Question about Zephyr AK8100S Kitchen Hood
My hood just conked out...no apparent reason and is less than 1 year old.
  • 3 Answers
If it cannot be fixed - too expensive or whatever - consider a replacement from Imperial. This is the only company that offers a 5 year 100% parts and labor warranty with in home service. If an issue in the first five years a technician comes to your home. Plus, they are made in the USA. Here is a link for for information: www.vent4less.com
Regards
Donald
Posted on Jul 14, 2010
I have a Reliance 501 HWH, 15 yrs old. Nary a problem until now. Yesterday, HW was very hot. Today, no HW. I'm thinking of replacing both elements and thermostats due to the age. Sound reasonable?
At fifteen years of age it would be less cost over time and labor to replace the whole tank. How efficient is your old one and being it runs hot all the time you could have a tank that will not last very long anyway. Mine sprung a leak at 18 years and made a big mess.
May 15, 2014 | Reliance Water Heater #6-50-DJRT 50GAL...
The circulation pump on my Fluval Spec V 5 gallon quit working. I bought the tank only three months ago. Any thoughts on why it conked out in such a short time?
did it "conk" out or is the pump impeller stopped by a buildup of material ?? the reason I say this its very unusual for a aquarium pump to go completely out (ive had one running 24/7 for ten years) but in that ten years ive replaced two impellors and cleaned it out over one hundred times , and yes three months is the perfect time period for a cleaning needed !!!
Aug 11, 2013 | Fluval Spec V 5 Gallon Aquarium Kit
Engine light on
Could be a oxygen sensor?Do you have a warranty?If so they will check and fix for free.If no warranty,you can go to Autozone and they will scan your vehicle for free and tell you why that check engine light means,the owner's manual tells you to go see dealer.
Dec 11, 2012 | 2011 Kia Rio
Water is collecting in the bottom of refirigerater, spilling out on floor. Leak in drain pan was caulked by repair man, but water is now statring to appear in the bottom of unit again. Can this be normal...
Hi!!
Check temp. settings and try to lower it 1 click, this will keep the unit working a little less, ddiminishing the condensatino.
Also try relocating the unit to a cooler spot, ie. away from the door.
Keep me posted!! Rate this post!!
Aug 12, 2010 | Kenmore Refrigerators
5 year old plasma that looses half the picture
Hello. I recommend that you forget the repair for two reasons. 1. Pricey. 2. You still have a 5 year old set with no warranty. In the last five years, the tv technology has come so far. The HD is fabulous. The new sets cost less to operate and they are so much better than they were five years ago. Joe
Mar 24, 2010 | Philips 42PF9630A 42 in. Plasma Television
We have a Canon D760 and have paper jammed at the out feed just before it goes to the tray how do i get to the jam
You it is necessary to make sure visual(optic) to see the sensor(pick-off) of that node(knot;element), which(who) you is informed.Byvat that conk or клинят sensors(pick-offs) of the passing, electronics in this case her(its)(her) fault is practically excluded. Extremely(Most) seldom(rarely) such быват.I work(operate) 18 years I had 1 or 2 times, but only mechanical damages much(highly;very much) often were. The Sensor(Pick-off) conks or клинит, when remoove the stuck paper. I am simply(merely) run away that reason in sensor. Good luck you!
Aug 07, 2009 | Office Equipment & Supplies
We ge a PF signal for no apparent reason its a
Check the wire connections at the power input to the dishwasher. Wire nuts should be tight and if you pull on individual wires while holding the wire nut, wires should be tight. My guess is you will find a poor connection there.
Jul 06, 2009 | Dishwashers
Sharp Aquos LCD intermittent display
Hi there.
The backlight inverter board is defective.
Replace it and your problem will be solved.
Oct 15, 2008 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Screen problem
Perhaps your connections on the inside have come loose. It may warrant you take it to a specialist to check it over before it gets any worse. Some other person was on here some time ago who had a similar problem and all it was is the switch in the lid. Apparently they tinkered with it by just kept on pushing it back and forwards as if to continue to open it and it came right they tell me that they hardly used it thats why!.
Oct 02, 2007 | HP Compaq Presario V2000 Notebook
Zephyr AK8100S Kitchen Hood Logo
105 people viewed this question
Top Zephyr Kitchen Ranges Experts
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
