Question about Philips Magnavox 60PP9701 60" Rear Projection Television
Magnavox 60p8241 turns off and light blinks twice
Magnavox 60p8241 i pulled an old projection tv from the garage. parents put it away cause when i turn it on it turns off after about 30 sec. then the power button flashes twice. i cant get it to stay on.HELP PLEASE
  • dvero13 Jul 13, 2010
    i was told by my parents the convergeance was
    jacked up and that an auto lock was activated. i got through the auto lock and deactivated it. the convergeance problem was not to bad. so the tv worked that night for about 4 hrs then thats when it just turned off by its self.
    thanks. ill just have to call the repair man
  • Philips Master
  • 11,800 Answers
Double flashing means that the power source is overstressed - one of the main consumers is drawing much more power than the source is capable of delivering so it shuts down by itself to protect the rest of the tv.
Most likely on a tv of that age the problem lies in the horizontal deflection unit - start checking the components, the power transistor and the electrolytic capacitors first.
This requires at least a basic experience in electronics, if you don't have it, don't touch it, you can do more damage just by touching the wrong stuff. Call a repairman and ask for a quote.
Posted on Jul 13, 2010
  • Philips Master
  • 12,061 Answers
Hi, I see this type of thing often, in my shop, a customer pulls a unit out of storage, after a while, and are stumped when it will not, "Go".Well, unfortunately, you see when a TV set, or any, electronic, device, is left without power going through it, it actually does it harm, things in storage should be powered up at least a few times a month, otherwise the Capacitors will loose their "Form" and will not work correctly, and if left too long the unit simply becomes unservicable, also the moisture in the atmosphere, gets absorbed by osmosis, into "Other" compnentry, and this too causes failures, not to mention, any other sort of corrosion, or perhaps flat cells in a unit, inductors etc. So as said, this makes a unit more or less unrepairable. without a large dollar outlay with no guarantee of success.
http://www.eserviceinfo.com/equipment_mfg/MAGNAVOX_2.html
Above, is your service and repair manual.
TV won't turn on. red light blinks twice and nothing happens
This is an error code of some fault inside. Kindly call in a qualified service technician.
Jul 25, 2012 | Magnavox 32MF301B LCD TV
I need a code and instruction to program my remote control with a magnavox tv
  • The Magnavox codes are 32114 and 11434. Should those codes not work then follow these steps to do a code search that will find the code inside the remote.
  1. Turn on your TV.
  2. Press and hold down the SET UP key until the red light blinks twice.
  3. Press Programme - three times. The red light will blink twice.
  4. Alternate between Programme- and Power until your TV turns off.
  5. You may have to press these keys many times, so please be patient.
  6. When your TV turns off, press the SET UP key to store the code. The red light will blink twice. Your TOTAL CONTROL is ready to run your TV.
Regards, Tony
May 18, 2011 | One For All URC4110 Remote Control
I am trying to find the name or part number of the small circuit board that powers my tv off and on model number 60p8241
Hello! Actually that little board is called a ballast. it's not that expensive. It goes fro 60-80 dlls http://www.discount-merchant.com/SearchResults.asp?Search=ballast?Click=48427
Nov 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
I need old style urc4330 Big easy remote codes for magnovox tv
The URC 4330 Big Easy remote codes for a Magnavox TV are:
0054, 1254, 0030, 0179, 0187, 0096, 0020, 0186, 0386, & 0024
Program them in by turning on your TV, pressing TV on the remote, pressing and holding SET until the LED blinks twice, entering the first code in the list, (the LED will blink twice to say it has been accepted, if it didn't blink twice start over at 'pressing TV on the remote'), and pressing POWER to test the code and turn off the TV. If the TV didn't turn off, repeat the steps using the next code on the list.
Hope that helps.
Sep 23, 2009 | One For All URC-3021 Remote Control
Magnavox 60 inch TV
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 12, 2008 | Philips 60P8241 60" Rear Projection...
Phillips Magnavox
Sounds like your Convertion bord pops. Tv Technical Prop, Take for service.
May 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox Plasma HDTV Red light
I had a similar problem with my magnavox tv with the blinking light issue. Eventually it just didn't come one anymore. Looking at other forms they said the problem was a bad capacitor number 2074 located on the power supply board. When I opened my tv, I noticed that the capacitor was bulging and burnt up. I bought a new one labeled 2200uf 35v and did some solder to attach the new piece. Put the tv back together and it works like new. No more blinking light. I hope this helps.
Feb 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
MAGNAVOX BIG SCREEN TV
Hi, I am having the same exact issue with mine. Although, it is only about 2 yrs old. We are still trying to find out what is wrong with it.
Aug 01, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 60PP9701 60" Rear Projection Television Logo
71 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
