Need program codes for living solutions giant remote for a sanyo tv
SOURCE: programming a universal remote control for a tv
The code for a Sanyo TV set should be 100. Press and hold the TV button on the remote while entering the code. The light should blink 5 times if it was accepted, and then you can test to see if it worked.
Posted on Feb 10, 2008
  • 7 Answers
SOURCE: need codes for a Sanyo TV
0049, 0097, 0110, 0004, 0268, 0012, 0108, 0180
Posted on Jul 30, 2008
  • 374 Answers
SOURCE: need Sanyo TV code numbers
These are the codes for Sanyo TV'S for this remote. The newer TV codes are at the end so work in reverse order when inputting these codes. Thanks for using Fix Ya.
542, 589, 590, 591, 592, 609
Posted on May 25, 2009
the q guy
  • 393 Answers
SOURCE: i need a code for a living solutions giant remote
I found that these websites should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
Posted on Jul 25, 2009
Puppet03
  • 172 Answers
SOURCE: need program advice for philips direct tv 2585/01 remote
http://www.directv.com/learn/pdf/System_Manuals/Philips/Philips_DSX-5150_5353_5375.pdf
only one i found but they all seem to work the same.
Posted on Oct 24, 2009
Testimonial: "Thanks!!! I received a response within a matter of minutes and resolved the problem. "
Tip
0154, 0159 are the possible Living Solutions Universal Remote codes for a Sanyo TV
SANYO Codes: 004/ 013/ 049/ 108/ 110/ 180/ 209
thanks
on Aug 26, 2010 | Televison & Video
Living solutions a17g0510 item # m#606426 big universal remote control. I cannot program it to my old sanyo tv
TV Codes listing:
http://www.docstoc.com/docs/23925020/Programming-Remote-Control-Brand-Codes-TV-Sets
If those dont work try the last three(or four) digits in the tv''s serial number. That's the only way could find my ATV TV's remote code.
Oct 08, 2010 | Universal Remote Control Remote Control
Need remote code for symphonic tv. Have living solutions giant remote
    Programming a Living Solutions Universal Remote
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  2. Step 2 Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  3. Step 3 Push the power button on the remote. This should turn on the device that you are syncing.
  4. Step 4 Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  5. Step 5 Press "OK" or "Enter" on the remote once the synced device turns off.
  6. Step 6 Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
Jun 30, 2010 | Symphonic ST420FF 20" TV
I can't find the code for our tv brand it is a
    Try This Out
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player2.gif, VCR or stereo.
  2. Step 2 Pointthe remote at the device you are programming and press thecorresponding device button on the remote. These buttons are labeled"TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  6. Step 6 Pressthe device button for the component you just programmed, and hit thepower button while pointing the remote at the component. If programmedcorrectly, the device should turn on, and you should be able to controlit with your Living Solutions Universal Remote.
Sep 21, 2009 | Big Button TV Universal Remote
I need a code for a living solutions giant remote control A17G1311
Jul 24, 2009 | Televison & Video
Living solutions giant remote control 3-in-1, A17G0510 (Item606426)
I had trouble programing the living solutions giant remote - c17g0801.
But after many times serching I ran across a genius' resolution (maybe it was 2 genius') -
Jumbo Remote:
Make sure you have device turned on.
Hold the device button you want to program for 3 seconds & release.
Push & release the power button & the red light will remain lit.
Push the CHANNEL UP button over & over slowly until the device turns off.
When device turns off press OK button.
Oct 27, 2008 | Philips Magnavox Learning Universal Remote
Code list for universal remote control-name brand is living solutions
This is what the manual says: Prgoramming the remote using PowerScan: 1. Manually turn OFF the device you wish to program (TV, VCR, DVD) 2. Press and hold the apprpriate device key (TV, VCR, DVD) until the red LED illuminates. This indicates that the Remote is in Programming mode. 3. Press and release the power key. The LED flashes once and stays ON, indicating that the remote is in PowerScan mode. 4. Press either the CH+ or CH- key Button repeatedly until the device switches ON. The CH+ Button searches upward in the code list, while the CH- key searches downward. (So since I have a Toshiba tv, I elected to search upward to get to 'T' faster. 5. When the device turns on, press and release the OK Button to store the new code and exit. To exit without setting the code, press the GO BACK Button. NOTE: If you press CH+ or CH- again after the device turns on, the device will not be programmed; you will need to repeat Steps 1-5 again. 6. Press and other operable key (VOL+/VOL-). If the device responds, no further programming is required. If not, repeat Steps 1-5.
Jun 08, 2008 | Big Button TV Universal Remote
Living solutions remote control codes
I have a Universal Remote Control Model ATC-1311 Giant remote. I have lost the codes to and instuction book to. Can you tell me where to get at least the code for my T>V> Thank you
Mar 29, 2008 | Televison & Video
Televison & Video Logo
330 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
