Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Dishwasher fills and empties water but doesnt run any programm
  • Bosch Master
  • 2,605 Answers
Hello, welcome to FixYa. Can you elaborate on the actions which take place ? Does it fill and just sit idle until eventually drain or do you cancel the cycle manually to initiate the draining ? I should be able to help you with some more details. I will watch for your reply. macmarkus :)
Posted on Jul 13, 2010
Dishwasher wont fill up with water
When you start the dishwasher you have probably noticed that it first drains water and is very important to hear that drain pump running all the time or stops after a while? Why?
If the drain pump runs constantly then the fault is in the phase of "drain water" or is activated anti-flood system. Reset point of pressostat is not reached after max. 120secs. Programme stop and can be continued after error remedy by pressing the programme key.
If the pump is running for a while and then stops, then the fault is in phase "fill up water". Switchpoint of pressostat is not reached
after max. 60 secs.
Usually built-in dishwashers has anti-flood system that responds in the event of water in the bottom of the dishwasher. Such a case, find and repair water leaks.
Dado
Aug 06, 2014 | Electrolux 23 in. ESI6104 Built-in...
Hi, Dishwasher problem: When a programme starts, the machine fills with water then stops and the "check water" light comes on. To empty the machine, I used the reset programme which does empty the...
You will need to check the inlet valve and the water level pressure switch. It can also be a low pressure in the pump that is giving out the signal for the control board to shut off.
So first of all check the water line throughly to confirm.
Oct 02, 2010 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher fills with water, then empties, fills then empties, and repeats this cycle a few times - then decides to work. then part way through cycle - it repeats this frustrating cycle, making the whole...
Hi, Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water. To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Apr 18, 2010 | Fisher and Paykel DS605I Built-in...
Zanussi DCE 5655 dish washer
Unplug at night if doesn't work change the L subport conversion chamber and remove the restricter plate
Feb 27, 2009 | Zanussi 21 in. DCE5655 Free-standing...
Programme will not run , starts beeping after 5 minutes into cycle
turn your dishwasher on the first thing it should do is a quick drain then fill after the fill open the door and see how much water is in it hold my rating till we are through
Jan 31, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Dishwasher stopped mid programme
First place I would go is the door switches, make sure the dor switch assembly is not broken, and switches working.
Jan 05, 2008 | Dishwashers
Bosch dishwasher problem
remove the kick plate below the door. youll see a white tray behind the kick plate. theres water in the tray thats activating a overflow switch. with a towel or 2 remove as much water from tray as possible. this will solve problem
Nov 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Zanussi Aquapulse DE6544 not emptying
Zanussi Aquapulse dishwasher - is filled with water inside, is not washing and the lights keep flashing on and off - has anyone any idea what may be wrong with it?
May 27, 2007 | Zanussi 24 in. DE6544 Built-in Dishwasher
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
191 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
