Question about Gateway (G-MAX2000) Computer Speakers
I have Gateway G-Max2000 2-Piece Multimedia Speakers. About two days ago i swiched i bought new cpu which runs windows7. Before I had windows XP. and the speakers were working on Window XP. But when i try to connect now it doesn't work. I have tested to other computers (X P and Vista). It does work there but does not work on this machine Please help me
  • 936 Answers
The issue is with your PC, not the speakers. Check that you are connecting to the correct socket, usually green in colour.
Check the sound settings in Windows 7.
See here:
Personalizing Your Work Environment in Microsoft Windows 7
Posted on Sep 20, 2017
  • 5 Answers
SOURCE: The speakers don't work
Ok There is another chance to work your speakers ,
  If you have your mother board CD , get play that  and  reinstall the sound system .
  I hope it will work ,      please do reply
Posted on Dec 22, 2007
SOURCE: One speaker not working and Scratchy Audio
just check is there any loose contact frm that speaker connection plug out the cable connect it again and have a check it may work...
or may be any time the speaker may be falled on ground so may be there is problem
Posted on Feb 05, 2008
  • 4 Answers
SOURCE: Cpu problem with speakers
reinstall the sound drivers. it will be fine
Posted on Jul 09, 2008
edwinmeyer
  • 57 Answers
SOURCE: I have Altec Lansing AVS 300 multimedia speakers with no power
Unfortunately the subwoofer supplies the power to the amp on the speakers, Once again I have the solution,
These speakers are factory molded so that the only way to open them is to break the factory seal
this can be done by sharply rapping the seam at the bottom of the speaker with a heavy screwdriver handle or something similar.
Now you need to supply power to the amp...If you do not have the subwoofer you will need a 4.5volt power supply, after removing the board from the casing find the red white and black wires connecting
the orange plug wire to it, Personally I removed the entire cord from the unit, shough you can splice in at this point if you desire.
Connect the white lead to your posative on your power supply by either splicing or soldering, connect the ground to the heat sink using the screw that is already there holding the chip to the sink. reassemble the speaker.....super glue... and you are now in business.
Ed Meyer
Owner AACS
www.alwaysaffordablesolutions.com
Posted on May 22, 2009
  • 5 Answers
SOURCE: my g-max 2000 speakers aren't working!
you do not need a driver or anything maybe they just burnt out?
Posted on Jul 29, 2010
Sir i m using windows 7 ultimate...n i want install tally 7.2. i cant use it in windows 7. i m also trying run as administrator, change compatibility mode in windows xp sp2 mode...but i hve same probs..so...
Tally 7.2 is not longer supported. You might need to upgrade to the newest version.
The only other suggestion is to see if you can run in XP Mode. This will depend upon your computer requirements.
Running Windows XP Mode requires:
1. Windows 7 Professional, Enterprise, or Ultimate editions.
2. A computer capable of hardware virtualization. This means your computer has a central processing unit (CPU) with either Intel-VT or AMD-V virtualization features.
3. Virtualization features turned on in your computer's basic input/output system (BIOS).
To determine whether your computer's CPU is capable of hardware virtualization, go to the Windows XP Mode and Windows Virtual PC support website and download a utility that can check whether your Intel or AMD CPU is compatible.
http://www.microsoft.com/windows/virtual-pc/support/configure-bios.aspx
To find your brand of processor so you can download the appropriate utility, click the Start button , right-click Computer, and then click Properties. Under System, next to Processor, you can see what type of CPU you have.
Even if your CPU can run Windows XP Mode, you might also need to turn on virtualization settings in your computer's BIOS. Procedures vary depending on the BIOS manufacturer. For more information, see BIOS: frequently asked questions.
http://windows.microsoft.com/en-us/windows7/BIOS-frequently-asked-questions
For more information, please logon to:
http://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7#section_3
Regards
Riztech
May 22, 2011 | HP Pavilion dv6000z Notebook
I bought Boston Acoustics MediaTheater Computer Speakers as part of a package with my Gateway computer about 12 years ago. I would like to use the speakers with my IBM Think Pad (laptop) that runs on...
A male to male audio cable should work depending on your laptop, but don't think you would need a driver. I used a male audio to male RCA and hooked this to my TV and works great.
Aug 14, 2010 | Boston Acoustics MediaTheater Computer...
I need the breakdown on the gmax 5 allison 5 speed
Under Windows XP, click Start
Click with the SECOND (usually the RIGHT) mouse-button on "My Computer".
Click Properties.
The first screen will run a short "speed-test" to determine your "actual" CPU-speed, and to display the "rated" CPU-speed, e.g., 3000 MHz running at 2.99 Ghz.
Apr 23, 2010 | Gateway GMAX 2100 Computer Speakers
I bought some years ago a USB to Serial Port Cable Nexxtech. It work fine with Windows XP. But I buy a new computer and Windows7 can not read driver from the disc. What can I do?
You should look for new driver on the internet. driver for windows 7 or maybe vista, it might work. Windows XP needs different driver then windows 7.
Good luck
Mar 22, 2010 | Computers & Internet
Avid media composer with windows7
no need it will definitely work on windows 7. because it has xp mode that run all the xp compatible applications in windows 7. u know that windows 7 is really amzing.....
Aug 26, 2009 | Avid Xpress Pro 4.8.1 Full Version for PC,...
Gateway- built-in laptop Speakers not working
Seems to me the speaker is just plain broken. You'll need a new one, contact your vendor for repairs, or you will have to live with using external speakers/earpieces...
I hope you will get your replacement,
Yannick.
May 25, 2009 | Gateway Computers & Internet
3ds max autodesk is not opening in windows7 ultimate
Right click the 3dmax then open it with administrator.
May 22, 2009 | Autodesk 3ds Max for PC
Gateway (G-MAX2000) Computer Speakers Logo
97 people viewed this question
Top Gateway Audio Players & Recorders Experts
Kolbrun...
Tom Chichester
Brett Duxbury
Brett Duxbury
Are you a Gateway Audio Player and Recorder Expert? Answer questions, earn points and help others
