Question about GE Microwave Ovens
I have a GE Spacemaker XL1800. It is making a buzzing noise.
I have a GE Spacemaker XL1800. It is nine years old and lightly used. It is making a buzzing noise (just started). It is heating food. The noise sounds like it is coming from the top of the unit where the vent opens when the unit is on.
The manual we have for our Model 1860SD does not depict the unit we have so it is no help at all. As a matter of fact the instructions on how to change the interior light are wrong. I went to GE's online support to see if I could find the correct manual, but it shows the same manual that came with our microwave.
Any help you can provide is appreciated
SOURCE: GE Spacemaker XL1800
check conrol circuit, and magnetron, and highvoltage section,
Posted on Nov 04, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: My ge profile spacemaker xl1800 turntable stopped .
It's probably a bad turntable motor or coupler.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
  • 3 Answers
SOURCE: G.E. Spacemaker XL1800- Loud constant buzzing noise. Help
My microwave was totally dead. Things I discovered: 1) There is an easily replacable fuse accessed by taking off the top front vent cover (two screws on top, gently massage off) and then the inside plastic grill. UNPLUG before doing this! 2) Pop off two wires on either end of fuse holder for safety. Then pop out fuse and replace. For more extensive help, there is an evelope with a wiring diagram inside the case on the inside wall! Very helpful when diagnosing the surface lamp problem (I forgot to plug the ballast back in when I closed up the bottom).
Posted on May 15, 2008
jonniewalker
  • 1031 Answers
SOURCE: Replacing interior light bulb for ge spacemaker xl1800
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top to check if you can access the bulb fromthere. There may be a panel on the bottom covering the light(s), instead.
you may have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy,
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
hope this helps dont forget to rate this
Posted on Sep 21, 2008
SOURCE: Outside venting GE Profile Spacemaker XL1800
Your vent flap could be taped or it could be faulty installation not allowing the vent to open. If you take the front vent cover off, you should be able to reach in above the fan unit and gently push the vent flap up, it should move freely with no binding. If it doesn't it is taped or blocked. If it is taped, gently putting upward pressure on the flap might release the tape. If that doesn't work the vent installation is blocking the flap. You might have to remove the unit from the wall (two people to do this) or disassemble the vent duct above the microwave and rework the interface for clearance.
hope this helps,
Posted on Oct 07, 2008
Problem with the GE Spacemaker (JVM1640SJ) Microwave Oven GE Spacemaker XL1800 won't heat food anymore....It worked this morning, now won't heat. What should I do?
GE Will replace the magnetron for 9 years! Mine is a 2004 model with a one year warrently according to manual. HOWEVER they did say the magnatron was covered for nine years: call 888-239-6832. When I called they said thats all they get calls for and would send out in 3-5 days. NO CHARGE. I had to ask if there was coverage longer than a year on major parts and that's when they offered the info and I eventually was transferred to the right office. Saved $120 bucks on parts alone.
Jun 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker xl1800 - Funny noise, flickering light
very possible your magnatron is faulty. Disconnect 2 transformer wires and make sure they dont short. try the program again. if no noise, replace magnatron:capacitor and HV diode Please i strongly suggest an electrician help you as it is truely dangerous in there. .
Sep 15, 2009 | Microwave Ovens
GE Spacemaker XL1800 hum/buzz noise but heating works
the magnetron needs replacement my friend, although you can still heat up food but eventually it will soon fail.
appreciate your kind comment
Apr 12, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave does not work
please dont forget to rate me on this issue...
Feb 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 first no inside light followed by loud noise
I agree that the light is unrelated. 99.9% chance you have a bad magnetron tube but it is covered by either a 5 or 10 year parts warranty through GE. Call GE Factory Service at 1-800-432-2737 or schedule online at www.geappliances.com
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 Buzzing
Chances are this is a problem on the control panel. We repair these for customers nationwide with our guaranteed $39.95 service.
Please feel free to contact me directly if you need more help. And please mention your model number when you write.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Mar 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Microwave Ovens Logo
166 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
