Question about Philips 37PF5321 37 in. HD-Ready LCD Television
I plugged in the tv and the little red light on the front-bottom of the tv goes on but when I press the stand-by button (either on the remore or the tv itself) the tv does not turn on. In stead the little red light starts flashing (two flashes then one more and then it repeats this pattern).
    Welcome Back:
    Visited the website for 2 consecutive days.
Hello...i think this is a problem of the lcd screen of the tv....or a problem in the circuit board of the tv..so you to call a tv technician for that.
Posted on Feb 10, 2018
SOURCE: red light flashing on tv
My 37" TV Will not yurn on . The green light goes on for 2 seconds then goes off and red light starts flashing. What Repair/Part is needed.
Posted on Oct 12, 2008
  • 90 Answers
SOURCE: Red flashing light. Light flashes red 8 times pauses & repeats
power supply board going bad
Posted on Mar 03, 2009
SOURCE: TV won't turn on
my philips plasma tv just shut of on me one night, i tried everthing 2 get it working. A repairman said to fix it approx $450.00. I paid over $2500.00 3 YEARS ago didnt know if it was worth paying out that money and then it breaking down again. For three months i kept the tv untill i decided what 2 do, couldnt bring myself to trash it. So this week i took of the back panel there was so much dust inside carefully removed all the dust, Still it wouldnt work so then i decided to go to where the powercord is to see if anything burned out, it hadnt. I followed where the cord went to and noticed that there was a fuse beside where it when on the board so i removed it when to lowes and bought replacement fuse for $1.75 put it in and bingo it started back up after about 4 months of trying.I hope it works for you. you have nothing to loose you will have to either trash it or let some repair man rip you off . Good luck
Posted on Nov 29, 2009
jerryg50
  • 1689 Answers
SOURCE: the red standby light flashes and when the power
One of the boards (module) has a short on it, and or the power supply itself is failing.
The service center will find the fault using the process if elimination. They will replace the bad boards or modules as required to get the set working again.
Jerry G.
Posted on Dec 16, 2009
SOURCE: bottom left lights. when i turn on tv red light
bottom left lights. when i turn on tv red light flashes what does mean
Posted on Jan 04, 2010
Tip
How to connect you Wii to your TV, Out of the Box.
After getting everything out of the box, decide on where you want to put your Wii. It should be near your TV and near an electrical outlet. You can either lay the Wii flat or sit it on its side. If you’re laying it flat, move on to step 2, Connect the Cables. If you want to place the Wii in a vertical position you should use the Wii Console stand, which is the gray base unit. Attach the console plate to the bottom of the stand, put it on your shelf and then place the Wii on it so the beveled edge of the console aligns with the beveled edge of the stand.
There are three cables that connect to the Wii: the AC Adapter (a.k.a. power cord); the A/V connector (which has three colored plugs on one end); and the Sensor Bar. The plug of each is distinctly shaped, so each cable plug will only fit in one port in the back of the Wii. (The two small, same-sized ports are for USB devices – ignore them for now). Plug the AC Adapter into the largest of the three ports. Plug the Sensor Bar plug into the small red port. Plug the A/V Cable into the remaining port.
To connect your Wii to your television, find the sockets on your TV that, like the A/V Cable, are colored yellow, white and red. The sockets are generally on the back of the TV, although you might also find them on the side or front. You may have more than one set of ports, in which case you can use any of them. Insert each plug into a port of the same color.
The sensor bar can be placed either on top of your TV or right below the screen, and should be centered with the middle of the screen. There are two sticky foam pads on the bottom of the sensor; remove the plastic film covering them and gently press the sensor into place.
Next, simply plug the AC adapter into a wall socket or a power strip. Push the power button on the console. A green light on the power button will appear. The remote comes in a rubber jacket, designed to protect it, which you will have to partially peal off in order to open the battery door. Put in the batteries, close the battery cover and pull the jacket back on. Now push the A button on the remote to make sure it is working (a blue light will appear at the bottom of the remote).
