My Cannon MX700 printer has the alarm light on and the screen says there is a paper crunch. I went over the machine with a fine tooth comb and found NO PAPER JAMS, The light came on and when I pressed "ok" a single sheet came out of the back storage. I could not transfer the front storage. I use my printer every day. I really like the printer, however it is easier to buy another printer than not being able to get it fixed right away.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First, verify that there is actually no paper jam (open all the doors, take out the paper tray, take out the cartridges and visually inspect). Turn printer off and unplug the printer from all cables (power, USB, etc). Try to hold it upside down and gently shake it so that if there is any paper inside it’s removed. If still it’s not resolved then clean the print head. To clean the print head take a hot water towel with the printer unplugged and the cartridges out, clean it till the time you see there is no ink residue on the towel. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 13, 2010
My cannon printer, model MX700 will not so anything, when I trun on the printer, the alarm button is blinking and on the screen it replys error code 5400, what am I to do to fix this problem
Hey!!
If you open the cover like if you were to replace the ink,look in there and at the back of the inside of the machine there is a silver shaft,just above it you will see a thin greyish strip!Take a damp cloth and clean it very gently!!Should sort out your problem!!
Good Luck!!
Jul 07, 2011 | Canon Office Equipment & Supplies
My cannon printer MX700 just now paper have jam inside. After i taken out of paper that jam inside my cannon printer have a error of 6A80 and it can't fixed. Pls help. Thanks.
The 6A80 indicates that the mechanism called the `purge unit' does not work correctly. In some cases after a paper jam, some paper gets in the unit. Try this:
Turn on the unit and open the cover. Hopefully, the printhead will come to the center. If it doesn't, unplug the printer and try to move the printhead by hand, to the left. Do not force it. If you are able, get a flashlight and inspect the area inside the unit to the right. There may be bits of paper in that area. Being careful, remove it with a tweezers or some such tool.
If you cannot see anything, then the machine will need to be dismantled for service. I recommend authorized service.
Sep 20, 2010 | Canon MX700 Office All-In-One InkJet...
Canon MX 700. I cannot get print alignment. I am missing lines. Have done head alignment 20 times and still cannon resolve issue. Have replace cartridges, cleaned heads, rollers, deep clean and still no...
My MX700 is 1 year old and I to have issues:
1) Alignment
2) Says it's out of paper when there is paper in it. Shutting off an Turning on usually helps
3) Feeds multiple pieces of paper at once!
HELP
Aug 30, 2009 | Canon MX700 Office All-In-One InkJet...
Cannon MX700 Output is blurred
You will have to replace the print heads on this printer. They most probably got damaged when you pulled out the paper jam.
Aug 12, 2009 | Office Equipment & Supplies
I HAVE ERORR CODE 5700 ON MY CANNON MX700 , HOW TO FIX IT
5700 is a sheet feeder error, if there is not something caught inside like a ink pen, paper clip, or kids toy, you might need a new feed assembly. Not too expensive, but a shop repair only.
Aug 03, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Can not clear memory on PIXMA Canon MX700
dear david
try this
) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release
the buttons). The Power LED lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons.
(Each time the Stop/Reset button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green,
starting with Alarm LED.)
4) When the Power LED lights in green (and "Service Mode Idle" is displayed on the LCD), press the Stop/Reset button 4 times.
5) Press ON/OFF, press Stop/Reset 2 times
6) Press ON/OFF. Unplug printer and plug back in. turn on and should be cleared
oke , post me back
cropp
Mar 31, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon mx700 can i use the rear verticle paper feed as an alternative to the front bottom horozintal paper feed
Yes, use the "feed switch" button on the front of the printer. There are small lights that indicate the paper tray to be used.
Sep 24, 2008 | Cannon Office Equipment & Supplies
Canon mx700 printer
Using a q-tip clean the rollers with rubbing alcohol.
Try different paper. The fact that it grabs more than one page means the paper or rollers are dirty.
Mar 05, 2008 | Canon MX700 Office All-In-One InkJet...
21 people viewed this question
jasbo
jasbo
