Changing the channel to av without a remote
I havent got a remote for this tosumi tv and cannot change the channel to av. is there anyway to change the channel to av without it?
I dont know if you tv has this sertting but click menu usally 4 times and it will bring u to a page wich might say channel or something else and u can chane the channel by using the volume buttoms this worked for me and i can put it onto av1 av2 av3 and av4
Posted on Jan 03, 2009
I did the same and i tried holding my menuer button (on the tv itself) and that actually worked, it brung up the av menu
Posted on Jan 10, 2010
CHANGE CHANNEL TO AV/SCART ON A GOODMANS TVC 1400 WITHOUT THE REMOTE CONTROL , ONLY RUNS THROUGH 7 CHANNELS
Not familiar with this, but see if there is another button on front or top or behind a cover marked AV or source, if so then that will select the channel you want.
Sep 16, 2014 | Televison & Video
How can I go to av mode without remote control in samsung hitron tv
Yes, you change your channel to '00' or go up to '101' and then press up button on tv then it will automatically comes to '00'
Nov 08, 2012 | Samsung Televison & Video
I have a Tosumi television connected to standard sky box but every time I turn on television it goes to another channel rather than the connected av channel. Also when I try to use sky controller to...
Always turn on your TV with the Sky box (or any other external device you want to use) turned OFF. When the TV is on, turn on the Sky box by pressing the "Sky" button at the top centre of the remote control. This will ensure that the TV recognises that there is an external input and it will automatically switch to the correct channel. It also ensures that your Sky remote control isn't in TV mode.
If you switch your TV to standby using the Sky remote after watching, the next time you use the Sky remote, it's still in TV mode. This is why your TV channels are jumping around.
Hope this helps.
Oct 21, 2010 | Televison & Video
I am trying to change the input on my tv but I do not have a remote. Can I still change it? How?
on some tv's you can go back through the channels and it will get to AV (eg: 2,1,0,av1,av2,99,98...)
Some TV's will have an AV or input selector buton on them
and on most TV's you cant put it to AV input without the remote... you could try a "0ne for all" remote, they generally work and are cheap
Aug 27, 2010 | Durabrand DWT1905 TV
How do I change the input selction without the remote?
many TV support AV after the last channel pls try last channel and go ahead you will find AV-1 THEN av-2 then channel 0 like that but i am not sure pls try
Aug 26, 2010 | Sanyo DS27910 27" TV
HOW CAN WE CHANGE TO AV ON HITACHI TV WITHOUT
Try this! Get into the menu and look for channel setup. See channel memory delete or save and add this to channel memory. Hope this works..I never repaired this model. This is only a suggestion.
Dec 23, 2009 | Hitachi 43FDX01B TV
How to select av without remote control
try pressing plus and minus channel on the tv at the same time. works with my daughters tv
Nov 16, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
you might try going to channel 00
If you cannot just dial the number 00, go to channel 2 and then channel down.
Does not always work, but without the model number of the TV it is hard to advise further
Mar 12, 2009 | Televison & Video
Havent got a code sheet
Call 1800 Remote to get the Original remote for that set.
Nov 04, 2008 | Televison & Video
Av mode?
well if you change the channel to the highest it goes some TV can be changed to a/v mode
or the lowerest number under 2 sometime a/v might be there
remote stop working due to batteries or drop remote, might have to be replaced either abtteries or whole remote.
Mar 03, 2008 | Emerson SpongeBob SquarePants TV
Televison & Video Logo
3,488 people viewed this question
Top Televison & Video Experts
