Question about Carrier BCA101R Air Conditioner
My air conditioner expels black fuzzy pieces of a dust like stuff. It is only noticed after it has been on, laying in the general area.What is it? And how do i get ride of it. We have a Major Highway behind our house.
  • Carrier Master
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly. Using the model number BCA101R this is a through the wall Air Conditioner. With long term use Air Conditioners build up dirt on the blower fan even IF you clean the filter on a regular basis. The particulate that builds up on the blower wheel is very fine. If you look closely at the particulate it appears black but most of the time is a very dark brown. That is dirt build up that is loose on the blower wheel and passes freely out the louvers when it comes loose from the blower wheel. When an Air Conditoner is on for long periods day after day there should be a routine maintenance cleaning schedule for the unit. Light use you can get by with cleaning it every 6 to 9 months. With heavy use you will have to clean it every 90 - 120 days. Cleaning involves removing the blower motor and power washing the evaporator and condenser coils along with the blower wheel and the rear fan blades. Anytime a power washer is used it is VERY important never to spray pressurized water at an angle other than straight on as it will bend the fins of the coils. Once the fins are bent straightening the coil fins can be a major hassle. This cleaning can be done by the home owner but.... the home owner must be able to follow electrical safety precautions by making sure the unit is not powered and that the run capacitor has been safely discharged. The control panel must also be disconnected and removed to perform proper cleaning.
Thanks for using FixYa.
Kelly
Posted on Jul 13, 2010
My ice maker does not work
Hi there one of the biggest reasons for not getting cold which will affect the ice maker also is -- low or no air flow.
2 areas - 1) inside the freezer section are vents and they should have some clear areas (our freezer often gets crammed full of stuff)
2) under and behind the fridge is a dust bunny breeding area - pull the fridge out and get as much dust and stuff off the coils as possible (I use a vacuum and a small paint brush). The coils transfer the heat out of the fridge like an air conditioner. Be gentle - coils are somewhat fragile.
Some fridges have a faceplate that pops off at the front.
Sep 19, 2014 | Pragotrade 83-4020-W Weston 18In Frezer...
What is the black stuff blowing out of vents?
Mold. Moldy dust. You need to clean your unit.
May 09, 2014 | Mitsubishi Mr. Slim MXZ30TN Air...
When the unit is turned on, for the first 15 minutes or so, there is a distinct stale mouldy smell. I suspect dust collected on the unit coils is being wet by condensensation and it smells as the first air...
You can check the cause of that smell if you have the tools to open the unit. The first test is to place a piece of paper in front of the evaporator and start the fan. If the paper is **** or stays in front of the evaporator, you have a clean evaporator. If it is not ****, you need to open and clean the unit. The blower may be filled with dust and molds. It is best to find someone who knows how to work and clean your a/c unit
Sep 10, 2011 | Carrier 52PQ307 Wall/Window Air...
Black flakes
Chances are what you are seeing is not mold, but deteriorated insulation from the inside of the unit being ejected out the air discharge.
You may need to partiallly disassemble the front of the unit and find the area where the insulation may be damaged. If it's badly deteriorated, it may need to be replaced. In some units, the insulation is glued. In others, it's clipped in.
If it's just bruised, then a small piece of metal screening (1/8" or 1/4" hardware cloth) can be placed and secured over the damaged area to prevent subsequent damage and the black flecks you are witnessing.
Jul 12, 2010 | Emerson Quiet Kool 10GV13 Air Conditioner
Black particles coming out of the room air conditioner
dirt, dust, or mold. could also be the tubing insulation flaking off. either way, open it up and clean it out. the dirt, dust, and flaking insulation can restrict air flow through the coils and cause the ac to not function properly. if it is mold, it's can cause sickness (legionaire's disease). do not use chemicals on the coils. it might be best to replace the ac alltogether. to prevent mold: when installing the ac, make sure the unit is slightly tipped towards the outside. any condensation that collects on the coils will drain out. failure to do so will result in water pooling inside, and this can cause mold.
Jul 30, 2009 | Kenmore 73259 Air Conditioner
Maytag M3X05F2AK air Conditioner -BLACK CHUNKS FLYING OUT
remove front cover and clean the coils off with a nylon brush. make sure filter is clean. with front cover off take it outside hook it to an extension cord and set it on the floor. then let it run till the stuff stops coming out. if you want to open the whole thing up you could clean it out even more example being the inside fan area behind the coils, but the first option should work.
Jun 05, 2009 | Heating & Cooling
My Fresh Air by EcoQuest blows out black like dust/substance. So much so that around the unit and on the wall is turning black. Is this working properly?
The unit is designed to drop particulates out of the air. If you have a heavily polluted area there are more allergens/dust in the air and this might create a 'dust-shower'.
The unit charges particles negatively so the particles bond with positively charged particles. Then the particles drop out of the air or stick to a nearby object. This could leave some black stuff on the wall. You can easily wipe this off, most of this is grime/dust.
Dutch
Apr 24, 2009 | Ecoquest Fresh Air Living Air Purifier
Kenmore ac blowing black peices all over room.
that is foam insulation around the seal of the evaparator box pull the unit from the wall remove the cover to get to it and clean or replace it
May 10, 2008 | Kenmore 70088 Air Conditioner
Carrier BCA101R Air Conditioner Logo
164 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
