Question about Frigidaire 11.6 cu. ft. / 328 liter Upright Freezer FFU12K1CW
Freezer is on, but not working
Freezer is plugged in and light is working, but the freezer is not keeping things cold and fan is not on.. Everything is melting
  • 1,531 Answers
Sounds as if the temp control knob has gone bad or maybe turned off by accident.
Posted on Jul 13, 2010
Freezer is too warm. We have cleaned all vents but is still in the 40s
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
I hope the above helps.....
For further assistance, please let me know.
Regards.
Sep 15, 2011 | Maytag Freezers
It is running but is not freezing the food
Regards.
Sep 15, 2011 | Maytag 15 cu. ft. / 425 liter Upright...
The freezer is not working... It has been slowly warming up for a few weeks. What could be wrong? Also, does this mean that the fridgerator is next to go? We have a GE Model # GSH25KGPA WW
Good luck.
Sep 14, 2011 | Freezers
My freezer is no longer freezing
Regards.
Sep 14, 2011 | Hotpoint Freezers
I own a frigidaire model # CF-5D-L*2 manufactured in Feb. 1987 and it stopped cooling off. I've looked at the underside of it and don't see anything off the bat that would be wrong with it. Can you...
Good luck.
Sep 13, 2011 | Frigidaire Freezers
My chest freezer (10 years old) won't freeze. Motor is running and the red indicator light remains on, but neither the amber or green lights are working.
Let's start by diagnosing the freezer;
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
Regards.
May 01, 2011 | Whirlpool 10 cu. ft. Chest Freezer...
My danby 3.6 chest frezzer has stoped working, it was freezing fine yesterday, now its not even keeping cold
I hope this helps........
Good luck.
Apr 14, 2011 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezer not freezing .. It's cold..
Take care.
Apr 12, 2011 | Northland Panel Ready Upright Built In...
Freezer stopped freezing. food started getting soft on top. power light on. green light off. tapped it , green light on. less than 1 yr old.
Good luck.
Mar 02, 2011 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
Kenmore 14CF upright freezer will die after a day or so
The defrost timer is faulty or you have a defrost circuit short, unplug remove back panel inside the freezer and check for a short in the heater and defrost thermostat.
Dec 30, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frigidaire 11.6 cu. ft. / 328 liter Upright Freezer FFU12K1CW Logo
145 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
