Question about Samsung SyncMaster 930B 19" LCD Flat Panel Monitor
Check signal cable
Cant get the monitor to work. It reads: check signal cable in Samsung syncmaster 930B
    Sergeant:
  • 212 Answers
Check if the monitor is not working by connecting this monitor to another computer.
If the monitor woks on another pc, then the pc is the issue and not the monitor.
If monitor doesnt work on the other pc, then it's the monitor that needs replacing.
I hope this helps you :)
Posted on Jul 13, 2010
How do I replace the inverter in a samsung syncmaster 930B?
The 930B and the 710T use the same power supply/inverter boards. Below is a link to a repair guide for the 710T unit that should get you going in the right direction.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-syncmaster-710t/
Jan 27, 2013 | Samsung SyncMaster 930B 19" LCD Flat Panel...
I have a samsung syncmaster 930b attached to an HP Pavilion Slimline s5660f Desktop PC, plugged into the DVI port of the PC. However, I cannot get the monitor to come up. There is power to it. I get the...
from user manual troubleshooting section
(When connecting D-Sub cable) Check the signal cable connection. (When connecting DVI cable) If you still see an error message on the screen when the monitor is connected properly, check to see if the monitor status is set to analog. Press Source button to have the monitor double-check the input signal source.
Source button Activates a highlighted menu item.
/ Push the 'SOURCE', then selects the video signal while the OSD is off. (When the source button is pressed to change the input mode, a message appears in the center of the screen displaying the current mode -- analog or digital input signal.) Note : If you select the digital mode, you must connect your monitor to the graphic card's port using the DVI cable.
https://images10.newegg.com/User-Manual/User_Manual_24-001-063.pdf ninth page in user manual
source button fourth from the left when facing monitor. looks like a box with an arrow pointing left.
Mar 05, 2018 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung syncmaster 930b 19inch: blinking green light on startup screen does not respond turn off or on after a random time period it usually works once screen goes from black to windows it stays...
<P>If you try new cable, try with another PC and still have the same problem, then you need to inspect the inside for bad caps first just like all the SAMSUNG as shown.</P><P style="tab-stops: center 3.25in left 255.75pt"><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A href="http://s807.photobucket.com/home/budm/allalbums"><FONT color=#800080>http://s807.photobucket.com/home/budm/allalbums</FONT></A><?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><A href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</A><o:p></o:p></SPAN></P><P><SPAN style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <A href="http://lcdalternatives.auctivacommerce.com/Viewsonic-C196320.aspx"><SPAN style="mso-spacerun: yes">&nbsp;</SPAN>http://lcdalternatives.auctivacommerce.com/</A><SPAN style="mso-spacerun: yes">&nbsp; </SPAN>he can make you a set of caps for you.<o:p></o:p></SPAN></P><P>&nbsp;</P>
Aug 25, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
No video signal from new computer AMD Athlon
have you tried the monitor on another PC? if yes? did it work? if yes, your new computer is set on a very high resolution that the syncmaster could not adjust...
May 09, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
My Samsung Syncmaster 930B was working fine unti I disconnected and then reconnected it to my computer. Now I get a black screen with a roaming box that says, "check signal cable".
Hello
1st Pull all power from pc from the wall.Plug back in and start pc up.
While starting hold down the f8 key and select safe mode.
once in go to control panel and select display.
set resoulution to default 60 hz and screen size to 800 by 600.
Reboot.
You may need to readjust your screen again.
Hope this helps.
Jan 14, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung 930b analog to digital input
Did you check for new drivers to both vid card and display? That'd be the first thing to try.
May 30, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung SyncMaster 930B 19" LCD Flat Panel Monitor Logo
505 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
