Question about Toshiba e-Studio 350 Copier
Toshiba estudio35 trouble code
I have a toshiba estudio35 copier, when i turn it on, a "call for service 1571324" and a code of F11, please help me to fix the problem of my machine.
    Problem Solver:
I have a toshiba estudio35 copier I CANAT INSTALL IP\TCP IN MY MACHIN
Posted on Apr 22, 2008
Where can you get the latest firmware for the Toshiba E studio 35 copier. I have been working on copiers for 15 years but this will be the first time I have to update the firmware but not sure I have the right info. I went to the Toshiba web page but it only shows driver updates is that the same thing?
Thank you Gary
www.BryantRecharging.com
Posted on Oct 14, 2008
  • 4 Answers
F11 code suggest a communication error between the system board and the SLG (scanner) board. Although several things can cause this like disconnected connectors or defective PCB's, the most likely cause is either corrupted firmware or incompatible firmware. A trained technician needs to reinstall the firmware, preferably with the latest version.
Posted on May 04, 2008
2 Suggested Answers
  • 653 Answers
SOURCE: Toshiba estudio35 trouble code
U need to update firmwares, if failed. then probably need to change board...
Posted on Sep 17, 2009
Error code C440
Toshiba eStudio 355/455 Full Service Manual - Tradebit.com
https://www.tradebit.com/.../155135538-toshiba-estudio-355-455-full-se...
Download Toshiba eStudio 355/455 Full Service Manual ... Configuring DepartmentCodes Configuring ... TSB-1013: C440 Error - Countermeasure .... DIG-ACC-145: MJ-1025 Bracket Change to Enable Installation on e-STUDIO205L/255/305
Aug 08, 2015 | Toshiba E-Studio 305 Digital Copier
Problem with code F11 on Estudio 311c - aspanner
[F11] Communications error between system-CPU and scanner-CPU
This quite often can be cleared up by resetting the machine. If not you will want to check all of the connections between the scanner, the scanner board and the system boards in the back of the machine. If nothing is loose this is likely a very critical error and you will need to have a toshiba authorized technician take a look at your copier.
Sep 08, 2010 | Toshiba COPIERS - E-STUDIO 311C Copier
Service problem giving code F11 on estudio 311
My Toshiba e161 printer error code on E 7. what problem in my printer and how the solved the problem
what is the sub code?
main code sub code description
E7- 02 LSU trouble 10 Shading trouble (Black correction) 11 Shading trouble (White correction) 12 Shading trouble 16 Abnormal laser output
more details digivisionm@gmail.com BR
Mar 09, 2010 | Toshiba e-Studio 161 Copier Copier
Can we refill toshiba e-studio 207 Tonar Cartige ( Cartige No.T-1640D
sir i have Toshiba 207 copier sir now write on screen call for service C44 sir please solve my this problem thanks
Sep 03, 2009 | Toshiba e-Studio 205 Copier
Try 08-600 sub code of 2. This is a reanitilazation of the HDD it may help you out. If it errors and does't tell you to reboot then your hdd is shot. after this code you will lose all fax presets and templates stored on machine. also just try a reboot.
Apr 20, 2008 | Toshiba e-Studio 350 Copier
Toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
Mar 31, 2008 | Toshiba e-Studio163 Copier
Toshiba eStudio 211c
it is hard disk trouble. First enter in service mode (pressing 08 while turn on the power) next, type 690 and set to 2, click enter and wait the "reboot the machine" message, then turn off and on again
Apr 11, 2007 | Toshiba E-STUDIO 211C Copier
Toshiba e-Studio 350 Copier Logo
536 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
