Question about LG 42LC7D-UB Television
LG 42LC2D Side Buttons/Remote don't work
LG 42LC2D
When you supply power to the TV it automatically turns on (green LED flashes 2 times then goes solid green) and comes up with the last input selected.
The video and sound are working great at this point.
The problem is that the side buttons do not work at all nor does the remote.
When you push buttons on the remote, the green LED flashes as if reading the signal but nothing happens on the TV.
Nothing happens at all when side buttons are pushed.
Things I have tried:
I have tried cleaning the Remote input jack on the back.
I have replaced the IR Remote sensor board and cable to the MB with a brand new one.
I have tried disconnecting the board with the side keys on it and seeing if the remote would work. Same behavior with LED flashing as if getting signal but nothing on the TV.
Here is the kicker:
I have connected to the RS232 port with a laptop and I can make all the TV functions work properly including turning the set on and off, all inputs, everything.
If I turn the set off using the RS232 port and then remove power supply for 15 seconds or so, when I plug it back in the TV once again automatically powers up (even though I had it "powered down" or in standby as the last known state).
ronaldo_ross
  • 1056 Answers
SOURCE: No Picture, No Sound
You can try troubleshooting the power supply section, which actually the only thing you can fix in these tv. check for leaking capacitors, bad semiconductors, such as diodes, transistors, which may be overheating and causing a short. troubleshooting electronic circuits is a pain unless you know a little about it. You may want to learn a bit about electronic first before you actually start taking parts out of a circuit.
Posted on Aug 04, 2009
SOURCE: LG 37LC7D remote doesn't work
Turns out there is a problem with certain LG models made in Mexico during May. Not only did the remote stop working, but the TV started shutting itself on and off randomly. Took it back and exchanged it for a Panasonic. Not putting up with that, LG.
Posted on Sep 24, 2007
  • 16 Answers
SOURCE: TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
Posted on Dec 07, 2008
  • 197 Answers
SOURCE: tv won't turn on - power SUPPLY OK
bad main pcb
Posted on Jun 07, 2009
  • 12 Answers
SOURCE: 42" LG 42LC2D HDTV Will not turn on
Hi, sounds like a power supply problem, most likely needs capacitors replaced, costs about £5 to do it yourself, and a fortune in the repair shop, easy enough if your handy or know someone who is,its worth a try,it'll be going in the bin anyway, cam
Posted on Jul 14, 2009
My LG 42LC7D tv wont turn on. The green led lights but no picture or sound
There could be several things going on, I would start with having the power supply checked. I've worked on several LG sets from that time frame that all had bad capacitors in the power supply causing all sorts of issues
Nov 27, 2012 | LG 42LC2D 42 in. LCD HDTV
Tv turn on no pic or sound
Try unplugging it for about half an hour, plug back in, if it still does not work, you will have to open it up and do some troubleshooting.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Parts: www.shopjimmy.com
Jun 17, 2010 | LG 42LC2D 42 in. LCD HDTV
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
The following steps should be able to correct the problem:
1) Unplug the TV or remove AC power from the TV
2) Count to ten and then plug in the TV
3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
6) The TV’s lower left Blue Power LED will come ON.
7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
8) Press the [Mute] button on the TV remote twice
9) Unplug the TV or remove AC power
10) Count to ten and plug the TV in
11) The TV power should automatically come ON and the blue power LED with be ON
12) Wait 40 seconds and the TV picture should appear
13) You can now continue using your TV.
14) If the picture does not appear, power on the TV manually:
· If the LED begins flashing, unplug and power ON a second time.
· If the LED begins flashing again, power ON the TV without unplugging
If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control.
2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
3) Scroll down to "system info" and select [OK] button on the remote
Dec 19, 2009 | JVC Televison & Video
37LC7D LG LCD tv turn's on but remote keys and tv side keys unresponsive.
HI,
I'll think your power supply is down.
Maybe there's still garanty on your TV.
kind regards,
Gerard
Oct 07, 2008 | LG 42LC2D 42 in. LCD HDTV
Lg 42" hd 1080p
This could be bad capacitors on the power supply board. My LG 42LB1DR has a known problem with this and I replaced the four bac capacitors myself and saved 5-6 hundered dollars that I was also told that it would cost to fix. I fixed for under 10 dollars and about 20 minutes. LG knows about it but they dont really want to admit it. My TV was only 26 months old when this happened. The four capacitors are made by Samxon and are 2200uf @ 10v. They are junk so even if you have the entire board replaced for say $200 its just going to happen again. They need to be replaced with a different brand.
Sep 10, 2008 | LG 42LC2D 42 in. LCD HDTV
 I heard that Best Buy is still selling these models despite this known problem- I am trying to have mione fixed but was told the replacement part is on back order until DECEMBER!
Sep 06, 2007 | LG 42LC2D 42 in. LCD HDTV
LG 42LC7D-UB Television Logo
724 people viewed this question
