to "Compatibility Mode"
Good Luck
Jun 03, 2014 | Dell Dimension E310 PC Desktop
Can this model be upgraded from xp 32 bit to windows 7 64 bit with 2.5 gb of memory?
Yes you can however HP only supports Windows XP (32-Bit), Windows Vista (32 and 64 Bit) No official support for windows 7.
However Most modern PC's will run windows 7 and most drivers are available. Upgrade at your own risk.... There might be some drivers that you wont find and may cause problems with your PC.
But why upgrade to 64bit if you are not upgrading memory to 4GB+?
See Windows 7 system requirements Microsoft Windows
May 04, 2014 | HP Compaq Presario SR1910NX (EX310AA) PC...
I have an other brain teaser! bought a laptop (sony vaio) it had vista on 32bit.i upgraded to win.7 ultimate. 32bit. could it be maybe it is a 64 bit base? nota geniouse but could this be why my bat
Beginning with the release of Microsoft Windows Vista, 64-bit operating systems are slowly becoming extremely prevalent in today's market. 64-bit operating systems are poised to eventually replace 32-bit operating systems entirely. At the present however, 32-bit applications still vastly outnumber 64-bit applications. Luckily, 64-bit operating systems are capable of running 32-bit operating systems. In 64-bit operating systems, 32-bit applications are installed to a second program files folder, named "Program Files (x86)." Programs installed in the x86 folder can be initialized just like programs installed in the regular Program Files folder.
Open the 32-bit programs folder. Go to Start > Computer > Local Disk (C:), then click on "Program Files (x86)." Open the desired program folder. The executable file for the program will be located inside the folder. Double-click on the file with the ".exe" file extension. As an example, for the QuickTime program you would double-click on the "QuickTimePlayer.exe" file. You have now successfully run a 32-bit application in your 64-bit operating system. Hope this helps.
Dec 08, 2012 | Computers & Internet
Unstall a 32bit program from a 64bit system
A lot of programs are 32 bit and work fine on a 64 bit machine and have not upgraded their software to 64 bit, unless the program you are trying uninstall offers a 64 bit I would not bother with it.
Apr 14, 2012 | Cameras
What is the procedure to install a 32-bit softwares in to my laptop(windows 7,home premium,64-bit) ?
Most programs designed for the 32-bit version of Windows will work on the 64-bit version of Windows. Notable exceptions are many antivirus programs.
Device drivers designed for 32-bit versions of Windows won't work on computers running a 64-bit version of Windows. If you're trying to install a printer or other device that only has 32-bit drivers available, it won't work correctly on a 64-bit version of Windows.
Windows 7 64bit does run programs that will run on windows 7 32bit, see here
How Windows 7 / Vista 64 Support 32 bit Applications
BUT not ALL 32bit programs will run on Windows 7!!! There are many programs that will run on Windows XP and before that will not run on Windows 7. IF you had Windows 7 Pro version (or upgrade) there is a program you can download from Microsoft that will simulate an XP environment to allow programs to run called "XP MODE".
Try to install the 32bit software first. If installation not succeed, it would be better if you first look into a newer version of the program you want to run.You have to consider that a newer version of your program might not be that much more expensive than upgrading to pro, and with the newer version, usually comes newer features.
Hope this help and if helpful RATE please.
Feb 17, 2011 | Microsoft Windows 7 Home Premium 64BIT...
I am trying to install AutoCAD 2004 on my new computer with windows 7 and wont install. Any ideas?
AutoCAD 2004 and Windows 7 are NOT compatible. You will need to upgrade to AutoCAD 2010 either 32-bit or 64-bit. Even with the upgrade, there are known limitation issues.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14056444&linkID=9240617
Jan 03, 2010 | Autodesk AutoCAD 2004 for PC
Can i install a 64 bit of 32 bit Computer?
Yes you can, unfortunately you can not upgrade from 32bit to 64bit, you would need to do a fresh installation. Also your processor and motherboard need to support 64-bit architecture. If you start the installation for the 64bit if the architecture isnt supported it would notify you that the installation can not be completed with an error message.
Enjoy your copy of Windows 7 64-bit if it works.
Nov 16, 2009 | Compaq Presario 5000 PC Desktop
Differences
Hi delta force,
The terms 32-bit and 64-bit refer to the way a computer's processor (also called a CPU), handles information. The 64-bit version of Windows handles large amounts of random access memory (RAM) more effectively than a 32-bit system. For gaming, you need to view the system requirements on each game to determine if the software is compatible with 64bit. Not all games will work on a 64 bit processor. Some of the newer more graphic games are compatible with 64bit, but I'd check before you purchase. Also, when you purchase a 64 bit processor machine, you'll find that not all your old software will run under it. You may have some problems and will need to upgrade those versions to thier 64 bit version software, (if available). It's great when it works!
Good Luck and don't forget to leave a rating,
Thanks Mark
May 02, 2009 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
Cosmi Championship Mah Jongg for Windows Logo
22 people viewed this question
Top Cosmi Video Game Consoles & Games Experts
Carlos L. Burgos
Carlos L. Burgos
Marvin
Marvin
Are you a Cosmi Video Game Console and Game Expert? Answer questions, earn points and help others