The Wii remote that comes with your Wii is already synced up, meaning your console will communicate properly with the remote. If you have purchased any additional remotes, you’ll have to sync them up yourself. To do this, remove the battery cover from the remote and press and release the red SYNC button inside. Then open the little door in the front of the Wii where you will find another red SYNC button, which you should also press and release. If a blue light goes on at the bottom of the remote then it is synced up. When using the remote, slip the Wii remote wrist strap around your hand first. Sometimes when people are waving their remote around it slips out of their hand and breaks something.
Turn on your TV. Set your TV input for the input channel your Wii is plugged into. This can usually be done through a button on your television remote generally called “tv/video” or “input select.” Read any onscreen text. This will be either a warning, in which case you can press the A button, or a request for information, such as whether the sensor is above or below your TV and what the date is. Point the remote straight at the screen. You will see a cursor similar to the mouse cursor on a computer. The “A” button does the equivalent of a mouse click.
Once you have answered all the questions you are ready to play games. Push a game disc into the disc slot; the illustrated side of the CD should face away from the power button.
The main Wii screen shows a bunch of TV screen-shaped boxes, and clicking on the top left one will take you to the game screen. Click the START button and begin playing.
on Feb 15, 2010 | Video Game Consoles & Games
Yes i am tyler thank you trutech plv16320vm tv/monitor, will not come on,when you plug it in you get a red stand by light ,when you press the power on button. it goes off and nothing happens. or after u...
I would have to say that you have bad capacitors in the power supply.Open the back of the TV,and look at the can shaped items called capacitors on the board with the power cord.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Mar 08, 2011 | TruTech PLV16320 Television
My tv won't turn on anymore. The power light and the opc light blink twice at the same time and then the opc blinks once and it keeps doing that. Please help!
Hi
Make sure the AC cord is not loose or disconnected. Check to ensure the cord is firmly plugged into the outlet at one end, and firmly connected to your television at the other end. The AC cord connects to the television about midway across the back of the set, near the bottom of the back panel. The hole for the AC connection is shaped like a figure eight. Try powering up the TV with the cords firmly connected.
Check the "Main Power" to ensure it is on. Locate the button on the top of the television among the "Volume" and "Channel" buttons. Press the button to switch the television on. If the "Main Power" button is off the remote will not turn on the television. Wait to see if pressing "Main Power" will activate the TV.
Press "TV Power" on the remote control to power up the TV from stand-by mode. If the power light on the front of the television glows red when you press "TV Power" on the remote, press the "Main Power" button on top of the television to remove the TV from stand-by. If the TV is accidentally in stand-by mode it may not come on when pressing certain buttons.
Check the circuit board. If your set still won't turn on and you hear a clicking noise when you plug it in, you most likely have a defective circuit board.
Oct 23, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How to connect a tv to a wii
Feb 15, 2010 | Samsung LN-S3241D 32 in.LCD HDTV
Cannot get tv out of stand by mode..
upon hitting the power button, the red light showing on the front of the tv should flash a couple of times, the screen should come on and the light goes off..the red "stand by " light stays on and we cannot get the screen to come up..needless to say, cannot get to the menu to change any display options...any suggestions?
Apr 10, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV will not switch on from stand-by mode
keep pressing the channel up button and switch on the tv( plug it to the power). then release the channel button and press power on.
it should work.
Mar 29, 2009 | Panasonic Televison & Video
Need codes for a AKARI 14" color TV IC-1494RAK
1. Turn TV on
2. Press TV key on remote.
3, Press and Hold magic button until red light blinks twice, it will blink once and then twice.
4. enter 991 red light will blink twice
5. Hit the power button
6. Aim the remote at the TV and press the channel plus button until the TV turns off.
7. Hit the magic button as soon as the TV turns off to store the code.
Hope this works for you!
Jan 03, 2009 | One For All URC 7740 Remote Control
Philips 37PF5321 37 in. HD-Ready LCD Television Logo
130 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
