Question about Kenmore 75180 Wall/Window Air Conditioner
There is condensation leaking badly from the front of the unit.
The unit has a proper tilt. When it runs for an extended period of time, the condensation build up and dips from the front of the unit. It actually pours.
It is a Kenmore model #75801700
    Brigadier General:
  • 4,044 Answers
I think I advised you on this earlier or something similar. You need to make sure the drain channels are clear so the water evacuates to the rear of the AC unit. The condensation is a natural result of the cooling process and can not be stopped. If there is too much condensation it is due to lack of air flow through the coils normally caused by a clogged filter or it has been run without the filter allowing pet hair and dust to clog the cooling grates. You can clean these grates with a dog/Cat flea brush that has 100's of little wires in the head. Use the brush in an up and down motion to collect and clear these grates of debris. That will increase air flow and reduce condensation.
Posted on Jul 13, 2010
  • 1 more comment
  • c_e_kucera Jul 13, 2010
    I have never been on here before. The cooling coils are clean. I clean them regularly. How can I check to see if the drain channels ae clear? I know AC units condensate. I am in the insulation business here in Houston. My company insulates chilled and heating water piping and AC Ducts for commercial AC systems.
    Instead of sounding so condecending, give me some practical help here.
    Also, when I tilt the unit to the rear the water does not drain. The drain pain under the coils is full.
  • James Young Jul 13, 2010
    My apologies if my first response sounded condescending. The drain channels run under the coils and move water away from the coils so they don't freeze over. You can clear these with compressed air or pressurized water from a garden house. When the condensation mixes with the dust in the air it makes a slimy kind of blockage. All you can do is clear these out so the water flows back to the rear or to carefully drill separate drain holes. This seems to be a common problem with this particular model as I've answered this question several times now over the past day. With the exact same model number, all explaining the same problem. If you have water coming out the front the drain channels are clogged or there is insufficient air flow to dry the coils. The lack of air flow is most often caused by the re-usable filter not being cleared. This can also be cleared with air from an air compressor or water both being sprayed from the opposite direction the air normally flows through the filter. When I clear the channels in my Window unit it use water and a sprayer attachment and spray under the coils to the rear and make sure the rear area is clear then use air to clear the coil area and under the coils to make sure the paths are clear. I have approximately a 15 degree tilt to the rear which is more than the installation calls for but it helps evacuate the condensation.
Hi, I have an air conditioner Frigidaire which is leaking in the front. The unit is in a window, in a 4th Floor and I don't have access to the back, how can I unclog the unit??. I am desperate!!!!
if it's just condensation leaking out the front of the unit it could be that the unit is not level in the window. If it's tilted too far into the room it will leak condensation into the room. Try to tilt it back just a hair so that the condensation leaks out the back of the unit.
Sep 02, 2013 | Frigidaire Heating & Cooling
My crosley air conditioner is leaking from the front. There in nowhere to drain it from the back. help
Hello, if this is a window unit make sure it is tilted back in the window about a 1/4 inch. If the unit does not have a drain then it uses the condenser fan blade to scoop up the condensate and splash the condenser to cool it and evaporate the condensate.
Jul 12, 2012 | Heating & Cooling
Water is draining into the house?.where is the drain?
Hello, the unit must be tilted back in the window to prevent the condensate from leaking inside. Some units will have a drain plug on the bottum, while others use the condenser fan to scoop up the condensate and splash the condenser to keep it cooler and evaporate the condensate.
May 29, 2012 | Maytag M3X05F2D Air Conditioner
Water leaking in floor board when ac is running for extended period.
refit the drain hose on the bottom of the heater unit it drains off the AC condensate ,as for the overheating then thats another matter and need the make and model to have a better idea
Apr 27, 2012 | Cars & Trucks
NewAir AF-350 is blowing water out the front louvers. Unit is 2 days old.
water normally condenses in the evaporator .. this runs down to a pan that drains to the outside section of the air conditioner .. there it it used to help cool the condenser and overflow runs out a drain in the back ... your unit is not draining the water properly to the back section .. that is usually caused by the air conditioner being being mounted with its top tilted toward the inside ... it should be level or slightly tilted toward outside for proper drainage ... its also possible that paper or other debree has clogged the drains inside the unit from the front section going to the back section ..
Jul 25, 2010 | Heating & Cooling
Condensation buildup
Make sure the unit tilts towards the outside. If it's installed level or tilted toward front it will not drain properly.
Jun 25, 2010 | LG Electronic Window Air Conditioner
Lg lwhd1200fr air conditioner is leaking water inside, best ideas on how to solve this problem?
REPOSITION UR WINDOW AC. RAISE FROM FRONT ABOUT 1/2 " SO WATER WILL DRAING DOWN TO CONDENSER OUTSIDE.
Sep 12, 2009 | LG LWHD1200FR Wall/Window Air Conditioner
My sub zero refrigerator is holding the set temperature however is leaking water from underneath the refrigerator. Sometimes the water is heavier than others
I would not be too alarmed about this. Most refrigeration systems will drip water off of the condenser coils while in use. This can most often be seen by cars that appear to "leak" only when the a/c is on. All that this "leakage"is is condensation. This is the same reason that window air conditioners need to have a slight downward tilt to the outside. This is also why they unfortunately, often freeze up.
If you're only noticing leakage while the refrigerator is running then I would bet even money that this is what's happening especially if the refrigerator is still staying cold. Most normally this condensation is caught in a drip pan which lets the water evaporate. However, during periods of extended use, especially with periods of high humidity i.e. the summer, sometimes the condensation is higher than what the drip pan can hold and you get leakage over the sides.
Unfortunately while this is a relatively minor problem about the only way you are going to eliminate this is to install a dehumidifier in your home, or simply tolerate it for a month or so during the summer. I would bet dollars to peso's that after mid august this won't be a problem.
One thing to note however, is that if you start to see that it is running constantly, or if you notice that it's not keeping cool, then it may be time to call in a service person. But for your particular problem I don't think that will be necessary.
Jul 29, 2009 | Sub-Zero 642
Thru wall GE A/C
Hi, If this is a new unit I would check the filter first and make sure it is clean. Also check and make sure it is slightly tilted to the outside. If its an older unit it probably needs cleaned. Window units naturally create water in the evaporator area. The water is suppose to drain to the back of the unit to the condensing area where the slinger ring on the condenser fan blade slings it into the condenser coil making it more efficient. There is usually a drain hole to drain excess water from the back of the unit. Any dirt in the pathway of this water or the wrong tilt will cause water to build up and drip or blow out the front. Anything touching the evaporator coil allowing water to run down the obstacle into the wrong area will cause the same thing. reduced air flow will cause the evap to freeze which could also cause a water problem.
Aug 27, 2007 | Heating & Cooling
Kenmore 75180 Wall/Window Air Conditioner Logo
42 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
